Hi all,
I am familiar with the inclinometer and turn co-ordinator of the Cessna and how to use it to establish the correct bank angle for a standard rate turn. Regardless of the IAS, I can perform a standard rate turn by setting a bank angle that matches the standard rate turn on the turn co-ordinator. In the Airbus (A330, for example), how is a standard rate turn performed? What instrument is used? I guess, I also have the same question for the Boeing... I am a newbie, so go easy. :-) Thanks Mark |
A rate one turn is a heading change of 180 degrees in one minute.
The angle of bank required for a rateone turn is 10% of the airspeed plus seven if you are using konts or five if you are using mph. I.E. for an airspeed of 100 kts the bank angle should be 17degrees for a rate one turn (15 degrees for 100mph). Airline flying is all about passenger comfort. At 300kts the AOB would have to be 37degrees which be too steep so a max of 25 degrees is used and it is accepted that this will be less than rate one at speeds above 180kts. Consider also trying to do a rate one turn in Concorde at Mach 2 / 1340mph. according to the formula the AOB should be 139degrees! Simon -- E-mails to the return address will not be read. E-mails can be sent to jodel at tiscali dot etc for a UK company. "Mark" wrote in message om... Hi all, I am familiar with the inclinometer and turn co-ordinator of the Cessna and how to use it to establish the correct bank angle for a standard rate turn. Regardless of the IAS, I can perform a standard rate turn by setting a bank angle that matches the standard rate turn on the turn co-ordinator. In the Airbus (A330, for example), how is a standard rate turn performed? What instrument is used? I guess, I also have the same question for the Boeing... I am a newbie, so go easy. :-) Thanks Mark |
| Thread Tools | |
| Display Modes | |
| Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 03:39 AM |
