Pitot/static leak issues when using a "squat switch"
Old November 26th 19, 06:22 AM posted to rec.aviation.soaring
Charles Longley
Default Pitot/static leak issues when using a "squat switch"
OK so I fly a glider which has nothing in it except a radio and basic instruments. I have an Oudie to keep me out of trouble. I just bought a FLARM brick with ADS-B in. Which I’ll install this winter. I’ll probably install a Trig Transponder next winter with ADS-B out. I’ve installed several different ADS-B out transponder systems in power airplanes.. I haven’t yet installed a squat switch in any of them. Generally power airplanes are faster than gliders. But there’s obviously Cub types that will fly at glider speeds so why don’t they have squat switches. I am just spit balling here. But it’s a good question.
Old November 26th 19, 07:10 AM posted to rec.aviation.soaring
Darryl Ramm
On Monday, November 25, 2019 at 10:22:16 PM UTC-8, Charles Longley wrote:
OK so I fly a glider which has nothing in it except a radio and basic instruments. I have an Oudie to keep me out of trouble. I just bought a FLARM brick with ADS-B in. Which I’ll install this winter. I’ll probably install a Trig Transponder next winter with ADS-B out. I’ve installed several different ADS-B out transponder systems in power airplanes. I haven’t yet installed a squat switch in any of them. Generally power airplanes are faster than gliders. But there’s obviously Cub types that will fly at glider speeds so why don’t they have squat switches. I am just spit balling here. But it’s a good question.
Why don't you ask the person who did the installation in any "cub types" how they intended it to comply with 14 CFR § 91.227 (d)(1)? And what happens in strong headwinds like those giving near zero groundspeed? Ask them if they plan flying in those conditions.
The simple assumption many power installations will make is to use GPS based air/ground switching... and slow enough GA aircraft will have issues if they get into a strong enough headwind. But they likely do not fly often in those conditions or have never thought about it. We should be thinking about it in gliders as earlier ADS-B Out installations ran into immediate problems in wave.
Heck in strong wave locations towplanes may well run into this issue, so for those operators at places like Minden it might be a good idea in the towplane as well, what the FSDO wants for approval, if anything, if the STC says use GPS determination is up for discussion with them.
I tried to explain what I understand the regulations to say, and point out what folks operating in wave conditions want to avoid (GPS groundspeed switching saying you are on the ground when at altitude in wave). If it was not the apparent need for automatic switching we would likely be better off selecting "none" as a TT22 switch setting and just rely on the pilot switching the transponder manually between ON and ALT.
Old November 26th 19, 02:48 PM posted to rec.aviation.soaring
Trying to apply logic here is risky, but maybe because the STC doesn't ask for it because the airplane is not intended to fly at zero groundspeed and so emitting ground mode while flying would be inadvertent.
If the glider is intended for wave and/or not experimental, then the STC would ask for the switch and zero groundspeed in the air would be expected. So being able to convince an investigator that you did a good faith effort in emitting the right signal "during the appropriate phase of flight" would lead one to the extra switch.
Old November 26th 19, 05:44 PM posted to rec.aviation.soaring
Dan Marotta
I've said this before concerning my ADS-B Out installation in my
Certificated Stemme:
I did the installation myself as told to the FAA on my Public
Performance Report.Â* One of the questions to answer was, "Who did the
installation?".Â* By stating that I did the installation, I then had to
identify the A&P IA who inspected the installation and signed it off.Â*
He provided me with a logbook sticker and a copy of the 337 he sent to
the feds to document the installation as having conformed to the STC.Â*
At the first opportunity I had a pitot/static check and a transponder
check performed.
I installed a pneumatic squat switch simply to ensure that I would never
report GND mode while in flight, even while flying backwards in wave.
I followed the STC installation instructions which left most of it up to
the installer for a glider.Â* For power planes the instructions are
specific about high vs low wing, antenna location, etc., but a glider
fuselage does not fit the mold.Â* I installed the antenna on an aluminum
shelf made by a local shop and mounted inside the engine bay, under the
fiberglass turtle deck.Â* I installed the TN70 behind the panel and had
to modify the prefab cable since it powered the TN70 from the TT22 and
the STC specifically stated to power the TN70 through a separate circuit
breaker.Â* I thought the price of the pneumatic switch was outrageous but
since it's a Certificated aircraft, I paid the price.Â* You can get a
switch for considerably less for an Experimental ship.
The most difficult part of the setup was converting metric to real
measurements and back (sorry, couldn't help it:-D).
On 11/25/2019 11:06 PM, Darryl Ramm wrote:
On Monday, November 25, 2019 at 8:39:51 PM UTC-8, wrote:
On Sunday, November 24, 2019 at 4:51:37 PM UTC-8, wrote:
On Sunday, November 24, 2019 at 10:56:03 AM UTC-5, Dave Nadler wrote:
On Friday, November 22, 2019 at 3:01:42 PM UTC-5, wrote:
I have heard gossip of ... leak issues.
Cure for squat leaks: https://tinyurl.com/ycvg3to4
Well, that depends.
Can someone point me to the regulation that requires an experimental glider to install a squat switch along with adsb?
There is no regulation that says that. Nobody here (including me) has ever claimed there is AFAIK.
The relevant bit is hidden in 14 CFR 91.227 (d)(1)
...Minimum Broadcast Message Element Set for ADS-B Out. Each aircraft must broadcast the following information, as defined in TSO-C166b or TSO-C154c.....
(1) The length and width of the aircraft;
Length and Width of the aircraft are only transmitted in ground mode messages. So this regulation says for 2020 Compliance the system must be capable of switching to ground mode. But I (and others) interpret the intro wording "each aircraft must..." as a direction that this change must be automatic. It's not saying each aircraft must be capable of being put in air/ground mode by a pilot. It's saying the aircraft must... Now it's sure not very well worded but that requirement is how manufacturers including Trig are interpreting that clause.
How do you as an installer propose to meet 14 CFR § 91.227 (d)(1)?
This is something the FAA clearly cared about as RTCA DO-260 (that defines 1090ES Out) actually intended light aircraft 1090ES Out to be able to stay in airborne mode while on the ground. The FAA deliberately changed that in these regulation, likely with concern about integration with ADSE-X and ASSC ground management systems. Which uh is really unlikely to be an issue with gliders.
The worse thing to do is to use the GPS air/ground determination mode in gliders that may fly in wave, or even strong headwind. Flying around spewing ground mode messages will eventually get you a letter from the FAA. How different traffic/collision avoidance systems behave when they see an erroneous ground mode targets is too complex to guess, but likely not good.
Not ever transmitting a ground mode message might well have no practical impact in typical glider operations. Few gliders are landing and taxing around SFO or JFK. But gliders do operate at some busy airports at times and you want to be careful of possible interactions with a variety of traffic systems in other aircraft. Some airports also have ADS-B coverage down to ground level and in those cases the FAA might followup up with any SIL=3 ADS-B Out systems that is not switching to ground mode. But not being a likely practical issue and not meeting regulation requirements are two separate things.
So it's *my recommendation* that 2020 Compliant ADS-B Out installations in all glider use a pitot squat switch.
If the glider is type certificated your A&P IA should follow the instructions in the TT22/TN70 STC. Not all of that STC is directly relevant to glider installs, but it does call out a the pitot squat switch (luckily it does not mandate the GPS air/ground mode determination).
If would hope A&Ps installing ADS-B out systems in experimental gliders are discussing how this works with owners, whether they are installing a pitot/squat switch or not, checking the operation of this systems (e.g. confirming the TT22 automatically display flips from ON to ALT as the glider takes off). and making sure the owner understand how to use whatever they have installed. FAA ADS-B Performance Reports will flag ground mode when airborne errors and airborne mode when on ground errors (although in many cases the FAA receiver towers will will not see your aircraft on the ground). If you install any of this stuff and it routinely has problems, expect the FAA to eventually followup with you.
If you are doing this yourself.... how do you propose to meet 14 CFR § 91.227 (d)(1)? What will the the person who signs off the glider's annual condition inspection expect to see for 91.227 compliance?
Squat switches are really a subtler things here, so many ADS-B Out installations have other more fundamental problems because A&Ps or owners doing work are not being careful with basic software setup. That can include not working at all, working, but not well enough to be seen by ATC, etc. You have to test each install by pulling an FAA Public Performance Report. The TT22 just saying it has a position fix is not enough to know things are working OK. I hope A&Ps are requiring owners to do an ADS-B Out test flight of all experimental gliders they work on, even if not called out in FAA policy (like it is for type certified aircraft). The FAA ADS-B Out Public Performance Report has been updated to request the submitter asking for the report to note who did the installation. The FAA seem to be exceedingly helpful with ADS-B Out problems, but pay attention.
TABS/TSO-C199 specifically allows the aircraft to stay in airborne mode on the ground. So for a TABS install I would argue the best thing to do is can just leave the pitot switch set to "none" and let the pilot manually select ALT. TABS also broadcast at a lower SIL level and not visible to ATC and not intended to interact the same with things like ADSE-X and ASSC.
Dan, 5J
Old November 26th 19, 08:01 PM posted to rec.aviation.soaring
The STC approved Peregrine squat switch required for use with the Trig TN70 is $125.00 from Aircraft Spruce & Specialty. https://www.aircraftspruce.com/catal...it10-05913.php
It has been mentioned a cheaper pneumatic squat switch could be used if intended for an experimental glider running the TT22/TN72 combo.
Please identify suitable "experimental" pneumatic squat switches.
Thanks.
Old November 26th 19, 08:50 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Thanks.
http://www.craggyaero.com/transponder.htm
To confirm correct operation while sitting on ground, turn the transponder mode knob to alt and the display should say grd, then you can increase pitot pressure to above the stall speed setting and the transponder display will switch to alt.
If you fly in wave without this switch your ground speed may be very low and ATC will think you are on the ground.
AIR PRESSURE SWITCH/Normally open, 42 knots, adjustable.
$48.50
Richard
www.craggyaero.com
Old November 26th 19, 09:07 PM posted to rec.aviation.soaring
On Monday, November 25, 2019 at 10:06:27 PM UTC-8, Darryl Ramm wrote:
"....the system must be capable of switching to ground mode".
Hi Darryl, thanks for providing the relevant regulation. I find it very unclear, but now at least I know the regulation behind this discussion. Personally, I would say that since my glider can't fly without me in the cockpit, I am an essential part of the system, and as such, I will manually turn the adsb system off when I'm on the ground. So I'm doing that in my experimental glider, with my self-installed TT22/TN72. My installation has passed the airborne adsb check that ATC provides, and I showed that report on my last condition inspection, although I was not asked to. I did also buy a squat switch on ebay for $12, but decided not to install it, since I worried that a small leak would upset my flight computer, which is vital when flying here in the west.
Old November 26th 19, 10:06 PM posted to rec.aviation.soaring
Tom BravoMike
Thanks.
$48.50
Richard
www.craggyaero.com
My glider can fly slower than 42 kts airspeed with flaps. What then? Can that be adjusted? How is it done?
Old November 27th 19, 05:15 PM posted to rec.aviation.soaring
Thanks.
$48.50
Richard
www.craggyaero.com
This switch says 34 Kts.
http://www.craggyaero.com/Trig/Airspeedswitch.pdf
The less expensive switch on this page
MLP503 I tested at 28 KTS
Richard
www.craggyaero.com
Old November 27th 19, 05:16 PM posted to rec.aviation.soaring
Thanks.
$48.50
Richard
www.craggyaero.com
Adjusted with a screw on the switch.
Richard
www.craggyaero.com
Are air filters necessary on Pitot, static or TE lines? Pete[_9_] Soaring 15 December 18th 18 02:13 AM
Pitot Static 411 413 followup post A Lieberman Owning 12 June 18th 05 04:00 PM
My static system had a leak Derrick Early Instrument Flight Rules 1 August 25th 04 02:35 PM
pitot/static location Ray Toews Home Built 2 December 30th 03 12:52 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
