an interesting in flight experiment
Old October 17th 09, 06:52 PM posted to rec.aviation.piloting
a[_3_]
Default an interesting in flight experiment
Next time you're at altitude and in cruise mode, switch from 'both' to
a single bank of spark plugs. It will remind you what happens should
you have one side decide to go in/op when in flight. I had the engine
(IO 360) go rough a couple of weeks ago, but rough was a lot better
than the very smooth and silent effects the left mag only gave me.
Old October 17th 09, 08:01 PM posted to rec.aviation.piloting
Peter Dohm
"a" wrote in message
Sounds like at least two problems--unless the fault was in the switch.
Peter
Just a thought
Old October 17th 09, 08:35 PM posted to rec.aviation.piloting
a[_3_]
... Next time you're at altitude and in cruise mode, switch from 'both' to
Peter
Just a thought
Nope. Engine went rough, stayed just as rough on the right bank, too
quiet on the left. After the repair all was well
again.
Even on run up you lose some RPMs when on a single bank of spark
plugs.
Old October 17th 09, 10:30 PM posted to rec.aviation.piloting
Jon Woellhaf
... Even on run up you lose some RPMs when on a single bank of spark
plugs.
If you don't get an rpm drop when running on a single mag, something's
probably amiss. My engine has never run rough during a mag check, except
when I forgot to lean aggressively before taxi and got lead fouling.
Old October 19th 09, 05:34 PM posted to rec.aviation.piloting
Ross
plugs.
Long ago I had rented a C=150 that the run up mag check was fine before
a return flight back to the home airport (about 1 hour flying). All of a
sudden in cruise the engine was running rough. I did a mag check, on one
side was rough and the other side smooth. I elected to run on one mag
that was good and squawked the aircraft upon landing.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old October 19th 09, 08:02 PM posted to rec.aviation.piloting
jan olieslagers[_2_]
Ross schreef:
I ... squawked the aircraft upon landing.
Ross, what do you mean by "squawking a plane upon landing?"
I only know the verb in a transponder context.
Old October 19th 09, 01:09 AM posted to rec.aviation.piloting
Brian Whatcott
plugs.
Usually. At a 1700 rpm run up this morning, - I couldn't find a
drop either side. So I did a dead cut (at 1200rpm) with the usual effect.
Brian W
Old October 18th 09, 02:06 PM posted to rec.aviation.piloting
twdeckard
This test should be part of the run-up pre-flight check.
You are verifying that the P-lead correctly grounds the magneto (by
observing the drop)
and that the firing side is operational. You are also, of course, verifying
that the engine will run on the ungrounded side (and that it is firing that
entire bank of spark plugs by scrutinizing how well it runs).
I am sure you know all of this (grin), I just chimed in becuase its a check
best done on the run-up pad.
Todd
"Peter Dohm" wrote in message
Peter
Just a thought
Old October 18th 09, 02:11 PM posted to rec.aviation.piloting
Morgans[_2_]
check best done on the run-up pad.
He did not say you shouldn't do it at run-up. He was just pointing out
that your engine could run very rough if you lose one side while cruising.
Old October 18th 09, 03:30 PM posted to rec.aviation.piloting
twdeckard
I didn't mean the post to sound too pedantic. I guess I reacted to the OP
phrasing it as a question or a suggestion. I am sure it was rhetorically so
"Morgans" wrote in message
Interesting and different flight on OLC Dave Nadler Soaring 2 August 4th 09 01:06 PM
Solar Flight Much more interesting than Hilarious Video Richard[_1_] Soaring 0 December 5th 08 04:07 PM
Interesting 2-plane takeoff at BWI 4-28-06 (formation flight) Gary G General Aviation 2 May 1st 06 08:42 PM
An interesting trial flight attempt... [email protected] Soaring 35 February 12th 06 07:31 PM
A small experiment Mike Borgelt Soaring 16 May 6th 05 06:41 AM
