#11
![]() Jerry Springer wrote: "Gig 601XL Builder" wr.giacona@coxDOTnet wrote Tie the aircraft to a pole and... Not a good idea for a new or rebuilt engine. It needs air flowing to keep cylinders cool. Happened to a local guy who thought it was neat to taxi all over the area in his new airplane, overheated cylinders and it burned a lot of oil from the very beginnoing. He had to rebuild the cylinders. I can see that happening at idle speeds but if you run the engine up to full throttle won't the prop wash provide enough cooling, depending on the cowling of course. -- FF |
I would do a few high speed taxi's and fly it. Don't worry that much
about the brakes. Haulting it down after the high speed taxi will do the job, you can ever leave a bit of power on with brakes to get the heat up. Make sure you don't have leaks and cooling is good. David Koehler wrote: Hi All, I'm not there yet, but, I have a new Lycoming O-360 and in the process of building a homebuilt kit. Lycoming says to break in the engine at full power and gives procedures on how to do it. The kit needs slow taxi, then fast taxi, glazing of the brakes. After take off there are procedures to do at lower power.... I know I'm not the FIRST in this dilemma, so what takes a preference? If you wait to do the full power to seat the rings, is that ok? Thanks for any response, I'm at a loss, david |
![]() "docrw" wrote in message oups.com... I would do a few high speed taxi's and fly it. Don't worry that much about the brakes. Haulting it down after the high speed taxi will do the job, you can ever leave a bit of power on with brakes to get the heat up. Make sure you don't have leaks and cooling is good. Talk with a flight advisor before doing any high speed taxiing. Many (most?) discourage it, because it puts you in the neither fish nor foul situation where the airplane isn't exactly flying and it isn't exactly just rolling along either. High speed taxi's are an excellent way to lose control on the ground with an unfamiliar aircraft, to accidentally become airborne. Certainly, there are alternate opinions... |
On Fri, 12 Aug 2005 20:45:36 -0700, Jerry Springer
wrote: wrote: Jerry Springer wrote: "Gig 601XL Builder" wr.giacona@coxDOTnet wrote Tie the aircraft to a pole and... Not a good idea for a new or rebuilt engine. It needs air flowing to keep cylinders cool. Happened to a local guy who thought it was neat to taxi all over the area in his new airplane, overheated cylinders and it burned a lot of oil from the very beginnoing. He had to rebuild the cylinders. I can see that happening at idle speeds but if you run the engine up to full throttle won't the prop wash provide enough cooling, depending on the cowling of course. Actually it will not, a prop turing at full speed with airplane not moving is not very efficient at all. It also take forward speed to create enough airflow for cooling. A lot of homebuilts have very tight cowlings and need a fair amount of pressure to force the air down and around the cylinders It depends on how well the engine is cooled. Many "Spam Cans" won't heat up enough to get the contaminants out of the oil, but new, or rebuilt engines are a different animal. OTOH isn't there a requirement for one hour on the engine before it takes to the air, or is that before the FAA inspection and sign off? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Jerry |
Greetings All,
First, thank you for all the insight, I've been all over the net, from Lycoming to Glastar. It seems that the break in is to seat the rings and if it's not done correctly the cylinder walls will glaze and the rings will never seat. One can start the engine up for short runs monitoring the temperature until the "break-in" can be done. We're not talking about 3 or 4 years, just a few runs not to exceed 3 minutes each and turning the engine off. I believe with smaller engines (rotax) you can tie them to a pole. Again, Thanks to all, without all the input I would still be going in circles. david "David Koehler" wrote in message ... Hi All, I'm not there yet, but, I have a new Lycoming O-360 and in the process of building a homebuilt kit. Lycoming says to break in the engine at full power and gives procedures on how to do it. The kit needs slow taxi, then fast taxi, glazing of the brakes. After take off there are procedures to do at lower power.... I know I'm not the FIRST in this dilemma, so what takes a preference? If you wait to do the full power to seat the rings, is that ok? Thanks for any response, I'm at a loss, david |
![]() "Roger" wrote in message ... snip OTOH isn't there a requirement for one hour on the engine before it takes to the air, or is that before the FAA inspection and sign off? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I've heard of the 1 hour engine run requirement, but I've never found it in any official (FAA) or reputable (EAA) source. I am aware of some DAR's who require it. My DAR didn't mention it. Personally, if I had access to a test stand with proper cooling set-up, I'd run a new engine at least an hour. However, installed on an aircraft, and without a test club, lengthy engine runs on the ground are not recommended per Lycoming's new or remanufactured engine break-in procedure. KB |
On Sun, 14 Aug 2005 08:03:47 -0400, "Kyle Boatright"
wrote: "Roger" wrote in message .. . snip OTOH isn't there a requirement for one hour on the engine before it takes to the air, or is that before the FAA inspection and sign off? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I've heard of the 1 hour engine run requirement, but I've never found it in any official (FAA) or reputable (EAA) source. I am aware of some DAR's who require it. My DAR didn't mention it. Personally, if I had access to a test stand with proper cooling set-up, I'd run a new engine at least an hour. However, installed on an aircraft, and without a test club, lengthy engine runs on the ground are not recommended per Lycoming's new or remanufactured engine break-in procedure. On my rebuild in the Deb they told me to take minimum taxi time, get it in the air and run the crap out of it. The first hour was running 80 to 85% with a lot of power changes. The rings seated in just a few hours. I don't remember just how many now, but it wasn't long. Although they were concerned with temps (which weren't a problem) in this particular case it sounded more like they were interested in the ring seating. It worked. Nearly a 1000 hours later and it still uses less than a pint in 25 hours. That puts the way you run the engine at odds with the way you want to start your test flights, so likewise, I'd prefer to run the engine in on a test stand, but unfortunately I don't think that is going to happen. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com KB |
Greetings All, First, thank you for all the insight, I've been all over the net, from Lycoming to Glastar. It seems that the break in is to seat the rings and if it's not done correctly the cylinder walls will glaze and the rings will never seat. One can start the engine up for short runs monitoring the temperature until the "break-in" can be done. We're not talking about 3 or 4 years, just a few runs not to exceed 3 minutes each and turning the engine off. I believe with smaller engines (rotax) you can tie them to a pole. Again, Thanks to all, without all the input I would still be going in circles. david Yes, with the rotax 2-strokes, the breakin procedure is normally done with the airplane tied down. It's a little over an hour, but involves starting slow and gradually increasing the amount of work the motor does. Overall, there's only about 5 or 6 minutes of full throttle operation, most of it right at the end. The motor is essentially ready to fly at the end of it with the rings just about fully seated. In my experience, though, about 10 hours is needed to fully break it in and get stable CHT's. I'm a strong believer in the tied-to-the-pole breakin procedure since it not only allows a breakin but also proves the motor installation. If there's a problem with your mounting job, it'll definitely show up during that screaming breakin. Also, if there's a fatal, major defect in the motor that'll show up too as a siezure or explosion or whatever. The nice thing is, the the plane tied down, all this will happen on the ground instead of way up in the air...... That's not a hard and fast rule though, as some manufacturers recommend the breakin be done in the air..... LS N646F "David Koehler" wrote in message ... Hi All, I'm not there yet, but, I have a new Lycoming O-360 and in the process of building a homebuilt kit. Lycoming says to break in the engine at full power and gives procedures on how to do it. The kit needs slow taxi, then fast taxi, glazing of the brakes. After take off there are procedures to do at lower power.... I know I'm not the FIRST in this dilemma, so what takes a preference? If you wait to do the full power to seat the rings, is that ok? Thanks for any response, I'm at a loss, david |
"ls" wrote in message
.. . I'm a strong believer in the tied-to-the-pole breakin procedure since it not only allows a breakin but also proves the motor installation. If there's a problem with your mounting job, it'll definitely show up during that screaming breakin. I can't be the only one who picked up the double entendre about "tying it to a pole" and "Slusarczyk" in the same post. Now I'm ROTFLMAO about a "screaming Pole". Rich "Is that a stall warning horn??" S. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
