Why Haven't Airbus A-320s Been Grounded?
Old October 7th 05, 05:01 AM
Jay Honeck
While were at it, why didn't the FAA ground the middle vintage 737s when
they had two fatal accidents from suspected rudder reversals, plus a
couple of rudder control incidents reported by other airlines while in
flight? At least the A320 nose gear problem hasn't yet resulted in any
fatalities.
I followed the 737 rudder reversals with great interest. The reason the FAA
did not ground the fleet was quite simply that they could not duplicate the
problem for some time. It took some pretty extreme environmental
manipulation (extreme cold, moisture, etc.) before anyone could actually
make the actuator in the 737 malfunction the way the flight data recorders
were apparently reporting.
Once they *were* able to duplicate the rudder problem, the AD came
immediately, and the fix was pretty urgent.
But that still doesn't answer the question. If this known nose gear
malfunction was happening on, say, Beech Bonanzas, the whole fleet would be
grounded in a heartbeat. Yet it's happening to a commonly used airliner,
and nothing much seems to be happening.
Is there some over-riding political reason the FAA doesn't want to offend
the Europeans right now?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 7th 05, 06:30 AM
karl gruber
would be
airliner,
The FAA didn't put an AD on the Bonanza tail until 350 (and decades)
of them disintegrated in flight. Then it was only because the president
of the Bonanza society, a big Beech defender, was killed that Beech got
off their butt and fixed the tail.
At the same time, King Air wings were falling off at an alarming rate
and Beech and the FAA did virtually NOTHING to solve that as well. It
took a private company to produce a wing strap for the KA to finally
embarrass Beech into fixing the King Air.
The new King Air wing is held on by bolts in shear. The old (pre about
1984)by bolts in tension. FAA did NOTHING!
The FAA is not necessarily going to do anything to promote safety in
aviation. They never have. It's ALWAYS private enterprise that fixes
the real problems!
Old October 7th 05, 05:12 PM
kgruber
n
Old October 7th 05, 05:22 PM
kgruber
KingAir wings falling off - at an "alarming rate"? Because you don't
have any King Air experience???
Could it be because a database search of the NTSB from 1962 to present,
using several different keyword combinations produced 0 records of such
incidents? Ever hear of the "world?"
Or the Google search, showing C-130's wings falling off, but not
KingAirs? You should learn how to "Google!" This is the company
that solved the problem after at least 5 King Airs had their wings fall
off:
http://www.nationalflight.com/aviadesigns.htm
Can you point us to evidence sufficient to warrant the insinuation
Do your own homework!
Karl
ATP----BE-300, CE-500, Lear Jet, DA-50
Old October 7th 05, 08:27 AM
Stefan
The current US government is doing everything they can to offend the
Europeans right now, so this can't be the reason. I suspect the reason
is that, despite all the television hype, there has never actually been
any real danger for the passengers.
Stefan
Old October 7th 05, 01:56 PM
Jay Honeck
Europeans right now, so this can't be the reason. I suspect the reason is
that, despite all the television hype, there has never actually been any
Landing an airliner with the nose gear 90 degrees misaligned poses no danger
to passengers?
That's a stunning statement, coming from a presumed pilot.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 7th 05, 02:35 PM
Stefan
Flying *is* a stunning thing.
Stefan
Airbus A380 water purification john smith Piloting 1 July 7th 05 02:50 AM
Australia chooses Airbus tankers John Cook Military Aviation 0 April 16th 04 10:25 AM
Airbus 15 minutes of fame over? Buzzer Military Aviation 5 January 20th 04 04:42 AM
Airbus Charts Course for Military Contracts Otis Willie Military Aviation 0 November 24th 03 11:04 PM
Airbus Aiming at U.S. Military Market Otis Willie Military Aviation 0 September 21st 03 08:55 PM
