#11
![]() "W P Dixon" wrote in message: Nothing About Electronics...I can relate. That is one reason I want to experiment with building some things such as a radio. To get a better understanding of them. This is jumping into the deep end like you wouldn't believe..8-) A better hack at some first time projects would be something around audio frequencies or so. Better probability of success and likely something you can actually use and enjoy. I am not trying to discourage you at all. But there's a reason that there are so few "really good" RF guys around - they live in a different world from the vast majority of day-to-day grunts who are product designers/EE's cranking out widgets for the masses. I was involved in product development for more than 25 years and still hold purely "analog" guys (and "RF guys" in particular - as a subspecies of the analog types) with some degree of suspicion 8-)... and a fair amount of awe. You have to love it apparently, and you have to really bust your nuts to master it. But - it ain't "rocket science". It's "radio science". I don't know which is worse...8-)............. I'm starting to dabble in it a little 'cause I don't have anything better to do - and because I've probably already gotten as "twisted" as possible - and this can't make it worse. YMMV - and it *will* - I promise...8-)..... |
Hey, thanks for the kudos! (I'll take anything I can get). I just (as in
2 weeks ago) quit my job with Hewlett Packard/Agilent, where I was a Senior RF/Microwave engineer. I've been in the field for 25+ years, and now it's time to be an A&P. I've been through the FCC, FAA, TSO, PMA hastle, and would second the idea that a transciever is not the medium for learning electronics (at least not if you really intend to transmit with it). Decades ago RF design was slide rules and Smith charts, but it has devolved to "plug and play" modules that any EE can make sing together. The day of the 10 picofarad calibrated wet finger is dead,(your finger may vary) or at least on it's last legs. But by gum, if it interests you, do it! The world need inventive, curious people just as it alsways has! Netgeek wrote: "W P Dixon" wrote in message: Nothing About Electronics...I can relate. That is one reason I want to experiment with building some things such as a radio. To get a better understanding of them. This is jumping into the deep end like you wouldn't believe..8-) A better hack at some first time projects would be something around audio frequencies or so. Better probability of success and likely something you can actually use and enjoy. I am not trying to discourage you at all. But there's a reason that there are so few "really good" RF guys around - they live in a different world from the vast majority of day-to-day grunts who are product designers/EE's cranking out widgets for the masses. I was involved in product development for more than 25 years and still hold purely "analog" guys (and "RF guys" in particular - as a subspecies of the analog types) with some degree of suspicion 8-)... and a fair amount of awe. You have to love it apparently, and you have to really bust your nuts to master it. But - it ain't "rocket science". It's "radio science". I don't know which is worse...8-)............. I'm starting to dabble in it a little 'cause I don't have anything better to do - and because I've probably already gotten as "twisted" as possible - and this can't make it worse. YMMV - and it *will* - I promise...8-)..... |
Thanks for all the advice. I know it is probably beyond my electronic
capability but it sure is something I may try later on. I'll start out with Jim Weir's Magneto Timer Kit and do some more projects that I may have use for and just get alot of practice in. Who knows, before I die I may actually build a decent radio ! ![]() that may be a good learning experience for me? Of course things for my plane or tools/testers are of interest. I have no desire to build a robot or crawling thingamybob. ![]() Patrick student SPL aircraft structural mech |
![]() "W P Dixon" wrote in message ... Jim, Is it practical, possible and legal to build a radio for your own homebuilt airplane? I can't see paying 1000 bucks for a panel mount unit for a volksplane. -- Patrick Dixon student SPL aircraft structural mech Patrick, For many reasons a homebuilt aircraft radio is a basket of worms best left unopened. The cheapest and easiest solution is a standard hand held aircraft transceiver. They can be purchased for a couple of hundred bucks and work well. Especially if you provide them with an external antenna. A number of the guys around here have purchased the radio and the optional alkaline battery holder. It is just a plastic box that fits onto the radio so it is pretty cheap. Then they cut the bottom off the box just leaving the attachment part with the contacts the make the connection from the batteries to the radio. They wire this into the airplane on the panel so they can see the face of the radio and punch the buttons when the radio is slid onto the adaptor. Then they plug in the aircraft antenna with the appropriate BNC or other antenna connector and they have an FCC certified "panel" mount radio for their homebuilt. Works great and is a lot cheaper than a regular panel mount. Plus, you can disconnect the antenna BNC and slide the radio off the adaptor on the panel and reconnect the rubber duckie and the original battery and use it as a handheld as well. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
![]() "W P Dixon" wrote in message: Thanks for all the advice. I know it is probably beyond my electronic capability but it sure is something I may try later on. For lots of folks kits are sometimes a great way to get started. You might be interested in something like this: http://www.ramseyelectronics.com/cgi...ction&key=AR1C It's a pretty straightforward little airband receiver (single conversion, manual/varactor tuning). It's cheap and hard to go wrong. There's also *plenty* of room for improvements and customization while you're learning and experimenting 8-)... You'll instantly learn about the value of an antenna and what phrases like "selectivity" mean. There are many small mods you can make and - even if you manage to toast it - easy to fix and you're only out a few bucks anyway. When you get bored with it you can stick it out in your garage or workshop and listen to the local traffic - not *really* exciting, but beats listening to "elevator music"...........8-) Beyond that - there are *zillions* of widgets, tools and doodads you can build (Jim's being among some of the more useful, BTW)... Bill |
![]() "Rip" wrote in message: Hey, thanks for the kudos! (I'll take anything I can get). I just (as in 2 weeks ago) quit my job with Hewlett Packard/Agilent, where I was a Senior RF/Microwave engineer. Wow! So - you must be *really* weird by now??! 8-)..... snip Decades ago RF design was slide rules and Smith charts, but it has devolved to "plug and play" modules that any EE can make sing together. Those days are coming back. All the semiconductor makers are obsoleting those "plug and play" modules so it's back to buckets of discrete components if you really want to build something (and can't afford custom silicon). Hmmmm.....I predict a lucrative second career for you as a consultant if you want to stay in the game 8-) The day of the 10 picofarad calibrated wet finger is dead,(your finger may vary) or at least on it's last legs. I always thought I could make a fortune if I could come up with a solid state "finger simulator" - you know - something you clip on to the rabbit ears so the family doesn't have to argue about who gets to stand beside the TV and hold the damn things...8-) Everyone would want one!!! Then along comes cable... sigh... Bill |
"Netgeek" wrote in
: "W P Dixon" wrote in message: Thanks for all the advice. I know it is probably beyond my electronic capability but it sure is something I may try later on. For lots of folks kits are sometimes a great way to get started. You might be interested in something like this: http://www.ramseyelectronics.com/cgi...ction&key=AR1C It's a pretty straightforward little airband receiver (single conversion, manual/varactor tuning). It's cheap and hard to go wrong. There's also *plenty* of room for improvements and customization while you're learning and experimenting 8-)... You'll instantly learn about the value of an antenna and what phrases like "selectivity" mean. There are many small mods you can make and - even if you manage to toast it - easy to fix and you're only out a few bucks anyway. When you get bored with it you can stick it out in your garage or workshop and listen to the local traffic - not *really* exciting, but beats listening to "elevator music"...........8-) Beyond that - there are *zillions* of widgets, tools and doodads you can build (Jim's being among some of the more useful, BTW)... Bill I assembled one of these several years ago. Your right about the customization. It started by hooking the my o-scope's horizontal to the tuning pot and rapidly swinging it through it's range, while listening, and watching the audio on the vertical. I then could mark the known frequencies around the pot's knob. OK, it's not extremely precise, but it sure did show where the activity was. I then made a simple sawtooth generator to drive the varicap, and the scope's horizontal input, and schazam!...an "aircraft band spectrum analyzer". (I live less than 2 miles out on the approach end of 12R at MSP.) |
![]() Ron Natalie wrote: Vaughn wrote: Practical? No. I have been in the radio business all my life and I would not even consider it, probably not even a kit. Possible? Yes. Legal? I don't think so. Back a long time ago, in the first incarnation of RST, Jim actually did have a kit radio. The "legality" was dealt with by sending the radio off to RST after you finished building it for it's test and alignment stage. Jim has felt the market out for radios again a few times over the years, but it's a hard market. Frankly, what I suggested to him maybe 10 years ago, and I think would still be intersting in pursuing is to have a com radio unit where the radio parts were preassembled/certificated but with no real user interface parts, just a digital interface of some sort that avionics hackers could integrate with their own electronic panel. Use a portable. Fasten it on the side of your cockpit and use a headset. I have flown gliders for hundreds of hours with a tiny portable on a light lanyard around my neck, but that may not work well over engine noise. I ferried my Navion around (it was between having the new panel cut at one shop and the radios installed at another) with my headphones, a portable intercom and my Yazoo handheld. Worked passably (would have been better with a real antenna rather than the rubber coated dummy load), but such would work well in a homebuilt. Cabin noise you fix with a headset. The bigger problem with a lot of these small planes is ignition noise. That can lay waste to the AM signal in any radio. ************************************************** ********************************** Ron; Back in 1983 I built one of RST's 360 Nav / Com radios. It was a fun job with over 1000 parts on 9 circuit boards,as I remember. I sent it back for calibration/certification and they found I had a couple of diodes installed backward - otherwise OK. I flew our Rv-4 for 700 hours with it and a Communications Specialists handheld, with a slide-in can and connections for power and antenna and wired into my intercom. Bob Olds RV-4 Charleston,Arkansas ************************************************** ********************************** |
![]() "W P Dixon" wrote in message ... Jim, Is it practical, No. possible Yes. and legal Yes. to build a radio for your own homebuilt airplane? I can't see paying 1000 bucks for a panel mount unit for a volksplane. You will spend a thousand hours designing such a device and ten thousand dollars testing and certifying it.. But it IS possible. Jim |
That definitely seems to be the popular answer Jim. Thanks for your input.
May try the handheld contraption in my volksplane. Just would not want an expensive radio in it . Now the Thatcher CX4 on the other hand ![]() Patrick student SPL aircraft structural mech |
Jim Weir article question | John S | Home Built | 0 | April 20th 05 04:38 AM |
AutoGas question.. Jay Honeck, Jim Weir.. others.. | Dave S | Owning | 32 | November 11th 04 10:04 PM |
Question for Jim Weir | Ed Sullivan | Home Built | 9 | September 21st 04 11:45 AM |
Avionic question for Mr. Jim Weir | Henning DE | Home Built | 4 | September 19th 04 09:07 AM |
Inverter question for Jim Weir | B2431 | Home Built | 35 | February 27th 04 09:28 PM |
