Retractable Comm Antenna
Old September 6th 04, 06:22 PM
Jim Weir
You are correct. Ron DOES get surly when working with electrons, especially
with those moving rapidly.
(Leon McAtee)
-Ron Wanttaja wrote in message
-recall they were palm sized units.........Surly you could rig
http://www.rst-engr.com
Old September 6th 04, 06:59 PM
On Mon, 6 Sep 2004 08:26:01 -0400, "TaxSrv" wrote:
Ron Wanttaja wrote:
I'd like to get the antenna oriented vertically, too, though for the
receive side, the longitudinal orientation would probably be fine.
On the Escort II, both nav and comm receive from the nav antenna,
which should be oriented horizontally for more critical nav purposes.
Comm sensitivity is affected, of course, but on my Escort II it
receives comm more than good enough.
The original suite of antennas on my plane was *two* horizontally oriented
dipoles. Under a metal turtledeck cover. Worked pretty good, for both
receive and transmit.
I've never used the VOR function of my Escort, so horizontal orientation on
the receive side is not critical. I have, once or twice, considered
replacing the Narco with a Comm/GPS unit. But then, I'd *still* have a
second antenna to install...
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
