Glider Electronics Experiment #1 - electrical crosstalk demonstrated
Old May 2nd 20, 11:32 PM posted to rec.aviation.soaring
Default Glider Electronics Experiment #1 - electrical crosstalk demonstrated
On Saturday, May 2, 2020 at 9:41:54 AM UTC-4, Richard Livingston wrote:
Nice demo of cross talk. Last year I fixed a problem in our glider where the microphone wires were not completely shielded, as in your demo, and were picking up signal from the radio speaker wires, also not completely shielded. The result was intermittently the radio would squeal during transmit due to feedback from the speaker back into the microphone. It was intermittent due to the wires shifting slightly every time the canopy opened/closed. Shielding both the speaker and microphone wires fixed the problem.
Rich L.
Such feedback could only occur if the radio had the (mis)feature of echoing the signal from the mic to the speaker. Kind of lets you know you've got the PTT pressed and it's all working, but not really necessary. With that happening, you may also get acoustic feedback, from the speaker back into the mic, even without crosstalk in the wiring. Maybe that feature can be turned off somewhere in the radio's settings?
Old May 3rd 20, 12:25 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
where=
we=
shie=
transmit=
intermi=
opened/close=
=20
Rich L.
echoing=
got
that
t=
tu=
Many radios have this foldback feature for use with headsets and intercoms.
But yes, it could cause acoustic feedback. But this does not satisfactorily
account for the above fix.
What would seem more likely is that the poor sheilding has allowed
cross-talk from the antenna cable to the speaker cables which has allowed
the RF to feed back into the radio box where it caused meyhem. The speaker
does not need to be active for this to happen.
The section on supressing cross-talk is going to be interesting because
there are so many possible causes.
Tim.
Old May 3rd 20, 02:13 PM posted to rec.aviation.soaring
Richard Lancaster[_2_]
Experiment #2 is just going to look at the effect of cable type on the type of noise seen in experiment #1.
Experiment #3 on-wards, if I manage to keep making them, will look at other types of noise.
Best regards,
Richard
Old May 3rd 20, 03:49 PM posted to rec.aviation.soaring
Nicely done.
Old May 3rd 20, 04:49 PM posted to rec.aviation.soaring
Richard Livingston
Rich L.
That's called the "sidetone", and many radios have an adjustment for that. It is also possible (likely even) that the feedback was from the RF back into the microphone wires. Connectors are notoriously leaky, and even coax can leak a little bit. If that RF signal gets into the microphone input it can be rectified by the transistors in the amplifier and produce feedback that will cause a squeal.
Rich L.
Old May 4th 20, 02:07 AM posted to rec.aviation.soaring
2G
Best regards,
Richard
I would suggest one mo the effect of ground distribution, especially single-point commons, on noise.
Tom
Old May 4th 20, 01:39 PM posted to rec.aviation.soaring
Stephen Szikora
I blame the noise in my cockpit on my choice of lunch.
Electrical continuity of control linkages and electrical instruments son_of_flubber Soaring 7 June 26th 15 05:09 PM
an interesting in flight experiment a[_3_] Piloting 58 October 24th 09 03:20 PM
Glider electronics for sale NXS Soaring 4 July 19th 05 01:40 PM
A small experiment Mike Borgelt Soaring 16 May 6th 05 07:41 AM
