Dumb Canard Question.
Old October 7th 03, 04:44 PM
Steven Johansen
Default Dumb Canard Question.
Why are many Canard designs (Cozy , Eze's etc)
parked with their noses resting on the ground?
Is it simply to reduce wear on the Nose gear or
for a more esoteric reason?
Cheers
Steven
Old October 6th 03, 11:51 PM
Juan Jimenez
With the nose on the ground it becomes almost impossible for anything but a
near-tropical-storm-force gust of wind (or higher) to move the airplane.
"Steven Johansen" wrote in message
. au...
Cheers
Steven
Russell Kent
The reason is because on those designs the static Cg is only
slightly ahead of the main landing gear. Without the pilot aboard
there is a very real risk that a gust of wind will tip the
aircraft back onto its butt. Collapsing the nose gear when parked
shifts the Cg forward.
The next question you're going to ask is "why don't the builders
move the main landing gear aft?" Two possible reasons: moving the
gear aft might make unsticking/rotation on takeoff a much too
exciting event (think uncontrolled stall on takeoff), and the main
gear has a tendency to throw up runway debris which we'd rather
not have pass through the propeller disk.
Russell Kent
Old October 7th 03, 12:25 AM
Bill Daniels
"Russell Kent" wrote in message
Snip---------
Russell Kent
So, why doesn't some clever builder make the main gear swing back when the
parking brake is set and swing forward again when the pilot is in the
cockpit and the brake released?
That would solve a lot of problems with small pushers.
Bill Daniels
Old October 7th 03, 12:39 AM
Morgans
"Bill Daniels" wrote in message
k.net...
Snip---------
Russell Kent
Bill Daniels
Three reasons.
Weight, weight, and weight.
Why not do what they have been doing, and not add 1 extra ounce?
Beats me!
Old October 7th 03, 07:26 AM
Corrie
"Bill Daniels" wrote in message nk.net...
Because smart designers and builders follow Kelly Johnson's credo:
"simplicate and add lightness."
Old October 7th 03, 05:55 AM
Paul Lee
Another may be that if main gear is moved aft a more heftier
front NG would be needed. Keeping most of the load on main gear keeps
the cost down.
Dont know why cozy's, MK IV, etc. don't spread the main gear more.
The main RG on my SQ2000 is 11' apart with little chance of
throwing debris on the 66" prop.
Paul Lee, SQ2000 canard project: www.abri.com/sq2000
Russell Kent wrote in message ...
............................ "why don't the builders
Russell Kent
Old October 7th 03, 01:49 AM
Del Rawlins
On 07 Oct 2003 07:44 AM, Steven Johansen posted the following:
snip
Steven, you ever spend any time in Cordova, AK? If not, then never mind,
'cause in that case I am remembering someone else.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old October 7th 03, 04:41 PM
John Ousterhout
On Tue, 7 Oct 2003 08:44:24 -0700, "Steven Johansen"
They are all pointed towards Mojave and bowing to worship Burt Rutan.
- J.O.-
Old October 7th 03, 06:46 PM
sean trost
ahkbar rutan !
kif, kif yer killing me....
Sean nyuk,nyuk Trost
- J.O.-
wing root strakes (not canard A/C) Wallace Berry Home Built 0 October 2nd 03 08:47 PM
question about EZRocket David O Home Built 6 October 1st 03 06:03 PM
virgins (was: Question - Regarding Canard Pushers...) RobertR237 Home Built 1 August 10th 03 11:06 PM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 11:07 AM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
