#11
Bertie the Bunyip wrote:
Philippe : Bertie the Bunyip wrote: spring oil pressure relief valve P/N 21352 Philippe - doesnt that relief valve control the upper limit i.e. opens at pressures greater than 35psi? - Mike I agree but with a very weak spring, it work for me... Why not try this first? .... If you have a weak spring, your higher power settign OP will also be low. Yes, it was... oops, sorry, he didn't say it was normal, but he didn't say it wasn't... Bertie Bertie - my upper OP is within the limits of 10-35PSI. It's my OP at idle that concerns me. Specifications for the A-65 show an acceptable range of between 10-35 and I'm concerned I may be below that range at idle ( at operating temp).- Mike Do we all agree that a pressure relief spring probably will not figure into the fix for the problem of raising my OP at idle? - Mike |
Michael Horowitz
: Bertie the Bunyip wrote: Philippe : Bertie the Bunyip wrote: spring oil pressure relief valve P/N 21352 Philippe - doesnt that relief valve control the upper limit i.e. opens at pressures greater than 35psi? - Mike I agree but with a very weak spring, it work for me... Why not try this first? .... If you have a weak spring, your higher power settign OP will also be low. Yes, it was... oops, sorry, he didn't say it was normal, but he didn't say it wasn't... Bertie Bertie - my upper OP is within the limits of 10-35PSI. your pressure above idle should be 30-40. If it's below 30 you don't have enough pressure. 10 is the lower limit for idle only. It's my OP at idle that concerns me. Specifications for the A-65 show an acceptable range of between 10-35 and I'm concerned I may be below that range at idle ( at operating temp).- Mike Do we all agree that a pressure relief spring probably will not figure into the fix for the problem of raising my OP at idle? - Mike might do if your pressure above about 1,000 rpm is less than 30 once your oil is warm! Bertie |
As the engine ages the pump wears and pump clearances open up so that
it pumps less volume. The bearing clearances also increase so oil flows through them easier. The result is a drop in oil pressure. I've seen that in my A-65 and others. The original potser had had his bottom end redone, so unless the mechanic paid no attention to crank wear and put things together with big clearances, I'd say that the accessory cover needs to come off and the pump fixed. The most likely wear is the aluminum pump cavity, since it sucks unfiltered oil and is easily scored up. If it's a homebuilt the cover plate could be lapped and the pump housing face machined lightly to reduce the endplay. If there's serious scoring the whole accessory cover needs replacing. And where do we find a new A-65 cover these days? Dan |
Michael Horowitz
: Bertie the Bunyip wrote: Philippe : Bertie the Bunyip wrote: spring oil pressure relief valve P/N 21352 Philippe - doesnt that relief valve control the upper limit i.e. opens at pressures greater than 35psi? - Mike I agree but with a very weak spring, it work for me... Why not try this first? .... If you have a weak spring, your higher power settign OP will also be low. Yes, it was... oops, sorry, he didn't say it was normal, but he didn't say it wasn't... Bertie Bertie - my upper OP is within the limits of 10-35PSI. It's my OP at idle that concerns me. Specifications for the A-65 show an acceptable range of between 10-35 and I'm concerned I may be below that range at idle ( at operating temp).- Mike Do we all agree that a pressure relief spring probably will not figure into the fix for the problem of raising my OP at idle? - Mike Um, no, the range for the A-65 is 10 minimum for idle, but it's 30-40 for higher settings. If you've got less than 30 when your oil is hot, youhaven't got enough, unless you've got an a-65 I've never seen! My old A- 50 was the same, BTW What's the source of info for your figure of 10-35? Bertie |
Um, no, the range for the A-65 is 10 minimum for idle, but it's 30-40 for higher settings. If you've got less than 30 when your oil is hot, youhaven't got enough, unless you've got an a-65 I've never seen! My old A- 50 was the same, BTW What's the source of info for your figure of 10-35? Bertie http://www.mooneymite.com/articles/continental.htm and elsewhere - Mike |
Michael Horowitz
: Bertie the Bunyip wrote: Um, no, the range for the A-65 is 10 minimum for idle, but it's 30-40 for higher settings. If you've got less than 30 when your oil is hot, youhaven't got enough, unless you've got an a-65 I've never seen! My old A- 50 was the same, BTW What's the source of info for your figure of 10-35? Bertie http://www.mooneymite.com/articles/continental.htm and elsewhere - Mike Note that it says 30-35 for cruising. I have a Continental manual in my lap and it specifies 30-40 for cruise. 30 is fine though towards 40 is better, but if you have less than that at anything above about 1500 revs and you're not running sewing machine oil, you don't have enough to keep from scraping bits of metal together on your cam or your bottom end. Bertie |
Michael Horowitz m: Bertie the Bunyip wrote: Note that it says 30-35 for cruising. I have a Continental manual in my lap and it specifies 30-40 for cruise. 30 is fine though towards 40 is better, but if you have less than that at anything above about 1500 revs and you're not running sewing machine oil, you don't have enough to keep from scraping bits of metal together on your cam or your bottom end. Bertie Bertie - I think I'm fine at the high end. My only concern is the minimal OP at idle. - Mike |
Michael Horowitz
: Bertie the Bunyip wrote: Michael Horowitz om: Bertie the Bunyip wrote: Note that it says 30-35 for cruising. I have a Continental manual in my lap and it specifies 30-40 for cruise. 30 is fine though towards 40 is better, but if you have less than that at anything above about 1500 revs and you're not running sewing machine oil, you don't have enough to keep from scraping bits of metal together on your cam or your bottom end. Bertie Bertie - I think I'm fine at the high end. My only concern is the minimal OP at idle. - Mike OK, well if your pressure is good at the high end, it's probably not the relief valve. Any adjustment or replacement I've ever seen on that usually changed it right across the board. In fact, if it's OK at the high side and you replace it or put some washers in or whatever, you'll probably find it going over the top on the high side and staying there. OTOH, it costs nothing but a bit of time to try it. Bertie |
182RG question | Paul Anton | Owning | 11 | May 16th 05 09:45 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
