#11
True Oh Dan, but Tom has said that his Toshiba's 2 USB ports are broken...
At 16:31 01 March 2020, Dan Marotta wrote: USB portable DVDROM drives are cheap on-line as are USB to serial adapters.Â* I have and use both. On 3/1/2020 7:53 AM, Tom BravoMike wrote: On Sunday, March 1, 2020 at 5:45:04 AM UTC-6, Tim Newport-Peace wrote: At 19:40 29 February 2020, Tom BravoMike wrote: On Saturday, February 29, 2020 at 4:00:05 AM UTC-6, Tim Newport-Peace wrote= : I have a put copy at www.newportpeace.co.uk/temp/CONV-EWA.EXE =20 As Paul says, it has has problems because it wants Full-Screen mode and i= t is a 16-bit program and won't run on a on a 64-bit PC. =20 Both these problems can be solved by running under DOSBOX. =20 I have written notes on using DOSBOX for these 16-bit programs at: http://www.ukiws.demon.co.uk/GFAC/do...ithout_DLL.pdf =20 Share and enjoy! =20 =20 At 22:20 28 February 2020, Tom BravoMike wrote: I used it in the 1990s and still have a nice collection of flight logs which I cannot open to watch in the modern software. Don't have the=20 old EWView program. Anyone can help? Thanks in advance ... Thanks, Tim (and everyone who responded). The conv-ewa.exe file was what I = was looking for and couldn't find. Now that I've got it, as I am a lucky ow= ner of an old Toshiba laptop with Win98 system and broken both USB port and= CD drive, I'm trying to find a way to transfer the files to the laptop and= launch them. I will let you know when I succeed with the ewt-to-igc conver= sion, as there is one particular flight from 1997 I'm very curious to look = at, my shortest ever non-crash landing/roll-out on approx. 10 meters in a P= W-5. That souunds like hard work as you have to transfer your files in, convert them and then transfer out again and all without using CD or USB! Will your 64-bit PC boot from a USB stick (I have one that will and one that won't)? If it will, then go to https://rufus.ie/ and use Rufus to create a bootable USB drive, nothing to install. Now copy CONV-EWA.EXE and your EW file to the USB. You can now Boot from it and convert your files. Reboot you 64-bit PC and copy the files from the USB stick. If you cannot boot from USB, then download and install the DOSBOX App (it's free!) and follow the procedure in: http://www.ukiws.demon.co.uk/GFAC/do...ithout_DLL.pdf It all works, and I have tried it out. Tim. Thanks, Tim, sounds interesting and I will give it a try. The old Toshiba laptop is worth keeping anyway for some other old software, partly MS-DOS, and it's D-Sub RS232 port. The CD drive actually works but it's read-only. The 3.5" floppy drive is working OK and I have just ordered an external FDD for my modern PC (should arrive tomorrow, Monday) - who would think that I will be using the floppies again! I'm also trying to remember how the old laptop connected to the internet - can't find the RJ45 socket and not sure it has a Wi-Fi capacity. -- Dan, 5J |
Ouch, that would make it a fine target for a shot gun...
On 3/1/2020 10:52 AM, Tim Newport-Peace wrote: True Oh Dan, but Tom has said that his Toshiba's 2 USB ports are broken... At 16:31 01 March 2020, Dan Marotta wrote: USB portable DVDROM drives are cheap on-line as are USB to serial adapters.ÂÂ* I have and use both. On 3/1/2020 7:53 AM, Tom BravoMike wrote: On Sunday, March 1, 2020 at 5:45:04 AM UTC-6, Tim Newport-Peace wrote: At 19:40 29 February 2020, Tom BravoMike wrote: On Saturday, February 29, 2020 at 4:00:05 AM UTC-6, Tim Newport-Peace wrote= : I have a put copy at www.newportpeace.co.uk/temp/CONV-EWA.EXE =20 As Paul says, it has has problems because it wants Full-Screen mode and i= t is a 16-bit program and won't run on a on a 64-bit PC. =20 Both these problems can be solved by running under DOSBOX. =20 I have written notes on using DOSBOX for these 16-bit programs at: http://www.ukiws.demon.co.uk/GFAC/do...ithout_DLL.pdf =20 Share and enjoy! =20 =20 At 22:20 28 February 2020, Tom BravoMike wrote: I used it in the 1990s and still have a nice collection of flight logs which I cannot open to watch in the modern software. Don't have the=20 old EWView program. Anyone can help? Thanks in advance ... Thanks, Tim (and everyone who responded). The conv-ewa.exe file was what I = was looking for and couldn't find. Now that I've got it, as I am a lucky ow= ner of an old Toshiba laptop with Win98 system and broken both USB port and= CD drive, I'm trying to find a way to transfer the files to the laptop and= launch them. I will let you know when I succeed with the ewt-to-igc conver= sion, as there is one particular flight from 1997 I'm very curious to look = at, my shortest ever non-crash landing/roll-out on approx. 10 meters in a P= W-5. That souunds like hard work as you have to transfer your files in, convert them and then transfer out again and all without using CD or USB! Will your 64-bit PC boot from a USB stick (I have one that will and one that won't)? If it will, then go to https://rufus.ie/ and use Rufus to create a bootable USB drive, nothing to install. Now copy CONV-EWA.EXE and your EW file to the USB. You can now Boot from it and convert your files. Reboot you 64-bit PC and copy the files from the USB stick. If you cannot boot from USB, then download and install the DOSBOX App (it's free!) and follow the procedure in: http://www.ukiws.demon.co.uk/GFAC/do...ithout_DLL.pdf It all works, and I have tried it out. Tim. Thanks, Tim, sounds interesting and I will give it a try. The old Toshiba laptop is worth keeping anyway for some other old software, partly MS-DOS, and it's D-Sub RS232 port. The CD drive actually works but it's read-only. The 3.5" floppy drive is working OK and I have just ordered an external FDD for my modern PC (should arrive tomorrow, Monday) - who would think that I will be using the floppies again! I'm also trying to remember how the old laptop connected to the internet - can't find the RJ45 socket and not sure it has a Wi-Fi capacity. -- Dan, 5J -- Dan, 5J |
| Thread Tools | |
| Display Modes | |
| Boeing Model 40 pics 3 [3/4] - Model 40C Pilot's panel with some modern features added for safe operation.jpg (1/1) | Miloch | Aviation Photos | 0 | May 27th 19 04:20 PM |
| Lockheed Model 10 Electra pics 2 [2/8] - Flight deck of a Model 10A, which has been updated with a more modern instrument panel.jpg (1/1) | Miloch | Aviation Photos | 0 | February 7th 19 04:23 PM |
| Beechcraft Model 18 pics 2 [08/11] - Engineless Hamilton Westwind conversion at an airfield in Tennessee.jpg (1/1) | Miloch | Aviation Photos | 0 | February 5th 18 04:24 PM |
| Granville Brothers (Gee Bee) Model R pics [08/21] - Gee Bee Model E-Sportster.jpg (1/1) | Miloch | Aviation Photos | 0 | June 26th 16 05:11 PM |
| file conversion from .fil to .igc | Fred[_4_] | Soaring | 3 | May 21st 08 08:26 AM |
