Jim Weir article question
Old April 20th 05, 04:38 AM
John S
Default Jim Weir article question
Dear Jim:
In your June 2002 Kitplanes article on soldering BNC connectors, I came to a
dead end at step 7. The clamp isn't mentioned until step 7. I don't
understand how to wrap the braid around and over the clamp--which apparently
goes on after soldering the pin to the center conductor and flaring the
braid to 90 degrees--and get it to touch the black sheath jacket. If you
put the clamp on after soldering the pin, the only way you can wrap the
braid over the clamp is by pulling it towards the cut end, over the clamp,
and there isn't any black sheath jacket in that direction. Can you clarify
this step? Thanks
John
Jim Weir - PTT switch article? Corrie Home Built 2 October 4th 04 04:46 PM
Question for BUFDRVR Keith Willshaw Military Aviation 3 August 6th 04 10:33 AM
Tiedown Stakes (Article in SportAv.) Jim Weir Home Built 34 April 24th 04 01:21 AM
Headset connections (attn: Jim Weir) Bruce Home Built 5 April 20th 04 03:56 PM
Inverter question for Jim Weir B2431 Home Built 35 February 27th 04 09:28 PM
