That is ABSOLUTELY false. Did you really READ 61.51(e) or did you simply
parrot somebody that you didn't check for accuracy? 61.51 lists a whole LOT of folks that can log PIC time. Your scenario isn't among them. Suggest that you READ rather than QUOTE. Jim FAR 61.51(e) describes who can log PIC time. In the case of a simulated instrument flight, both the pilot under-the-hood (sole manipulator of the controls) and the safety pilot (required crewmember on a flight requiring more than one pilot, such as a simulated instrument flight) can log PIC at the same time. Charles. -N8385U |
![]() "Slick" wrote in message ... I've only ever flown Cessna products and I've come across an area I'm not sure about. I have my private and I have flow 150/2 and 172's since I starting my training. Now I might partner up with a guy in a Tomahawk next weekend for a tour across the state. I don't have any formal training in any Piper products, will I be allowed to log any stick time? I don't recall exactly how the regs layout type certification. Do I have to be signed off and have logged instruction to be PIC in the Tomahawk? Also if I only had time in a 150, would I have to have instruction in a 152 before I could log PIC? One last question, If I fly simulated instrument with a safety pilot, does the safety pilot have to sign my logbook? Thanks to everyone for your help and response. On Sat, 30 Apr 2005 09:09:33 -0700, "BTIZ" wrote in Z4Oce.113$fI.16@fed1read05:: No Dumb Questions.. just hard to interpret Regs.. You are qualified for Airplane Single Engine Land... a Tomahawk is an Airplane Single Engine Land.. With the exception of those aircraft that require the pilot to have a Type Rating, airmen holding a private ASEL certificate may act as PIC of any aircraft certified in that category and class. any time you have hands on stick.. that is PIC.. All time spent as sole manipulator of the controls is logable as PIC time. PIC time is also logable by the pilot who is acting as the responsible PIC, IINM. as far as the FAA is concerned.. you don't need a specific sign off.. Other than for those aircraft that require a Type Rating. the insurance companies or rental FBO may have other ideas... specific make and model sign offs are insurance company requirements.. If you are under the hood and have a rated pilot acting as a safety pilot, then all you need is his name.. any time you are flying with hands on stick, with or without the hood, you are PIC, any time you are under the hood, he may log PIC (acting pic) even though he may never touch the stick. I believe the safety pilot usually logs SIC time in that situation, but it would depend on who the pilots agreed would be responsible for the flight. I copied this out of a magazine several years ago when I was often flying with another pilot: Cockpit Resource Management CRM is the effective use of all resources - hardware, software, leadership, and humanware - to achieve safe and efficient flight operation. Don't divide duties as they are on most airlines. There, the pilot becomes too dependent on a copilot, because the pilot simply flys the aircraft, while the copilot does everything else - radios, navigation, checklists, and backing up the pilot as to proper altitudes and headings. The CRM philosophy puts the onus on the pilot for communications, checklists, and decision making. Decisions are based on the concerns of the less comfortable pilot. The copilot handles navigation, cross-checks the pilot's communication and navigation frequencies for an instrument approach, and assures that the altitude requirements are met at the final approach fix and at minimums. The copilot still has plenty to do, managing the aircraft's loran, RNAV radio, or handheld GPS moving map display that is used as a backup. In addition, the copilot scans for other traffic, keeps a running check on fields in which to land - just in case - and keeps track of the nearest airport. The copilot knows s/he is to support and backup the pilot and offer help in emergency situations. Pre-takeoff briefing is important for any flight; it can be abbreviated, however, when another pilot is aboard. It can be as simple as thinking out loud. If you expect the other pilot to help with the flight, say so before takeoff. Spend several minutes before the flight explaining to the non-pilot passenger how to control the aircraft and how to communicate. Once in the air, spend a few minutes letting the passenger fly. It is fun for the passenger and gives the pilot another resource to use in case of a medical emergency. |
![]() "BTIZ" wrote in message news:Z4Oce.113$fI.16@fed1read05... No Dumb Questions.. just hard to interpret Regs.. Nothing difficult at all. You simply need to READ them. You are qualified for Airplane Single Engine Land... a Tomahawk is an Airplane Single Engine Land.. And unless the Traumahawk is covered by one of the six execeptions of the regulations, you are good to go. HOWEVER, it is clever to prove to yourself that you don't fall into one of the exceptions. any time you have hands on stick.. that is PIC.. That is absolutely not true. If I ask my kid to hold onto the wheel while I find the extra batteries, that does NOT make her the PIC. PIC is not only a state of mind, it is a legal definition. If you are a certificated pilot and I ask you to fly along with me as the PIC, I can ask you to fly the airplane from Sacramento to Salt Lake while I sleep and I am still the PIC. No matter that you flew the whole route, I am the PIC and am responsible for the flight. When the fit hits the shan, the determination will be made as to who was the PIC. It is NOT necessarily the person with their hands on the controls. If you are under the hood and have a rated pilot acting as a safety pilot, then all you need is his name.. I'm sure my CFI-I Betty wouldn't appreciate that comment. any time you are flying with hands on stick, with or without the hood, you are PIC, Absolutely not true, as noted above. any time you are under the hood, he may log PIC (acting pic) even though he may never touch the stick. Absolutely not true. Jim |
![]() "RST Engineering" wrote in message ... "BTIZ" wrote in message news:Z4Oce.113$fI.16@fed1read05... No Dumb Questions.. just hard to interpret Regs.. Nothing difficult at all. You simply need to READ them. Maybe you should read them... You are qualified for Airplane Single Engine Land... a Tomahawk is an Airplane Single Engine Land.. And unless the Traumahawk is covered by one of the six execeptions of the regulations, you are good to go. HOWEVER, it is clever to prove to yourself that you don't fall into one of the exceptions. I guess you don't know what a Tomahawk is but what 6 exceptions do you refer to? any time you have hands on stick.. that is PIC.. That is absolutely not true. If I ask my kid to hold onto the wheel while I find the extra batteries, that does NOT make her the PIC. PIC is not only a state of mind, it is a legal definition. If you are a certificated pilot and I ask you to fly along with me as the PIC, I can ask you to fly the airplane from Sacramento to Salt Lake while I sleep and I am still the PIC. No matter that you flew the whole route, I am the PIC and am responsible for the flight. When the fit hits the shan, the determination will be made as to who was the PIC. It is NOT necessarily the person with their hands on the controls. please re read 61.51(e)(1)(i).. sole manipulator in an aircraft that he is rated in.. may log PIC.. even if you think he is not ACTING PIC.. because you, the PIC, is sleeping and think you are in charge. If you are under the hood and have a rated pilot acting as a safety pilot, then all you need is his name.. I'm sure my CFI-I Betty wouldn't appreciate that comment. generic "his",, get real.. any time you are flying with hands on stick, with or without the hood, you are PIC, Absolutely not true, as noted above. re read 61.51(e)(1)(i) as noted above... any time you are under the hood, he may log PIC (acting pic) even though he may never touch the stick. Absolutely not true. re read 61.51(e)(1)(ii) as reported in another post... Jim BT |
![]() Maybe you should read them... I've been reading them...and teaching them for over forty years. And you? I guess you don't know what a Tomahawk is but what 6 exceptions do you refer to? I expect that I've got more PIC hours in Tomahawks than you have total. Something on the order of 900 hours. You, sir? please re read 61.51(e)(1)(i).. sole manipulator in an aircraft that he is rated in.. may log PIC.. even if you think he is not ACTING PIC.. because you, the PIC, is sleeping and think you are in charge. Let's take this to another thread, one on point. You have the same misguided interpretation that a lot of pilots have. It may be informative to the group to clear this up once and for all. generic "his",, get real.. Sexist pig. Get into this century. any time you are flying with hands on stick, with or without the hood, you are PIC, Absolutely not true, as noted above. re read 61.51(e)(1)(i) as noted above... Reread the WHOLE of 61.51 and get a life.... Jim |
BTIZ wrote:
"RST Engineering" wrote in message That is absolutely not true. If I ask my kid to hold onto the wheel while I find the extra batteries, that does NOT make her the PIC. PIC is not only a state of mind, it is a legal definition. If you are a certificated pilot and I ask you to fly along with me as the PIC, I can ask you to fly the airplane from Sacramento to Salt Lake while I sleep and I am still the PIC. No matter that you flew the whole route, I am the PIC and am responsible for the flight. When the fit hits the shan, the determination will be made as to who was the PIC. It is NOT necessarily the person with their hands on the controls. please re read 61.51(e)(1)(i).. sole manipulator in an aircraft that he is rated in.. may log PIC.. even if you think he is not ACTING PIC.. because you, the PIC, is sleeping and think you are in charge. Your confusion is between "being the PIC" and "logging PIC time". They aren't synonymous. You can log PIC during times that you aren't the pilot in command of the flight. Matt |
![]() RST Engineering wrote: If you are under the hood and have a rated pilot acting as a safety pilot, then all you need is his name.. I'm sure my CFI-I Betty wouldn't appreciate that comment. Jim Jim... Instruction is logged with an endorsement by the instructor. Safety Pilot just requires recording of the name.. (and that means it can be in anyone's handwriting). Chapter and verse below. I am presuming you are contesting the signing versus recording of the name, not the gender issue you also seem to be alluding to. Dave 61.51.g.3.ii (3) For the purposes of logging instrument time to meet the recent instrument experience requirements of §61.57(c) of this part, the following information must be recorded in the person's logbook— (i) The location and type of each instrument approach accomplished; and (ii) The name of the safety pilot, if required. 61.51.H.2.i (h) Logging training time. (1) A person may log training time when that person receives training from an authorized instructor in an aircraft, flight simulator, or flight training device. (2) The training time must be logged in a logbook and must: (i) Be endorsed in a legible manner by the authorized instructor; and |
![]() BTIZ wrote: If you are under the hood and have a rated pilot acting as a safety pilot, then all you need is his name.. any time you are flying with hands on stick, with or without the hood, you are PIC, any time you are under the hood, he may log PIC (acting pic) even though he may never touch the stick. BT This is a NIT-pick but its an IMPORTANT one.. The Safety pilot is considered a required crew-member and under that role is considered Second In Command or SIC. So he can log it as SIC. If the pilot-flying (hood pilot) AND the Safety Pilot BOTH agree that the Safety Pilot "IS" the "Pilot in Command" for the period the pilot-flying is under the hood, THEN the safety pilot can log it as PIC. You need to agree beforehand. This is usually not of consequence UNTIL or UNLESS something goes wrong: you break or bend something, the plane busts airspace, a near-midair occurs and is reported.. etc.. That can expose the Safety Pilot to accountability as the PIC. Reality is.. the hood pilot and the safety pilot both log and claim PIC.. just understand what the implications are when you do it. Dave |
It IS a nit-pick, and an important one.
The pilot under the hood can log PIC time and the safety pilot can log second in command time. The safety pilot can log PIC time and the pilot under the hood can log second in command time. They CANNOT BOTH LOG PIC time at the same time. Jim This is a NIT-pick but its an IMPORTANT one.. |
They CANNOT BOTH LOG PIC time at the same time. under which regs? if you mean good ol' FAA, then you are wrong; --Sylvain ps actually, I once was in a flight where three of us did log PIC time *at the same time* and perfectly legally: exercice to the readers: describe the situation :-) |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Dumb Transponder Question! | John P | Owning | 2 | March 30th 04 01:26 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Dumb Canard Question. | Russell Kent | Home Built | 39 | October 19th 03 03:25 PM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
