Turn co-ordinator
Old November 2nd 05, 01:43 AM
Bill Zaleski
Default Turn co-ordinator
I never said that you will get "green line "vacuum. I did say that
the gyro's will continue to work with the vacuum that you will have
with a windmilling engine. Go to 10K, windmill, and see that you still
have useable gyro's. Been there, done that, they still work.
On Tue, 01 Nov 2005 11:48:38 GMT, Jon Kraus
You think wrong Bill. At least on my Mooney at idle doesn't come close
to the vacuum gauge reading in the green. This is with a new dry pump
too. I still doubt that a windmilling engine will keep the gyros spooled
up enough to run the AI and DG. Just my .02. YMMV
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Bill Zaleski wrote:
You think wrong, Jon. Even at idle, most vacuum pumps produce enough
differential to keep rotors spinning satisfactorily.
Old November 2nd 05, 03:46 PM
Mark Hansen
How long did you windmill? After all, the gyros are going to
continue to spin for some time with no vacuum. The slower they go,
the more difficulty they're going to have.
Did you go for more than 5 or 10 minutes and verify that they were
still working acceptably?
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old November 2nd 05, 04:28 PM
Bill Zaleski
Yup. Right to the ground from 10K' bout 800FPM
Bill Z. A&P I.A.
On Wed, 02 Nov 2005 07:46:24 -0800, Mark Hansen
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Old November 2nd 05, 04:33 PM
John R. Copeland
"Mark Hansen" wrote in message ...
My gyros spin up from stopped to a usable state while my engines idle after startup.
Don't yours?
Old November 2nd 05, 04:48 PM
Mark Hansen
Don't yours?
What is usable? The AI usually doesn't straighten-up 100% until after
I do my static run-up.
However, the real sign is the vacuum gage. It reads below the green while
idling. Now, the gyros are still spinning even while the vacuum is not
in the green - but I wouldn't want to bet my life on them while in IMC
conditions ... I may have to, but I wouldn't assume they are working 100%
while the vacuum is below the green.
Sacramento, CA
Old November 2nd 05, 05:02 PM
John R. Copeland
Don't yours?
Roger that.
Do you have any possibility of changing to a higher-capacity vacuum pump?
(I assume your instrument filters aren't clogged, of course.)
I show 5 inches Hg of vacuum at engine idle in my airplane.
Old November 2nd 05, 06:03 PM
Mark Hansen
Don't yours?
Roger that.
Naw, Rental. C-172M
Sacramento, CA
Old November 2nd 05, 10:18 PM
Ron Natalie
Don't yours?
You would hope so, because otherwise you're going to be in deep doodoo
climbing up into the soup shortly after takeoff.
Old November 2nd 05, 10:19 PM
Ron Natalie
Probably not the run-up but the elapsed time. It takes on the order of
ten minutes for the gyros to stableize.
idling.
Fix your pump.
Old November 2nd 05, 10:41 PM
Newps
Then you got a bad gyro. My AI shakes like a son of a bitch for about
10 seconds and then settles down in the upright position. Idles speed
about 900. Vacuum gauge will be bottom of the green at 1000 rpm.
Change in AIM wording concerning procedure turn Kris Kortokrax Instrument Flight Rules 208 October 14th 05 12:58 AM
"Proceed on Course" = "Right turn approved"? Bob Chilcoat Piloting 41 July 18th 04 11:48 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Rate of turn indicator on commercial jets (Boeing / Airbus) Mark Simulators 1 November 1st 03 10:35 AM
