for the amateur meteorologists, question.
Old October 22nd 20, 10:24 AM posted to rec.aviation.soaring
Default for the amateur meteorologists, question.
Le jeudi 22 octobre 2020 Ă* 08:33:03 UTC+2, krasw a Ă©critÂ*:
On Thursday, 22 October 2020 at 03:41:13 UTC+3, Waveguru wrote:
Waves aren't always generated by hills or mountains, sometimes the air bounces off of another air mass.
Boggs
Waves form in stable layer, convection in neutral layer. Hard to imagine you could connect with wave 1000ft agl and same time have cu clouds passing above.
My dear friends,
The answers to most of your questions (or doubts) are printed in the book “Dancing With the Wind”, for sale in the on-line shops (Cumulus-Soaring, Wings & Wheels, www.topfly.aero).
Including a lot of historical data regarding US pilots and others.
All the best, take care!
Old October 22nd 20, 12:50 PM posted to rec.aviation.soaring
On Monday, October 19, 2020 at 3:22:11 PM UTC-4, john firth wrote:
Maybe the last flight of the year, but memorable.
Atmosphere 10C, very unstable , with cloudbase 5000ft and tops above 10K; showers, wind W 15kt @ 1000ft.
climbed to 4000 (airspace limit) over the airfield ; flew upwind along a cloud street, holding 4000ft.
Street ended after 10 miles , then strong sink for 5 miles ending under a large cu.; at 1200 AGL
found zero sink but little more. Started circling but losing slowly, expecting to find real lift,
but probing found nothing better. Considered starting the engine, but that is admitting defeat too
early, with good fields below; and so I circled in smooth air and drifted, gaining 100 and losing it.
Clouds 4000 ft above drifted past.
Have faith! Unstable air has to get it together and accelerate; the fields drifted steadily
by underneath, in the weak October sunshine, interspersed with large woods, .
This went on for a long time, round and round, airfield unreachable even downwind.
( would I ever contemplate a 15 kt downwind landing? only as a life saver)
and so after 40 mins, still at about 1000 AGL, I see a dual lane highway, the airfield a mile beyond.
surprise! I can reach the airfield; after another couple of circles, I abandon the "thermal" and immediately hit 2 kts. End of suspense. I had drifted 14 miles at 1000ft in 50 mins doing 120 circles.
Now for the question: how does a parcel of air over 600ft diameter maintain a steady ascent
of 150 fpm for nearly an hour without either breaking away or dissipating.. This was not a donut
as there was no central core. It must have been replenished from below.
Any similar experiences?
Have a well socially distanced winter!
John Firth (PIK 20E)
John, the unusual pattern of what we called flatland wave has been experienced a few times here in Florida. In 1983 Bennie Flowers and myself flew at least two of these occurrences during a few weeks span. I was able to gather some good information on the weather conditions for one particular flight which included satellite photographs. Our late friend Harry Senn assisted in gathering and analyzing the information. On one particular flight Bennie and I rode this wave to about 25 miles offshore on the East Atlantic coastline, we could have easily made the Bimini. May1983, Soaring magazine, Catching A Florida Wave.
The lift started below the cloudbase and we flew between these strange lines or rows of clouds that looked like a long loaf of bread with about two or three miles between each cloud, as I recall the cloudbases were only about 3K AGL and we rode the wave to well over 10K AGL. Bob
Old October 22nd 20, 03:09 PM posted to rec.aviation.soaring
Tango Whisky
I had that one over Norther Germany (whis is as flat as flat can be). Cloud streets with base at 1200 m and tops at 1800 m. Wave lift started just under the base in front (upwind) of the cloud, and I managed to go over the tops.
You need a wind shift of 30° or so at cloud base level, with the air becoming stable (and the convective layer to be significantly unstable so that the thermals are pushed far into the stable layer above).
Le jeudi 22 octobre 2020 Ă* 13:50:12 UTC+2, a Ă©critÂ*:
Old October 22nd 20, 03:31 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
over the tops.
I've seen that too, in Cambridgeshire, UK directly over our airfield, but
the bases were lower - only 1200-1400 ft with a fairly brisk breeze,
blowing. The first time I saw it, the streets had short branches almost
at right angles to the street. It was possible to slope soar 150-200 ft
up the front of a branch. The second time there were no branches but
there was lift enough to climb up and over the street and then glide down
on the other side. I don't recall there being sink on the way down and
don't remember whether there was a crosswind under the street, which was
more or less circular in cross section.
Martin | martin at
Gregorie | gregorie dot org
Old October 23rd 20, 09:40 PM posted to rec.aviation.soaring
john firth
over the tops.
Martin | martin at
The comments are interesting but a convergence zone usually takes surface air up to the inversion;
I am familiar with flatland ( thermal) wave and have used it numerous times..
I was too quick to dismiss the donut vortex ring model. Vortices can be stable entities.
If the core was more than 600 ft dia., the donut could be over 1000 ft across; some energy
has to be supplied to keep it circulating.
This could come from the surface wind pushing the vortex; slightly unstable air is then picked up
at the downwind side and ascends in the core ; it spills out at the sides and rear and descends.
This could be quite smooth flow as indeed it was. It would explain why exploring all four quadrants
only showed sink. (ie not wave).
a drifting vortex ring might act as a mechanical trigger for local patches of "buoyant but sticky"
surface air (a.k.a. super adiabatic) to join the ring and keep it sustained. (thanks Dave Frank)
Amateur Built - Spacecraft? Richard[_8_] Home Built 2 June 20th 12 09:03 PM
Amateur Emerald Glenn[_2_] Aviation Photos 0 July 27th 07 03:24 PM
Amateur night at the field Viperdoc Piloting 33 May 13th 06 06:28 PM
Amateur Question: Meaning of "Heavy" Robin General Aviation 3 September 1st 04 05:12 AM
amateur design consultant? Shin Gou Home Built 14 June 30th 04 01:34 AM
