Instrument panel labeling
Old January 10th 20, 04:59 PM posted to rec.aviation.soaring
Default Instrument panel labeling
One word of warning about fonts to use. Don't make the font too fancy - you need the label to easily READABLE during flight. Arial is great. Brush Script is definitely NOT (especially so in all caps).
Case in point are some of the contest IDs I have seen on the vertical stab that are cool but truly UNREADABLE. What's the point?
My $0.02.
John DeRosa OHM Ω
Old January 10th 20, 05:08 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John DeRosa OHM Ω http://aviation.derosaweb.net wrote on 1/10/2020 8:59 AM:
Just look at your Flarm: it tells you the contest ID way before you can read it
off the glider, and really, that's too late to be useful.
Old January 10th 20, 05:45 PM posted to rec.aviation.soaring
Bob Kuykendall
https://www.mscdirect.com/product/details/61659249
Old January 10th 20, 05:52 PM posted to rec.aviation.soaring
Roy B.
Amen John! As in, "Blue Smear - on your right side"
ROY
Old January 10th 20, 06:00 PM posted to rec.aviation.soaring
George Haeh
I've used a local sign shop for vinyl transfer lettering for contest ID and registrations. Very simple to apply – lots of options.
Instrument panel labels are of course a much smaller font. Check with the sign shop.
Old January 10th 20, 07:36 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, January 9, 2020 at 9:26:27 PM UTC-5, wrote:
I'm looking for ideas on how to make professional looking placards/labels...
I've used https://www.frontpanelexpress.com - they do a great job.
They can do enclosures, for example lettering and cut-outs (DSUB, LED) on
the CAN-repeater I designed for Antares:
http://www.nadler.com/Antares/WCAN3_...ed_closeup.JPG
Great for larger parts like a fuse sub-panel as well as smaller stuff.
Hope that helps,
Best Regards, Dave
Old January 10th 20, 07:58 PM posted to rec.aviation.soaring
These are some great ideas. I like the durability of the anodized/engraved plates but was hoping to find something like the transfer that Cookie suggested from Decalprofx. If you read this, how durable have the decals been? Did you apply a clear coat over them? I think I could be happy with either of these results.
Doug
Old January 10th 20, 08:52 PM posted to rec.aviation.soaring
Dan Marotta
That's great, but I never got good grades in penmanship...
Dan, 5J
Old January 10th 20, 08:56 PM posted to rec.aviation.soaring
Vinyl lettering is great for large lettering (1/2" minimum and above, *MAYBE* 1/4"). But the very small lettering you might use on a panel is almost impossible getting the letters to release from the transfer tape and onto the panel without loosing a few in the process. Been there, done that.
Old January 11th 20, 12:52 AM posted to rec.aviation.soaring
Cookie
Yes, I sprayed a super light coat of clear "fixative". Plane has yet to fly, so not sure of how it holds up.....but many aircraft use this system.
Cookie
Doug
ASW 19 instrument panel Charles Longley Soaring 14 November 1st 17 07:47 AM
P-39 Instrument-Panel - P-39 Instrument-Panel.jpg ... Miloch Aviation Photos 0 June 26th 16 01:47 AM
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
