Old EW Avionics Model B file (.ewt) conversion to .igc
Old February 28th 20, 10:20 PM posted to rec.aviation.soaring
Tom BravoMike
Default Old EW Avionics Model B file (.ewt) conversion to .igc
I used it in the 1990s and still have a nice collection of flight logs which I cannot open to watch in the modern software. Don't have the old EWView program. Anyone can help? Thanks in advance ...
Old February 29th 20, 08:13 AM posted to rec.aviation.soaring
Paul Candler[_2_]
I had the same problem some years ago, and found a copy of the
CONV-EWA utility. I think it was on the old EW (not EWavionics)
website, which is no longer there, not sure if it's available anywhere
else.
It's an old MS-DOS program, and it won't run on my 64-bit Windows7
PC, but luckily I had an old laptop kicking around that it would run on
and I converted all of my flights. I can send a copy if you like.
old
Old February 29th 20, 09:45 AM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
I have a put copy at www.newportpeace.co.uk/temp/CONV-EWA.EXE
As Paul says, it has has problems because it wants Full-Screen mode and it
is a 16-bit program and won't run on a on a 64-bit PC.
Both these problems can be solved by running under DOSBOX.
I have written notes on using DOSBOX for these 16-bit programs at:
http://www.ukiws.demon.co.uk/GFAC/do...ithout_DLL.pdf
Share and enjoy!
else.
old
Old February 29th 20, 11:23 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Sat, 29 Feb 2020 09:45:15 +0000, Tim Newport-Peace wrote:
Share and enjoy!
Are you the new Sirius Cybernetics Sales rep?
Martin | martin at
Gregorie | gregorie dot org
Old February 29th 20, 11:49 AM posted to rec.aviation.soaring
Share and enjoy!
And you will remember the Sirius Cybernetics Motto?
Old February 29th 20, 12:47 PM posted to rec.aviation.soaring
Share and enjoy!
Of course, especially after their new giant 3D version of the motto
partially sank under its own weight and read a little differently. At
least the complaints dept were first against the wall when the revolution
came.
I saw the stage version in the Hammersmith Odeon, which was wonderful.
Best Zaphod ever. Sadly, that was too late in the run to get a Pan-
galactic Gargle-blaster during the interval.
Martin | martin at
Old February 29th 20, 07:40 PM posted to rec.aviation.soaring
Tom BravoMike
Share and enjoy!
else.
old
Thanks, Tim (and everyone who responded). The conv-ewa.exe file was what I was looking for and couldn't find. Now that I've got it, as I am a lucky owner of an old Toshiba laptop with Win98 system and broken both USB port and CD drive, I'm trying to find a way to transfer the files to the laptop and launch them. I will let you know when I succeed with the ewt-to-igc conversion, as there is one particular flight from 1997 I'm very curious to look at, my shortest ever non-crash landing/roll-out on approx. 10 meters in a PW-5.
Old March 1st 20, 11:42 AM posted to rec.aviation.soaring
wrote=
=20
i=
t
=20
=20
=20
Share and enjoy!
=20
=20
logs
the=20
old
I
ow=
and=
and=
conver=
look
P=
W-5.
That souunds like hard work as you have to transfer your files in, convert
them and then transfer out again and all without using CD or USB!
Will your 64-bit PC boot from a USB stick (I have one that will and one
that won't)?
If it will, then go to https://rufus.ie/ and use Rufus to create a bootable
USB drive, nothing to install. Now copy CONV-EWA.EXE and your EW file to
the USB.
You can now Boot from it and convert your files. Reboot you 64-bit PC and
copy the files from the USB stick.
If you cannot boot from USB, then download and install the DOSBOX App (it's
free!) and follow the procedure in:
It all works, and I have tried it out.
Tim.
Old March 1st 20, 02:53 PM posted to rec.aviation.soaring
Tom BravoMike
wrote=
=20
i=
t
=20
=20
=20
Share and enjoy!
=20
=20
logs
the=20
old
I
ow=
and=
and=
conver=
look
P=
W-5.
that won't)?
the USB.
Tim.
Thanks, Tim, sounds interesting and I will give it a try. The old Toshiba laptop is worth keeping anyway for some other old software, partly MS-DOS, and it's D-Sub RS232 port. The CD drive actually works but it's read-only. The 3.5" floppy drive is working OK and I have just ordered an external FDD for my modern PC (should arrive tomorrow, Monday) - who would think that I will be using the floppies again! I'm also trying to remember how the old laptop connected to the internet - can't find the RJ45 socket and not sure it has a Wi-Fi capacity.
Old March 1st 20, 04:31 PM posted to rec.aviation.soaring
Dan Marotta
USB portable DVDROM drives are cheap on-line as are USB to serial
adapters.Â* I have and use both.
wrote=
=20
i=
t
=20
=20
=20
Share and enjoy!
=20
=20
logs
the=20
old
I
ow=
and=
and=
conver=
look
P=
W-5.
that won't)?
the USB.
Tim.
Dan, 5J
Boeing Model 40 pics 3 [3/4] - Model 40C Pilot's panel with some modern features added for safe operation.jpg (1/1) Miloch Aviation Photos 0 May 27th 19 03:20 PM
Lockheed Model 10 Electra pics 2 [2/8] - Flight deck of a Model 10A, which has been updated with a more modern instrument panel.jpg (1/1) Miloch Aviation Photos 0 February 7th 19 03:23 PM
Beechcraft Model 18 pics 2 [08/11] - Engineless Hamilton Westwind conversion at an airfield in Tennessee.jpg (1/1) Miloch Aviation Photos 0 February 5th 18 03:24 PM
Granville Brothers (Gee Bee) Model R pics [08/21] - Gee Bee Model E-Sportster.jpg (1/1) Miloch Aviation Photos 0 June 26th 16 04:11 PM
file conversion from .fil to .igc Fred[_4_] Soaring 3 May 21st 08 07:26 AM
