Discus polar curve at high speeds
Old December 19th 05, 09:19 PM posted to rec.aviation.soaring
Default Discus polar curve at high speeds
If "something goes bang" it is either because of a) flutter or b)
extreme drag forces when extending airbrakes at extreme speeds.
Which are the known incidents of gliders fluttering to bits?
(apparently Dirks parachuted from the DG-600 prototype after wing loss,
also almost loosing his eyeballs in the process...)
Karl
Old December 19th 05, 09:39 PM posted to rec.aviation.soaring
Gary Emerson wrote:
I'm taking a wild guess here, a hypothesis only...
If you exceed VNE can you divide the failure causes into two families?
Structural and Flutter?
Ok, discount Flutter for the moment and consider only a structural failure.
If you are in moderate dive, the wings still have to support the weight
of the glider and therefore you have higher drag because the wing is at
some positive angle of attack.
However, if you are in a near zero G pushover, the wings are unloaded
vertically and therefore you are at a minimum drag condition from an AoA
standpoint. Then, if there is no flutter, you might get well beyond VNE
before something goes bang..
To go from level flight at 125 knots to 250 knots would require losing
over 2000 feet in this zero lift flight, much of which would vertical. I
have to wonder how a pilot could resist pulling back on the stick or
opening the spoilers for such a long distance! And how carefully he'd
have to fly to avoid G forces that would remove the wings; after all,
this maneuver isn't in the usual glider training syllabus.
Eric Greenwell
Washington State
USA
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Control Reversal in WWII Eunometic Military Aviation 14 June 27th 04 01:03 PM
Cambridge 302 -or- Borgelt B50 plus data logger Romeo Delta Soaring 25 May 30th 04 09:50 AM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 03:31 AM
