ventus c main wheel mudguard attachment
Old January 15th 20, 06:49 PM posted to rec.aviation.soaring
Martynas Bykovas
Default ventus c main wheel mudguard attachment
The reason i am installing fender is to minimise amount of debris.
Thought mudguard is appropriate word, sorry, i am not native english speaker.
Old January 15th 20, 08:43 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
speaker.
'fender; has a lot of meanings including a rope mat put between a boat
and a dock to avoid damage to the boat, the skirt-like thing on the front
of a railway locomotive and, mainly by Americans, the thin shaped sheet
metal or plastic part used to prevent a wheel from spraying water, mud or
gravel onto the rest of the vehicle. The rest of the english speaking
world calls the last item a mudguard, so call it whatever suits you best.
Martin | martin at
Gregorie | gregorie dot org
Old January 15th 20, 10:59 PM posted to rec.aviation.soaring
Dan Marotta
When I was growing up we called that thing a "cow catcher".
No worries about not being a native English speaker.Â* We understood.
Dan, 5J
Old January 15th 20, 11:08 PM posted to rec.aviation.soaring
So did we in NZ.
The use of 'fender' for a cow-catcher as something I found in a
dictionary. I also knew of 'fender' as a nautical term for both the rope
mat thing used between two ships of ship and wharf and for horizontal
chunks of wood mounted on piers and wharfs.
Martin | martin at
Old January 16th 20, 06:24 AM posted to rec.aviation.soaring
Chris Behm
Most vessel fenders are inflated plastic balls or cylinders with a line attached.
Rope mats are rarely used any more, even on tug boats.
Tugs generally have large used aircraft tires as fenders, or sometimes closely folded flaps of sheet rubber, attached around the bow, from one side to the other, like a giant piece of terrible tasting ribbon candy.
Regards,
Chris
Navy test range auxiliary vessel "Swiss Ladder-120
Old January 16th 20, 05:37 PM posted to rec.aviation.soaring
Dan Marotta
Old tires (tyres) work as boat fenders, too. ;-)
So did we in NZ.
Dan, 5J
Old January 16th 20, 05:49 PM posted to rec.aviation.soaring
Yep, been there, done that.
Using aircraft tyres is a new one for me, though.
Martin | martin at
WTB - used Cleveland 40-78B main wheel Roy B. Soaring 1 February 19th 18 08:25 PM
Ventus 2C main wheel inner tube. Short stem or long stem valve ? [email protected] Soaring 1 July 1st 14 06:07 AM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
main wheel dollies, plans? [email protected] Soaring 1 July 18th 07 06:55 AM
