for the amateur meteorologists, question.
Old October 19th 20, 08:22 PM posted to rec.aviation.soaring
john firth
Default for the amateur meteorologists, question.
Maybe the last flight of the year, but memorable.
Atmosphere 10C, very unstable , with cloudbase 5000ft and tops above 10K; showers, wind W 15kt @ 1000ft.
climbed to 4000 (airspace limit) over the airfield ; flew upwind along a cloud street, holding 4000ft.
Street ended after 10 miles , then strong sink for 5 miles ending under a large cu.; at 1200 AGL
found zero sink but little more. Started circling but losing slowly, expecting to find real lift,
but probing found nothing better. Considered starting the engine, but that is admitting defeat too
early, with good fields below; and so I circled in smooth air and drifted, gaining 100 and losing it.
Clouds 4000 ft above drifted past.
Have faith! Unstable air has to get it together and accelerate; the fields drifted steadily
by underneath, in the weak October sunshine, interspersed with large woods, .
This went on for a long time, round and round, airfield unreachable even downwind.
( would I ever contemplate a 15 kt downwind landing? only as a life saver)
and so after 40 mins, still at about 1000 AGL, I see a dual lane highway, the airfield a mile beyond.
surprise! I can reach the airfield; after another couple of circles, I abandon the "thermal" and immediately hit 2 kts. End of suspense. I had drifted 14 miles at 1000ft in 50 mins doing 120 circles.
Now for the question: how does a parcel of air over 600ft diameter maintain a steady ascent
of 150 fpm for nearly an hour without either breaking away or dissipating. This was not a donut
as there was no central core. It must have been replenished from below.
Any similar experiences?
Have a well socially distanced winter!
John Firth (PIK 20E)
Old October 19th 20, 09:30 PM posted to rec.aviation.soaring
John Foster
Could it have been a line of convergence?
Old October 20th 20, 12:58 AM posted to rec.aviation.soaring
Waveguru
Or some kind of traveling wave?
Boggs
Old October 20th 20, 01:33 AM posted to rec.aviation.soaring
2G
https://chessintheair.com/convergence/
Old October 20th 20, 02:41 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
a cloud street, holding 4000ft. Street ended after 10 miles , then
strong sink for 5 miles ending under a large cu.; at 1200 AGL found zero
find real lift,
that is admitting defeat too early, with good fields below; and so I
circled in smooth air and drifted, gaining 100 and losing it. Clouds
fields drifted steadily by underneath, in the weak October sunshine,
even downwind.
saver)
maintain a steady ascent of 150 fpm for nearly an hour without either
breaking away or dissipating. This was not a donut as there was no
Yep, but not recently.
This was definitely convergence over the front of sea-air incursion. A
winch launch at Gransden Lodge, 10 miles west of Cambridge UK, put me in
zero sink with a cloud line, which turned out to be a convergence line,
running N-S along the road about 1 km to the east. I cruised over to it
with no height loss, turned north along it cruising at 50 kts and
climbing slowly but steadily to cloud base at 3500/4000 ft. It ended
around 5miles/8km I glided out to the motel on the A1 at Peterborough and
back to the cloud line for the loss of around 1500ft, drove back along it
to GRL and landed. That was my first XC in my 201 Libelle - a 100km out
and return in almost exactly an hour.
I haven't seen convergences like that in the last few years, but they
used to be frequent enough not to be unusual in Eastern UK and were
almost always in calm, high pressure conditions when an E or NE breeze
brought sea in from the North Sea.
Martin | martin at
Gregorie | gregorie dot org
Old October 21st 20, 06:57 PM posted to rec.aviation.soaring
john firth
find real lift,
even downwind.
saver)
Martin | martin at
I am afraid none of these ideas fit the observations; I am familiar with convergence
lines ( this was not a line) both as a lake effect and locally, terrain differential.
waves are not stable in a unstable atmosphere nor is the flat , slightly ridged terrain
condusive to wave generation.
The puzzle is that this bubble did not coalesce with a convective cloud passing overhead.
John F
Old October 21st 20, 10:46 PM posted to rec.aviation.soaring
WaltWX[_2_]
John,
Likely the answer is some kind of weak linear region of lift or convergence.. The atmospheric boundary layer if one could look down it often has lift lines parallel to the wind... or the lines look like like a "mesh" pattern. These may not be referenced necessarily to terrain or ground features.
Walt Rogers WX
Old October 22nd 20, 01:41 AM posted to rec.aviation.soaring
Waveguru
Waves aren't always generated by hills or mountains, sometimes the air bounces off of another air mass.
Boggs
Old October 22nd 20, 03:38 AM posted to rec.aviation.soaring
Basically, we don't understand meteorological conditions on the micro-micro level, as in the anomalies that happen for whatever reason in a tiny area. Of course, the "tiny" area is much smaller than can be predicted from satellite imagery, atmospheric analysis of airmass movement and surface disturbances. Essentially it all boils down to just flying in it and making some guesses about what is happening. The best competition pilots generally have many hours and good memories, enough so that they can recognize conditions they have experienced in the past and make assumptions and decisions based on prior knowledge.
For the rest of us, we are essentially clueless until someone with more data can provide a reasonable explanation. And even then, there is a good chance they are blowing smoke. Remember that it was less than 100 years ago (1933) that mountain wave formation was observed and explored by Wolf Hirth and Hans Deutschmann.
Trying to explain atmospheric phenomena requires lots of data, gathered a few bits at a time, and needs to be experienced by as many observers as possible to build even a little bit of understanding.
We used to say in hang gliding, "If we could see air, we'd probably quit flying!"
Old October 22nd 20, 07:32 AM posted to rec.aviation.soaring
krasw
Boggs
Waves form in stable layer, convection in neutral layer. Hard to imagine you could connect with wave 1000ft agl and same time have cu clouds passing above.
Amateur Built - Spacecraft? Richard[_8_] Home Built 2 June 20th 12 09:03 PM
Amateur Emerald Glenn[_2_] Aviation Photos 0 July 27th 07 03:24 PM
Amateur night at the field Viperdoc Piloting 33 May 13th 06 06:28 PM
Amateur Question: Meaning of "Heavy" Robin General Aviation 3 September 1st 04 05:12 AM
amateur design consultant? Shin Gou Home Built 14 June 30th 04 01:34 AM
