Aerodynamics of carrying water
Old October 11th 05, 05:27 PM
Bill Daniels
"Gene Whitt" wrote in message
nk.net...
Y'all,
Been many years on rec.aviation.student but even more years since
gliding. Unable to explain the 'why' of water ballast to increase
performance in gliders to argumentative airplane student.
I need a simple explanation in 25 words or less.
Gene Whitt
All good answers.
I would add that an examination of two polars for a particular glider, one
ballasted and one not, will show a crossover airspeed above which the sink
rate with ballast is less than without - very counterintuitive.
Most modern gliders flying in conditions with greater than 2Kt thermals will
spend 80% of their X/C time flying at airspeeds above the crossover point
where the sink rate is reduced by using ballast.
Flying fast with reduced sink is dramatic.
Bill Daniels
Old October 11th 05, 05:38 PM
Pat Russell
On 11 Oct 2005 03:52:06 -0700, "Andy" wrote:
Edit to 25 words.
"A glider is a gravity-powered machine. The heavier it is, the more
power it has."
16 words, beat that!
-Pat
Old October 11th 05, 05:43 PM
Andy
The polar documents the phenomenon, it does not explain it. Any
attempt to explain the use of ballast by reference to the polar should
leave any intelligent person asking - but why does the polar do that.
I believe the effect can only be explained by considering the system
energy exchange. Once that is understood the effect on the polar
family is intuitive.
Old October 11th 05, 07:10 PM
Andy
But I need the same amount of power to go the same speed don't I? Why
does more power reduce my sink rate?
I think you'll need more than 16 words.
Andy
Old October 11th 05, 07:31 PM
Derrick Steed
but loses all the effects due to Reynolds number which is an aerodynamic
phenomena and the original question was about the aerodynamics, not the
dynamics.
Rgds,
Derrick Steed
Old October 11th 05, 08:22 PM
P.Corbett (ZZ)
Gene Whitt wrote:
Y'all,
Gene Whitt
E=M(CxC)
Paul
Old October 11th 05, 08:58 PM
Derrick Steed
Gene Whitt wrote:
Y'all,
gliding. Unable to explain the 'why' of water ballast to increase=20
=20
Gene Whitt
buy glider, put water in, launch, do 100 knots, note sink rate, dump
water, land, fly, do 100 knots note sink rate, job done
Rgds,
Derrick Steed
Old October 11th 05, 11:51 PM
Jim Kelly
Thermalling stores energy in the glider, but thermals stop at
cloud base. Water carried needs to be lifted too, thus more
energy can be harnessed.
jk
nk.net...
Y'all,
increase
Gene Whitt
Old October 12th 05, 02:30 AM
Gene Whitt
Thanks everyone. Now for a 'yes' or 'no' answer to my follow-up
question.
Does the addition of weight have the same effect on airplanes with power off
and prop stopped as on gliders but at a less efficient level.?
Gene
Aside: I once dove a C-150 to 120 mph before stopped prop
would start the engine,
Old October 12th 05, 03:58 AM
A sled is a gravity-powered machine. A glider is solar
powered.........
Leon McAtee
Airbus A380 water purification john smith Piloting 1 July 7th 05 02:50 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
