#11
On 17 Dec 2005 09:45:07 -0800, "nrp" wrote in
.com:: "in an ideal gas the sonic velocity depends only on the molecular weight and the absolute temperature (degF + 460), and is proportional to the square root of that absolute temperature". In which units does that equation provide the sonic velocity? More he http://roger.ecn.purdue.edu/~aerodyn...Lecture06.html |
When I took thermo, there were only ft lbs, BTUs, and lbm. It was a
lot simpler before Metric became PC. (I wonder how we happened to keep seconds?) |
![]() "nrp" wrote in message oups.com... When I took thermo, there were only ft lbs, BTUs, and lbm. It was a lot simpler before Metric became PC. I found the MKS system to be simpler. |
nrp wrote:
When I took thermo, there were only ft lbs, BTUs, and lbm. It was a lot simpler before Metric became PC. (I wonder how we happened to keep seconds?) You must be REALLY old as the SI system has been around at least since 1875. :-) Matt |
On 17 Dec 2005 12:07:43 -0800, "nrp" wrote in
.com:: When I took thermo, there were only ft lbs, BTUs, and lbm. So you don't know if your equation expresses sonic velocity in knots or MPH? |
In hotter air the molecules can move faster, so they carry disturbances
(sound waves) faster. In denser substances such as water and steel, the molecules do not move far from a central point so the increased temperature does not give them the opportunity to transmit the sound disturbance at a faster rate when heated. However, because of the greater density and the fact that molecules are closer together in water and steel than in air, sound does travel faster in water and steel than in air. The closer the molecules are together, the more quickly a disturbance is transmitted from one molecule to another. Larry Dighera wrote: On 17 Dec 2005 12:07:43 -0800, "nrp" wrote in .com:: When I took thermo, there were only ft lbs, BTUs, and lbm. So you don't know if your equation expresses sonic velocity in knots or MPH? |
speed record set by scramjet - fair? | Don French | Piloting | 55 | November 28th 04 01:57 PM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Kestral 1000 Wind Speed Meter NEW IN BOX | Cecil E. Chapman | Products | 0 | November 7th 03 06:56 PM |
