New Mexico Fire-Devils
Old December 5th 05, 01:02 PM posted to rec.aviation.soaring
Default New Mexico Fire-Devils
Bob Korves wrote:
Marc Ramsey wrote in
. net:
http://vortexengine.ca/
Wanna buy a bridge to go with that Atmospheric Vortex Engine?
-Bob
Quite. The Solar Chimney technology (trialled in Spain and, I think,
currently being worked on in Australia)
http://www.globalwarmingsolutions.co...ar_chimney.htm
looks likely to be much more efficient.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old December 5th 05, 01:16 PM posted to rec.aviation.soaring
I can think of the following reasons why a visibly rotating dust devil =
can end in an apparently spin-less cloud:
1. The angular momentum carried in a dust devil is partially dissipated =
to the neighbouring air through the normal momentum transfer mechanisms =
that occur in all fluid flows, and very strongly in turbulent flows.
2. A rising thermal collects a large amount of surrounding air, =
especially in its final (or higher) stages. This incorporated air likely =
has statistically random angular momentum, thus diluting the specific =
angular momentum in the whole thermal.
3. The thermal widens and the rotation speed drops by the inverse square =
of the radius.
4. The angular velocity drops by the inverse cube of the radius.
So a ten metre wide dust devil rotating once every two seconds can turn =
into a two hundred wide cloud rotating once every sixty hours, without =
violating any physical laws.
Regards
Old December 5th 05, 01:24 PM posted to rec.aviation.soaring
Oops! Made a mistake in point 4 of previous message.
So, where I wrote "once every sixty hours", please
read "once every six hours".
The cloud will anyway seem devoid of rotation to any human observer.
Regards
Old December 5th 05, 02:46 PM posted to rec.aviation.soaring
The idea looks to be interesting, although the problems in producing a
chimney
with a height of 1000 metres would be interesting. :-(
And more importantly, isn't this a bit high for a first thermal off of the
launch? ;-)
Be nice to have a dedicated thermal just off the runway though!
Malcolm...
"Martin Gregorie" wrote in message
. net:
-Bob
gregorie. |
Old December 5th 05, 09:01 PM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
There are some very optimistic people working on a 1000m high chimney in the prime soaring country north of Mildura, Australia at this very moment.
I asked the question on our aussie site if it could be used as a thermal generator for gliding, everyone was confident it would be no problem BEFORE twin towers 911, not now.
Another good one George, thanks.
Old December 6th 05, 01:08 PM posted to rec.aviation.soaring
I certain I've read that, on a calm day, if you lie on your back and
cloud watch, you CAN see them rotate, just very slowly.
Can't remember where I read that, though.
gregorie. |
Inside the Cowling Fire / Heat Detector? George Sconyers Aviation Marketplace 4 May 31st 04 01:40 AM
"Friendly fire" Mike Naval Aviation 3 April 6th 04 06:07 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 05:02 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
"Friendly fire" Mike Military Aviation 0 March 19th 04 02:36 PM
