ventus c main wheel mudguard attachment
Old January 13th 20, 03:29 PM posted to rec.aviation.soaring
Martynas Bykovas
Default ventus c main wheel mudguard attachment
Hello,
i plan to install mudguard on main wheel. I have mudguard itself but it is not clear how/what it should be exactly attached to.
I found wheel including mudguard drawings for cirrus however i doubt there is the same attachment principle for ventus c.
I would be grateful if someone could share wheel/suspension/mudguard drawings or pics.
BR,
Martynas
Old January 13th 20, 03:49 PM posted to rec.aviation.soaring
Scott Williams[_2_]
On Monday, January 13, 2020 at 9:29:53 AM UTC-6, Martynas Bykovas wrote:
Hello,
BR,
Martynas
I have pictures of a ventus A model gear, If it is the same.
Scott
Old January 13th 20, 04:04 PM posted to rec.aviation.soaring
Martynas Bykovas
Hello,
BR,
Martynas
Scott
I believe it should be the same.
Martynas
Old January 13th 20, 04:14 PM posted to rec.aviation.soaring
Martynas Bykovas
Hello,
BR,
Martynas
Scott
Thanks for the pictures Scott, - to my surprise ventus c (b) has different suspension. "H" shaped forks are not metal but glass fiber, also no shock absorber.
BR,
Martynas
Old January 13th 20, 04:55 PM posted to rec.aviation.soaring
Mike N.
Scott can you send pictures to me as well?
I was just looking at this on my Ventus C over the weekend.
Mikelleen AT gmail...
Old January 14th 20, 02:53 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Ventus B’s don’t have shock absorbers.
DC
Old January 14th 20, 03:15 PM posted to rec.aviation.soaring
Martynas Bykovas
DC
Yes, same as ventus c's.
BR,
Martynas
Old January 15th 20, 05:13 AM posted to rec.aviation.soaring
JS[_5_]
DC
BR,
Martynas
Not sure why you'd want to replace the "mud guard". From experience, if you land in a muddy field it jams the wheel. Best left out?
Old January 15th 20, 04:13 PM posted to rec.aviation.soaring
Scott Williams[_2_]
Hello,
BR,
Martynas
I think the fender would minimize dirt, gravel and other debris from being thrown up into the wheel well and underside of the fuselage, "mudguard"? I wonder if that nomenclature is just a translation expediency
Scott
Old January 15th 20, 06:49 PM posted to rec.aviation.soaring
Martynas Bykovas
The reason i am installing fender is to minimise amount of debris.
Thought mudguard is appropriate word, sorry, i am not native english speaker.
WTB - used Cleveland 40-78B main wheel Roy B. Soaring 1 February 19th 18 08:25 PM
Ventus 2C main wheel inner tube. Short stem or long stem valve ? [email protected] Soaring 1 July 1st 14 06:07 AM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
main wheel dollies, plans? [email protected] Soaring 1 July 18th 07 06:55 AM
