#11
Steelgtr62 wrote:
Some British engines used an oil passage through the carb venturi, a far more elegant solution. However using fuel injection or mounting the carburetor on top of the engine instead of underneath would largely obviate the problem. Fuel injection will help a lot, but mounting the carb on top makes almost no difference. Matt |
Matt Whiting wrote...
...but he may be referring to turning on the carb heat after he's already accumulated enough carb ice to noticeably decrease his RPM. Yeah, that's it. g No, I'm afraid UltraJohn was right. I haven't seen anything remotely resembling carb ice, and from what I've heard it's not very common in RVs. I get a very slight RPM *drop* with carb heat, presumably to a slight temperature *rise* from switching to undercowl air. Dave 'cold throat' Hyde "My wallet's fat and so is my head" - Greenday, 'Walking Contradiction |
Matt Whiting wrote in message ...
Steelgtr62 wrote: Some British engines used an oil passage through the carb venturi, a far more elegant solution. However using fuel injection or mounting the carburetor on top of the engine instead of underneath would largely obviate the problem. Fuel injection will help a lot, but mounting the carb on top makes almost no difference. Matt The Gipsy Major took its carb heat from up next to the crankcase. As with using undercowl air, the time between startup and useable heated air is too long and carb ice can form while warming up. We see carb ice shortly after startup rather regularly here, and we live in fairly dry country. Need to pull carb heat soon after startup some mornings. It's a good thing the exhaust piping heats up quickly. Dan |
Ray Toews wrote in message ...
Thanks for the insightful help, I planned to install some sensors to check the rise. I think I will glue one rite to the outside of the carb at the intake for as realistic a measurment as possible. I use those little automotive outside air temp sensors I buy from Canadian Tire, ------------------------------------------------------------------- Dear Ray (and the Group), Take your outside air temp sensor and hit it with a hammer. Okay, okay... squeeze it with a pair of pliers. IF (Big IF) IF... you're lucky, inside you will find a thermistor about the size of a grain of sand; the the tiny bit of **** that seems to be welded to the wires. To measure temperature at the carb, drill a hole in it large enough to accept the thermistor. (#80 works for the little thermistors.) SOP is one hole just above the throttle plate (if you have a throttle plate). (If you want to measure inlet air, put a thermistor on the carb-side of your carb heat box.) Now put a piece of tape over the hole on the INSIDE of the carb and go find yourself some metal-filled epoxy. The Good Stuff comes from Kodak, contains silver and transfers heat with virtually no loss at all. Mix up a dot of it, dip the thermistor into the epoxy and plug it into the hole. Now let it cure. (Don't forget to remove the tape.) You may install a suitable connector, if you wish. Should I mention that it's a good idea to only drill where the carb is solid metal? (Nah!) A carburetor makes a nice refrigerator. Outside air temp has surprisingly little to do with it. The pressure drop across the venturi (traditional carb assumed) and gasoline's endothermic change-of-state is enough to put frost on a can of beer quick like a bunny. With a suitable temperature probe in place you can sit there warm & cozy in the cockpit and see it all happen long before the engine starts running ruff and the Bad Silence ensues. (You may want to pull out that red knob over there...) -R.S.Hoover |
May want to test the thermistor after you free it from the evil probe and before you capture it in the refrigerator....
"Bob Hoover" wrote in message ... Ray Toews wrote in message ... Thanks for the insightful help, I planned to install some sensors to check the rise. I think I will glue one rite to the outside of the carb at the intake for as realistic a measurment as possible. I use those little automotive outside air temp sensors I buy from Canadian Tire, ------------------------------------------------------------------- Dear Ray (and the Group), Take your outside air temp sensor and hit it with a hammer. Okay, okay... squeeze it with a pair of pliers. IF (Big IF) IF... you're lucky, inside you will find a thermistor about the size of a grain of sand; the the tiny bit of **** that seems to be welded to the wires. To measure temperature at the carb, drill a hole in it large enough to accept the thermistor. (#80 works for the little thermistors.) SOP is one hole just above the throttle plate (if you have a throttle plate). (If you want to measure inlet air, put a thermistor on the carb-side of your carb heat box.) Now put a piece of tape over the hole on the INSIDE of the carb and go find yourself some metal-filled epoxy. The Good Stuff comes from Kodak, contains silver and transfers heat with virtually no loss at all. Mix up a dot of it, dip the thermistor into the epoxy and plug it into the hole. Now let it cure. (Don't forget to remove the tape.) You may install a suitable connector, if you wish. Should I mention that it's a good idea to only drill where the carb is solid metal? (Nah!) A carburetor makes a nice refrigerator. Outside air temp has surprisingly little to do with it. The pressure drop across the venturi (traditional carb assumed) and gasoline's endothermic change-of-state is enough to put frost on a can of beer quick like a bunny. With a suitable temperature probe in place you can sit there warm & cozy in the cockpit and see it all happen long before the engine starts running ruff and the Bad Silence ensues. (You may want to pull out that red knob over there...) -R.S.Hoover |
Just use a standard K or J type welded junction type thermocouple (i.e. two
wires welded together in a small bead). I would be cautious of any other type of sensor ... they may have too much mass and will introduce lag or damping into the readings because of the time required to heat the mass of the sensor housing. Also don't bond the thermocouple to the carby housing. You want to measure the air temperature, not the temperature of the metal inlet flange to the carby. Just stick the thermocouple wire into the inlet area - depending on the engine you can loosen a cable clamp in the alternative air system and just slide it in and retighten the clamp. I would slide in approx 1" of thermocouple wire so that the thermocouple is somewhere near the middle of the inlet hose. Ray Toews wrote in message ... Thanks for the insightful help, I planned to install some sensors to check the rise. I think I will glue one rite to the outside of the carb at the intake for as realistic a measurment as possible. I use those little automotive outside air temp sensors I buy from Canadian Tire, I noticed Wally wallmart has them as well but the ones I bought from wally were celsius only, irritating but not unsurmountable. They have about six feet of wire and a sticky back wich seems to hold well. God bless all the little borocrats who consented to give us the homebuilt movement. ![]() ray On 19 Oct 2004 16:55:42 -0700, (Dan Thomas) wrote: Matt Whiting wrote in message ... Steelgtr62 wrote: Some British engines used an oil passage through the carb venturi, a far more elegant solution. However using fuel injection or mounting the carburetor on top of the engine instead of underneath would largely obviate the problem. Fuel injection will help a lot, but mounting the carb on top makes almost no difference. Matt The Gipsy Major took its carb heat from up next to the crankcase. As with using undercowl air, the time between startup and useable heated air is too long and carb ice can form while warming up. We see carb ice shortly after startup rather regularly here, and we live in fairly dry country. Need to pull carb heat soon after startup some mornings. It's a good thing the exhaust piping heats up quickly. Dan |
Heat treating 4130 | RAM | Home Built | 0 | July 18th 04 04:33 PM |
Painting and air cooled motor? | CitizenX | Home Built | 5 | June 30th 04 12:47 PM |
28 volt pitot heat | B2431 | Home Built | 15 | April 17th 04 03:25 PM |
Heat treating wing ribs | Holger Stephan | Home Built | 13 | February 3rd 04 11:59 PM |
Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 03:32 PM |
