Cherokee battery box repair
Old August 29th 05, 01:59 PM
Default Cherokee battery box repair
Hey all... I've got the plane down for an annual and have discovered a small
weeping leak in the bottom of the battery box (where the drain nozzle attaches). Am I
correct in recalling that the box is made of tin and the nozzle of copper? Will
regular Lead/Tin (60/40) solder this, or do I need some special solder for it? It
seems like it should be repairable, since it looks like it was *made* by soldering.
Oh yeah, and of course a good cleanup and repaint is in order back there.
Very little corrosion back there, but enough to do a bit of cleanup.
-Cory
* Cory Papenfuss *
Old August 29th 05, 02:19 PM
Mike Rapoport
The battery boxes that I have seen are made of aluminium.
MU-2
small
attaches). Am I
Will
it? It
soldering.
-Cory
* Cory Papenfuss *
Old August 30th 05, 02:26 PM
I'll respond to my own post and a few others with the results.
- I believe my version of the Service Manual wasn't quite so descriptive on the
"Alternator source power circuit" label... it was pretty vaguge.
- I wasn't sure how sensitive the external regulator was to low bus voltages...
whether or not it would self-excite. The only self-exciting alternators I've played
with are the standard Delco GM (GM-10 or something?) that would be hung off a '78
pickup or equiv.
- It certainly seems like the box is tin, so one would think that if it were clean
enough regular Pb/Sn solder would stick. I was unsuccessful last night, but about the
only soldering I do is electrical in nature, so I didn't have any acid-based flux.
The Rosin core beaded up and wouldn't stick, as expected. A buddy of mine had a
rod of "magic solder" from when he did his box. Looked like a stick welding
rod with florescent orange flux. Took a hot-ass flame to melt it, but when it did it
bonded the copper/tin together nicely.
-Cory
* Cory Papenfuss *
Checking the battery in a Cherokee nobody Owning 15 May 5th 05 12:39 PM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
