Control Reversal in WWII
Old June 20th 04, 04:43 AM
Eunometic
Default Control Reversal in WWII
In discusing the characteristics of how the Me 109K should be flown
against the P51 Mustang and P47 the issue of control reversability
came up. Would someone be able to expand on control reversability.
The Me 109 G10 and Me 109 K4 (G14 was a stopgap due to engine delays
in the G10)had a powerfull engine that allowed them to do a speed of
458mph and outclimbe all allied aircraft. However the old crate had
an old wing section that created enormous aileron forces for the
pilot; also becuase the the small Me 109 cockpit a pilot could
generate only 40lbs of joystick force could have generated 60lbs of
force in a P51. As a result only 2-3 degree of airleron deflection
was possible at 400mph the 109 had a roll rate of 45 degrees/second.
A FW190A and even a P47 could have managed nearly 180 degrees in that
time.
The issue of control reversability then came up. If power ailerons
were fited to the Me 109 they would have allowed a greater deflection
but would this have caused control reversability at some point as the
wing twisted and the ailerons acted more like trim tabs?
What causes reversability? Why is a slab elevator sometimes used?
I've also heard of WW2 pilots using trim tabs to pull out of a dive or
get an aircraft rightway up. What were they doing?
The P38 had a smaller turning circle than the Me 109 (presumably at
lower speeds of around 300mph) but its roll rate was even worse than
the 109 and this is how 109s escaped P38s and I note that some late
war P38s received power controls.
Old June 20th 04, 05:33 AM
Orval Fairbairn
time.
Two things: You hit the first one above: aeroelasticity.
The second is localized Mach 1+ velocities, which can cause shockwaves
on the upper surface of, say, a wing. The result is a pressure higher
than that on the bottom surface. A subsequent dive results.
Even modern aircraft can suffer from #2. If they cruise at very high
altitude, where their critical Mach number is near cruise and stall is
close, too, any changes in velocity have to be within those limits, or
an uncontrolled descent is in the works, until Mach number recedes, or
the ground intervenes.
Old June 20th 04, 04:43 PM
Eunometic
"Orval Fairbairn" wrote in
message
news
flown
reversability.
delays
of
had
of
deflection
degrees/second.
that
time.
ailerons
deflection
used?
Thanks, you've given me some terms I can use to do further research.
shockwaves
higher
is
or
or
Like the U2. There is a sailplane called Perlan which will
experience this coffin corner phenomena soon,
Old June 20th 04, 09:36 PM
W. D. Allen Sr.
The Navy FJ-3 Fury carrier based fighter of the late 1950s suffered from
control reversal. In a dive as it approached Mach 1 when the stick was put
over to one side the plane rolled rapidly, but in the opposite direction
from that intended! The FJ-3 ailerons extended out to the tips the wings.
Consequently at near sonic Mach putting the aileron down resulted in the
wing warping such that the net lift force was opposite to what was expected.
The problem was fixed in the FJ-4 by designing the ailerons to not extend to
the wing tips.
Interestingly, The Navy FJ series fighters were an outgrowth of the famous
Korean War Air Force F-86, which in turn was an outgrowth of an earlier Navy
fighter, the FJ-1, a straight wing jet powered plane that the Navy deployed
in one squadron before going with the FH-1 (the granddaddy of the equally
famous Vietnam War F-4 Phantom). North American Aircraft Company made use of
Nazi World War II engineering test data to develop the swept wings they
fitted to the Navy FJ-1 to create the Air Force F-86. This is the same North
American Aircraft Company that built more World War II aircraft than all
other aircraft companies, the largest number being the B-25 medium bomber.
WDA
end
"Orval Fairbairn" wrote in message
news
time.
Old June 21st 04, 11:25 AM
Cub Driver
On Sun, 20 Jun 2004 14:39:59 GMT, "Eunometic"
From what i understand: the Cub has a tailplane that changes angle as
well as having elevators.
Yes, that's right. Forget I spoke!
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
Old June 20th 04, 07:13 PM
Darrell
The B-47 had neutral aileron control at about 425 knots (as I seem to
remember). Above that speed it rolled in the opposite direction than the
control input. It was because of the flexible wing. Approaching 425 (if
that's the right speed), the roll produced by aileron input reduced to no
roll at all at 425, then it would roll opposite the control input above 425.
It was, as you noted, because, above 425, the aileron served merely as a tab
which ended up twisting the overall wing in the opposite control direction.
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Eunometic" wrote in message
om...
time.
Old June 21st 04, 04:55 PM
Lynn Coffelt
"Darrell" wrote in message
news:FAjBc.20218$ey.9317@fed1read06...
425.
tab
direction.
I believe that the B-47 aileron control characteristics you mention are
close to the facts, and I recall that the "red-line" speed vs roll control,
was handled in a rather unusual manner.
During the late 1950's, some B-47 units were tasked to fly low level
"LABS" missions. At some speed near the "red-line" (it could have been 425,
it was long ago!), the wing twist would cause one wing or the other to
become increasingly "heavy", and increased roll trim would have to be
cranked in to maintain level flight. Each aircraft was slightly different
than others, so an aileron rerigging program was begun, to rerig all ships
ailerons to near perfection and then test fly each one to determine how much
aileron trim was required to maintain level flight at some speed (I thought
it was higher than 425, but hey, that was in maybe 1958 or so). Then, if
more than 20 (?) units of trim were required, the aileron of the "heavy"
wing was carefully rerigged a couple of degrees below neutral, and the test
flight was repeated.
This process went on until all the 303rd Bomb Wing ships except one met
the new criteria. The one that did not respond got a meticulous (sp?)
alignment check, and one wing was found to have a permanent twist, exceeding
the -3 structural manual's service limits. Deep down in the procurement
documents it was found that that particular ship's right wing was out of lim
its when accepted by the AFPRO from Boeing.
Old Chief Lynn
Old June 21st 04, 05:40 PM
Lynn Coffelt
425.
tab
direction.
Old Chief Lynn
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 09:48 PM
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 03:20 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 08:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 08:31 PM
