Runway Numbering - Radio Procedure
Old October 21st 05, 03:03 AM
Icebound
Default Runway Numbering - Radio Procedure
"John T" wrote in message
m...
"Mike W." wrote in message
If you hear 'runway zero', then you know you have missed something in
the transmission.
Similarly, if you're in the pattern for runway 20 and you hear somebody
announce "[your airport] traffic, N123 base, runway 2[garbled]", you can
assume you've missed something. You still haven't made a case for using
anything but the numbers painted on the runway.
Well, yes, the case is easy to make.
If everybody used the leading zero all the time, then you KNOW FOR SURE
anytime you hear less than two digits, then you have missed something.
If the leading zero is NOT used and you hear only ONE digit, then you have
no way of knowing whether you missed something, or not.
Shortening a direction-based entity in this way is unnatural and causes
confusion. Even the FAA's own NACO chart-selection web site, uses the
leading zeros in the index, and then omits them on the charts..
Old October 21st 05, 04:32 AM
Jose
Why does announcing "Runway Two Zero" allow the last digit to be cut off
while announcing "Runway "Zero Two" prevents the last digit from being cut
off?
It doesn't. It prevents the last digit from being cut off =unawares=.
It acts as a checksum of sorts. If all runways are two digits, then any
transmission missing a digit is suspect. If some are one and some are
two, then there are some cases where an error would not be noted; this
is especially the case with runway 2-20, both of which exist on most
airports for which one exists.
Jose
Money: what you need when you run out of brains.
Old October 22nd 05, 04:10 AM
Jose
I once flew to an ratehr rundown airport with a 2-20. The Unicom was
so badly garbled that I even after asking Unicom to "say again" three
or four times, I had no idea whether the guy was saying "zero two" or
"two zero."
"Runway one plus one, or runway ten plus ten?"
Jose
Old October 22nd 05, 04:17 AM
vincent p. norris
.... this is especially the case with runway 2-20, both of which exist on most
"two zero."
No wind tee, wind sock to bedraggled to make out from pattern
altitude.
Based on winds in the general area, I suspected he was saying "zero
two" so I asked him "Runway 2?" and he came back with the same number
of garbled sylables as before.
Hearing no other traffic after two circuits, I finally just landed on
runway 2 and tried to teach the guy how to announce runways.
Had he said "Runway two," I would have known from the number of
syllables which runway he meant.
vince norris
Old October 22nd 05, 04:57 AM
Steven P. McNicoll
"Jose" wrote in message
It doesn't. It prevents the last digit from being cut off =unawares=. It
two, then there are some cases where an error would not be noted; this is
especially the case with runway 2-20, both of which exist on most airports
Wouldn't the gap in the transmission do that?
Old October 22nd 05, 06:26 AM
Jose
Maybe. But not certainly. People don't always speak with the same
cadence, so time is a poor checksum.
Jose
Old October 22nd 05, 02:10 PM
Steven P. McNicoll
If you hear 'runway zero', then you know you have missed something in the
transmission.
Two things, actually, the runway and the airport.
Old October 22nd 05, 03:09 PM
Jose
transmission.
Yes, but missing the airport does not imply a transmission error. The
airport simply may not have been transmitted. Poor form, but not a data
error.
Jose
Old October 22nd 05, 05:15 PM
Joe Johnson
Hi Jose. I like your checksum argument. It's two digits for me from now
on, and we should urge everyone to adopt this convention.
Old October 22nd 05, 05:21 PM
Jose
It's actually somebody else's idea, though I recognized it as like a
checksum. However, "zero two" and "two zero" can be confused with each
other even when each is clearly heard.
You've all heard of the dyslexic agnostic insomniac? He stayed up all
night wondering if there really was a dog.
Jose
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 06:23 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 03:33 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
