New Engine on New homebuilt
Old August 11th 05, 08:27 PM
David Koehler
Default New Engine on New homebuilt
Hi All,
I'm not there yet, but, I have a new Lycoming O-360 and in the process of
building a homebuilt kit. Lycoming says to break in the engine at full power
and gives procedures on how to do it. The kit needs slow taxi, then fast
taxi, glazing of the brakes. After take off there are procedures to do at
lower power.... I know I'm not the FIRST in this dilemma, so what takes a
preference? If you wait to do the full power to seat the rings, is that ok?
Thanks for any response, I'm at a loss,
david
Old August 11th 05, 08:48 PM
Gig 601XL Builder
"David Koehler" wrote in message
Hi All,
power
ok?
david
Tie the aircraft to a pole and...
Old August 11th 05, 10:37 PM
N523RV
David,
Not to steer you away from this forum but this very topic is just
getting kicked off in the Lycoming group on Yahoo.
http://groups.yahoo.com/group/lycoming
Matthew
RV-9A (Wiring avionics)
www.n523rv.com
Old August 11th 05, 10:38 PM
Roman
If the engine is from Lycoming, it should have had a few hours put on
it on the test stand and you should have gotten a report on the test
run with the engine.
Old August 11th 05, 11:37 PM
Dan, U.S. Air Force, retired
Hi All,
power
ok?
david
I know just the Pole. Call Chuck S.
Old August 12th 05, 12:44 AM
Kyle Boatright
Hi All,
power
ok?
david
The brake break-in procedure only requires a few minutes of taxi time and a
couple of stops, IIRC. On my RV-6 (I assembled the airplane rebuilt the
engine myself), I probably ran the engine 10-15 minutes before the first
flight. First was a short run to make sure it ran and didn't have major
leaks. Then was a short run to taxi the airplane the length of the taxiway,
performing the pad break-in procedure.
The third time I cranked the engine, I taxied to the end of the field, ran
up the engine, and launched into the blue. Of course, I had done LOTS of
work to verify that all of the controls had good continuity and the aircraft
was properly rigged. I've known too many people who had trouble due to
sloppy rigging on the first flight.
It is attention grabbing to make the first flight of any homebuilt aircraft,
moreso one where you built the engine too...
KB
Old August 12th 05, 02:14 AM
Jerry Springer
Not a good idea for a new or rebuilt engine. It needs air flowing
to keep cylinders cool. Happened to a local guy who thought it was neat
to taxi all over the area in his new airplane, overheated cylinders and
it burned a lot of oil from the very beginnoing. He had to rebuild the
cylinders.
Jerry
Old August 12th 05, 02:50 AM
Morgans
But keep a good eye on temps. Without flying, the cooling air is not as
"good" at keeping you new baby from getting hot under the collar. Or so I
have heard. g
Old August 12th 05, 02:51 AM
Morgans
Not a bad idea! It would take some doing to move *that* pole. g
Old August 12th 05, 02:54 AM
Morgans
aircraft,
Moreso? Don't they make racing engines, or something? vbg
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
