After Annual ...
Old August 12th 05, 04:21 PM
Marco Leon
There was a very good article in Aviation Safety magazine's July 2005 issue.
Here's the checklist they had in a sidebar but you should subscribe and/or
get a copy of the article. Pretty much a regular checklist (at least like
mine) with a couple more items.
Test-Flight Checklist
In addition to spending some time with the paperwork checklist on the
previous page, once you get ready to test-fly the airplane, you'll want to
conduct a very thorough inspection. The checklist below is adapted from one
I created for picking up a Baron from a paint and interior shop, with some
additional work done during the downtime. Use it as a template for writing
your own post-maintenance checklists.
Before Take-Off
.. With master switch on, check electric gyro erection.
.. With any smoke or burning odor, shut off master and investigate.
.. Proceed to avionics master, repeat.
.. Execute normal start and note any discrepancies.
.. Check engine, electrical and pneumatic indications after starting.
.. Free and correct movement of the flight controls.
.. Correct movement of the fuel selector valves.
.. Proper operation of fl aps, brakes and nosewheel steering.
.. Free, proper and unrestricted movement of the trim in all axes.
.. All switches on the pilot's control yoke.
.. Operation of all anti- and deicing equipment.
.. All electrical equipment and avionics.
.. Lack of "noise" on a Stormscope/Strike Finder, if present.
.. All circuit breakers remain "in."
.. Verify proper engine oil and temperatures before takeoff .
Test Flying
.. All engines must develop full power for takeoff .
.. Takeoff performance must be as predicted/per POH.
.. Check all engine operating indications, especially temperatures.
.. Electrical and avionics operation.
.. Operation of landing gear, wing fl aps and cowl fl aps.
.. Correct autopilot and trim operation.
.. If possible, proper operation of the weather radar/Stormscope.
.. If possible, fly an ILS to test glideslope reception.
.. Note any GPS anomalies/discrepancies.
.. Ask ATC to verify transponder and Mode C operation.
.. Correct "feel"-does the aircraft properly respond?
Post-Flight Checks
.. Investigate any squawks resulting from the acceptance fl ight.
.. Fully open engine cowlings for leak inspection.
.. Check for any loose fairings, inspection covers.
.. Any other operational or business items.
Finally picking up my airplane tomorrow after a 2-month annual. Just
bought it in April. It is a '61, and despite logbook entries that SAY
annuals have been done every year, it was pretty clear the majority of
stuff under the cowl hadn't been touched in a LONG time. Picking it up
tomorrow. Along with the usual, thorough preflight routine, I plan to do
one or two landings at that airport, come back, shut down and have
another look at everything before leaving to bring the airplane to my
home airport.
Have a few hundred more hours to go before a major engine overhaul, but
just about every part was taken out, scrutinized, cleaned, overhauled,
and replaced. Any tips/advice on that first test flight after that kind
of maintenance, other than the obvious?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old August 12th 05, 04:40 PM
OtisWinslow
"John Clear" wrote in message
A friend of mine does the first flight after annual on his Arrow
in full nomex with a helmet. John
John Clear - http://www.clear-prop.org/
This guy is a little off if you ask me.
Old August 12th 05, 05:59 PM
Newps
A little? I mean really, an Arrow for Christs sake.
Old August 12th 05, 07:16 PM
John Clear
Like I said in the part that got snipped, this guy is a bit militant
about safety. And yes, he is just a little bit off, but I have no
problem flying with him. The point of my post, and him wearing
nomex, is that the first flight after maintenance has a bit more
unknowns then your average flight.
Just so you don't think my friend is a tin-foil hat type, he has
done alot of work on getting the word out about mountain wave (just
don't ask him about the Julian VOR[1]) and also calculated the best
way to do the 'impossible turn', went out and verified the calculations
at altitude, and then did it for real with a video camera mounted
in the back seat. The take off clearance was 'cleared for take
off 25 Right, cleared to land 7 Left'. The video is pretty
impressive.
John
[1] Do an NTSB search on 'Julian, CA' if you are curious. Not all
are mountain wave related, but many list 'loss of control for
undetermined reasons' in the probable cause section.
Old August 12th 05, 07:22 PM
Dale
Fire is fire, be it in an Arrow or Eagle. Head injuries are very
unforgiving regardless of the cause. Why not use the protection if it's
available?
I wear nomex for most of my flying, and would wear a helmet if I had one
available.
I've had the unfortunate experience of taking broken and burned bodies
out of aircraft crashes.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old August 12th 05, 08:17 PM
Sylvain
impressive.
I saw that video! took place in Livermore, right? also attended
this guy's presentation about the impossible turn, very well
worth our time, don't miss it if he gives it in your neighborhood.
--Sylvain
Old August 12th 05, 08:23 PM
RST Engineering
Coming home to San Diego (SEE) from El Centro (IPL) one day, I got to 19,500
over JLI -- in a C-170. I had the sucker at flight idle, yellow-arced and
going like dammity hell, and STILL going up.
(I hope the statute of limitations has expired after 30 years.)
Old August 12th 05, 08:41 PM
Scott Migaldi
What does that say about helicopter pilots who alwys seem to be wearing
nomex and helemnts? Do they actually think that the helmet will save
their head if they run into the rotors?
just kidding of course ;-)
Scott F. Migaldi
CP-ASEL-IA
N8116B
PADI MI-150972
Join the PADI Instructor Yahoo Group
http://groups.yahoo.com/group/PADI-Instructors/
Old August 12th 05, 08:42 PM
John Clear
impressive.
Yep, the video was shot at Livermore.
John
Old August 12th 05, 10:57 PM
Skywise
"OtisWinslow" wrote in news:Yp3Le.146240
From 18+ years of motorcycle riding, this reminds me of the
two types of riders.
One - helmet, gloves, jacket, boots, and chaps. That's me.
Although on really hot days and/or short trips I may forgo
the chaps. Yes I get hot. Yes I sweat. But I'd like to keep my
skin should something happen, and it's been tested, fortunately
only a minor situation with no injuries.
Two - helmet, t-shirt, shorts, flip-flops. These are usually
the hot shots on the rice rockets who think they can ride like
the pros on the track. Invariably I see these bikes with broken
turn lights and scratched paintjobs.
I realize motorcycle riding and flying are two different things
and one doesn't normally wear all that protective gear while
flying. But the idea of calling someone "off" for wearing
protective gear when they are - for all intents and purposes -
being a test pilot, is a bit "off" in itself, don't ya think?
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Blog: http://www.skywise711.com/Blog
Sed quis custodiet ipsos Custodes?
Moving the Annual Up Jay Honeck Owning 26 February 21st 05 12:34 AM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
