At 02:00 16 March 2005, Toad wrote:
Regarding the difficulty of sequencing gliders for landing after a cylinder finish, this is exactly what gliders do every good soaring day. Never had a problem myself on a typical non-contest day without a finish cylinder. So why do you think problems arise with cylinders in contest situations? My theory is that the modern GPS-enabled minimum-time tasks compress finishers more than the old system and the cylinder introduces just enough randomness to reshuffle the landing sequence from the finish sequence. The net result is a bit more 'pattern roulette' than I knew from gate finishes in the old AST world. Not a problem for pilots who exert good judgement and use the radio - potentially an issue for those who don't. 9B |
![]() Andy Blackburn wrote: At 02:00 16 March 2005, Toad wrote: Regarding the difficulty of sequencing gliders for landing after a cylinder finish, this is exactly what gliders do every good soaring day. Never had a problem myself on a typical non-contest day without a finish cylinder. So why do you think problems arise with cylinders in contest situations? I have never had or seen a problem with the cylinder finish. It is also the only finish type that I have used, since I started racing in 2002 and fly in sports class with my 20 year old glider. I have seen plenty of "pattern roulette" at busy soaring sites on non-contest days. Most of those patterns are non-events. Everybody lands somewhere, leaving as much space as possible for the next guy. Todd |
At 00:30 17 March 2005, Toad wrote:
My point is that moving that poor judgement UP 500-1000 ft DOES help solve problems. Todd My experience is it introduces about as many as it solves: mixed traffic between the cylinder edge and the airport, re-sequencing of traffic from finish to pattern entry, potential for low altitude thermalling to make the 500 (or 1000) foot limit, ballistic pullups below stall speed for the same reason, mixed finish techniques leading to conflicts (pull-up or press on). That's just the ones that have happened so far. Of course none whould have happened had the pilots involved exercised better judgement. On the proximity issue, keep in mind that a low energy finish on a 500' cylinder will have you less than 500' from whatever you're flying over prior to entering the landing pattern and therefore at least as much in violation of any relevant FARs as a gate finisher. My view after reading the regs is they both are legal. Of course we cold solve all of this AND address the 15-minute rule if we just made the rules read that you have to finish no lower than you start. Now THAT would spice things up. 9B |
Of course we cold solve all of this AND address the 15-minute rule if we just made the rules read that you have to finish no lower than you start. Now THAT would spice things up. This, I like 8^) |
NS Norfolk Gate 2 NATOPS - All Hands Memorize Immediately! | Yofuri | Naval Aviation | 0 | December 17th 04 05:38 AM |
Sources for Yellowed tagged Remote Gyro and Flux Gate. | Michelle P | Owning | 0 | July 18th 04 12:19 AM |
FS2004 gate problem | Quilljar | Simulators | 2 | June 1st 04 10:36 PM |
Showalter in Orlando charging $45 to open gate | Piperflyer | Piloting | 2 | February 24th 04 03:20 AM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
