#11
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message ... A lot of time? I don't see it. Unless the hold line is way back from the runway, I can typically taxi onto the active and be rolling at full throttle in 10 seconds or less. All they need to do is clear me for takeoff when the airplane that just landed is 10 seconds or so from clearing the runway and no time at all will be lost. How long do you think it takes a heavy to do the same? The one's I've flown take maybe 20-30 seconds. So, you just lead them a little more while the landing airplane is rolling out. I don't think this is any less safe then P&H. I didn't mind P&H in my Skylane as I could see out the back windows enough to tell if someone was going to land on me. However, in the Arrow I now fly, you are blind towards the rear. Matt |
Blueskies wrote:
"Matt Whiting" wrote in message ... Robert M. Gary wrote: That's hard to believe. P&H really saves a lot of time when the runway is really busy. The only way I can see this working is if pilot learn how to do "cleared for immediate takeoff". Most controllers avoid this because "immediate" for many pilots means sitting on the runway while they go through their last checklist. A lot of time? I don't see it. Unless the hold line is way back from the runway, I can typically taxi onto the active and be rolling at full throttle in 10 seconds or less. All they need to do is clear me for takeoff when the airplane that just landed is 10 seconds or so from clearing the runway and no time at all will be lost. Matt Don't think takeoff clearance can be made when there is still an aircraft on the runway... That can be changed also. Matt |
![]() Blueskies wrote: "Matt Whiting" wrote in message ... Robert M. Gary wrote: That's hard to believe. P&H really saves a lot of time when the runway is really busy. The only way I can see this working is if pilot learn how to do "cleared for immediate takeoff". Most controllers avoid this because "immediate" for many pilots means sitting on the runway while they go through their last checklist. A lot of time? I don't see it. Unless the hold line is way back from the runway, I can typically taxi onto the active and be rolling at full throttle in 10 seconds or less. All they need to do is clear me for takeoff when the airplane that just landed is 10 seconds or so from clearing the runway and no time at all will be lost. Matt Don't think takeoff clearance can be made when there is still an aircraft on the runway... Sure there can. The only requirement is that that other aircraft be off the runway before you get on it and start your takeoff roll. It's called anticipated separation and applies to any separation standard. As long as the separation is there when it's needed all the rest is irrelavant. |
![]() " Blueskies" wrote in message . .. Don't think takeoff clearance can be made when there is still an aircraft on the runway... FAA Order 7110.65P Air Traffic Control Chapter 3. Airport Traffic Control-- Terminal Section 9. Departure Procedures and Separation 3-9-5. ANTICIPATING SEPARATION Takeoff clearance needs not be withheld until prescribed separation exists if there is a reasonable assurance it will exist when the aircraft starts takeoff roll. |
![]() "Matt Whiting" wrote in message ... The one's I've flown take maybe 20-30 seconds. So, you just lead them a little more while the landing airplane is rolling out. Lead them a little more? You mean delay the takeoff clearance a little more, don't you? I don't think this is any less safe then P&H. The problem with P&H is not in holding aircraft on a runway, it's in clearing other aircraft to land while aircraft are holding in position on the runway. The solution is simple; stop clearing aircraft to land when aircraft are holding in position. |
Something I heard on the radio a few months ago while overflying KCMA:
PLANE: Camarillo Tower, Cessna 123 at runway... uh... twenty six. TOWER: Cessna 123, say your intentions. PLANE: I'd like to take off. TOWER: Cessna 123, position and hold, runway two six. PLANE: Um, I'm at runway two six. TOWER: Roger, position and hold on runway two six. PLANE: Well, my position is runway two six, and I don't understand what you mean. TOWER: Confirm, Cessna 123, you're at runway two six and you're NOT on the runway? PLANE: Yeah, and I'm holding my position here. TOWER: Drive onto the runway and hold your position, Cessna 123. PLANE: (pilot keys transmit button, but there's a long silence as he tries to wrap his head around the instruction until ![]() TOWER: (pause, teeth gnashing sounds inserted by my imagination.) Cessna 123, cleared for takeoff, runway two six. PLANE: Cleared for takeoff, Cessna 123......(five second pause, then he keys up again).....oh, and I'm departing to the right. Sometimes, I think that radio conversations like this are staged for the benefit of making nearby student pilots feel better about their radio work. |
"Dave S" wrote in message nk.net... Yea.. just think of all the near collisions it will avoid! How many? Up to ALL of them on the runway? In theory, of course, :P Dave |
![]() Roger wrote: And if it doesn't work out the plane on final does a go around. Couple of times I've been cleared to land and heard, Thirty Three Romeo, go around, aircraft on the runway!". The identified problem is because the controller forgets about the aircraft in position and lets the aircraft land over the top of the one on the runway. |
![]() "Steven P. McNicoll" wrote in message nk.net... " Blueskies" wrote in message . .. Don't think takeoff clearance can be made when there is still an aircraft on the runway... FAA Order 7110.65P Air Traffic Control Chapter 3. Airport Traffic Control-- Terminal Section 9. Departure Procedures and Separation 3-9-5. ANTICIPATING SEPARATION Takeoff clearance needs not be withheld until prescribed separation exists if there is a reasonable assurance it will exist when the aircraft starts takeoff roll. Thanks! |
"Matt Whiting" wrote in message ... The one's I've flown take maybe 20-30 seconds. So, you just lead them a little more while the landing airplane is rolling out. Lead them a little more? You mean delay the takeoff clearance a little more, don't you? No, I meant give the takeoff clearance a little sooner while the aircraft that just landed is still going down the runway heading for the taxiway. This would have the same advantage as P&H in most circumstances. I don't think this is any less safe then P&H. The problem with P&H is not in holding aircraft on a runway, it's in clearing other aircraft to land while aircraft are holding in position on the runway. The solution is simple; stop clearing aircraft to land when aircraft are holding in position. Yes, that works also, but then what is the point of P&H if not to get more throughput per active runway? Matt |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 01:25 AM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
