AUTOPILOT AWRY
Old February 15th 06, 12:12 AM posted to rec.aviation.owning
Default AUTOPILOT AWRY
Hi James,
Thanks for your feedback. I think we are talking about two different
generations of Piper / Mitchell autopilots. Mine is an Altimatic II,
installed in a 1964 Piper Aztec. It obviously is original equipment,
factory installed. All the electronics are composed of germanium
transistors, so that also dates it.
My info all comes directly from the Piper Service Manual entitled
"Autocontrol I & II, Altimatic I & II Service Manual". The Piper part
number is 753 798 with a first publish date of June 1961. It contains
permanent revisions numbered PR710920 and PR721020, dated
September 20, 1971 and October 20, 1972, respectively. There are
also pages with various dates between these dates.
The 10Mhz frequency information is contained in the theory of operation
section and it describes in good detail the construction and operation of
the roll
vane in the AI. It shows it as being composed of an Iron Ferrite piece
on one side and of an Aluminum piece on the other. As the aircraft
banks to the Iron side, it says the inductance of the circuit is increased
and
when it banks to the Aluminum side, the inductance of the circuit decreases.
It also details a similar pickup in the AI for pitch and a variable
capacitor in
the DG, variable capacitors in the each servo's "follow-up" circuit and
variable
capacitors in the amplifier and control console. It goes step by step on
how
a change in bank and a change in pitch and altitude changes each reactive
component and how all of the these reactive components work together to
maintain a given resonant frequency.
Maybe the 10MHz figure is just an example - I have not measured the
frequency. However, the roll and pitch servos in my 1964 Aztec definitely
have the feedback or "follow-up" capacitors. I've seen them with my own
eyes
and checked their timing marks to see if they are lined up properly.
There are RF type variable capacitors in the control console and in the
console
amplifier to adjust the circuit reactance (level the wings and level the
pitch). There
is also an RF type variable cap in the altitude bellows assembly to detect a
change
in pressure altitude. The trim-turn and pitch controls on my control
console are
also variable caps, along with an altitude / pitch offset adjustment.
The amp has two cans which look like IF transformers with paper labels on
them
that state "Do not adjust discriminator". The whole thing is connected
together
with coax cables and the service manual is clear about using the proper
length
and type of cables otherwise the resonant frequency will be shifted. The
service
manual shows a drawing of these cable as being composed of a hollow tube
that
contains a curly wire on the inside and a braided shield on the outside.
The whole
thing is covered with an outer jacket of rubber or plastic material. It
reminds me
of the radio antenna coax used in automobiles in the 1960s.
When I went looking for an instrument shop to overall my AI, I ran into
several that
stated they would not work on "those old RF type gyros". All of this taken
together
makes me believe that the system does in fact use an RF signal as the method
to detect changes in pitch and bank and to detect the position of the
servos.
From the limited information I can find, it appears that the later Mitchell
/ Piper
versions switched to the pickup system that you describe. Maybe this was
Autocontrol IIB / Altimatic IIB and later versions? I don't know.
I wish I had a schematic of my console amplifier. My service manual is
lacking
in this area. It treats the amplifier as a black box. It does provide a
schematic
of the radio coupler, but no theory of operation information, or other
useful info
like the excitation frequency it supplies to the DG, voltage levels, etc.
Any
information you'd care to share along those lines would be greatly
appreciated.
Just FYI, the earliest Autocontrol and Altimatic systems used what the
service
manual refers to as a "0" heading directional gyro. This device did not
allow a
specific heading to be selected, but rather just indicated a change in
heading which
was used to keep the wings level. Also, these early models had amplifier
modules
attached to the back of the AI and to the back of the DG. There was no
central
"console" amplifier. When I first got the service manual and saw this, I
knew these
didn't exist in my airplane and thought there were missing components.
However,
as I dug in more, I finally figured out that these were consolidated in a
later version
and that the DG was changed to a resolver type wired to the radio coupler
rather
than the older RF type wired to the autopilot amplifier.
What is the excitation frequency of the radio coupler to the DG in the later
Mitchell /
Piper autopilots? Maybe it is the same in mine.
FYI, my coupler has a 4-pin Amphelnol connector for the radio input and a
9-pin Amphenol connector for connection to the DG and autopilot amplifier.
In my case, the coupler could not be eliminated from the system by simply
moving connectors around.
I'd be happy to learn all you're willing to teach me about these things. If
you have
any schematics or theory of operations on the early Autocontrol / Altimatic
I/II
amplifiers and/or on the early radio couplers, I'd really appreciate getting
a copy.
Ronnie
"jmk" wrote in message
Hmmm... I have to admit, that's quite a bit different than a standard
Autocontrol (aka Century) for a normal Piper system - and I would ask
if you are sure of your information? The standard "wing level"
indication from the AH is indeed off a pickup coil, but it's about 5
KHz, no RF. And there is no frequency shift - the inside of the
Century AH/AI just has two coils and a metal plate behind them (looks
like an iron butterfly). As the thing shifts from one side to the
other you get a shift in amplitude, either in phase or out of phase
(180 degrees) with respect to the ROLL EXCITATION signal. [Or the HDG
EXCITATION signal, if it goes through the nav coupler.] With the AH
centered in roll, the amplitutde is zero. There is no frequency shift
regardless. It would be great if there was some sensor back from the
ailerons, but there isn't - so it has no way of knowing their position.
Having said all the above, your "list of the usual suspects" is the
same one I would come up with. #3 is the one that surprises most
folks, but if you have a nav coupler then it uses HDG EXCITATION to
drive the ROLL coils, so lose of HDG signal affects just operating in
the WINGS LEVEL mode. You can move the ROLL cable that goes from the
computer to the NAV Coupler to go to the AI instead and restore use of
ROLL EXCITATION for a test.
Old February 15th 06, 02:37 PM posted to rec.aviation.owning
Clearly that is quite different. I suspect that RFI may have been one
of the reasons they went to the much lower frequencies...
and a 9-pin Amphenol connector for connection to the DG and autopilot
amplifier. In my case, the coupler could not be eliminated from the
system by simply moving connectors around.
Too bad. With the Century (aka Autocontrol) units the basic "computer"
plugs in to the AH and you have wing leveler capability. If you have
the right DG (i.e. with the heading bug) then a second cable plugs into
the DG and you now have heading control as well. [Hence the separate
ROLL EXCITATION and HDG EXCITATION.] When they added the little NAV
Coupler unit, all that was needed there was to unplug the computer's DG
cable from the DG and plug it into the NAV Coupler. The NAV coupler
then had a cable that went out to the DG.
With the NAV Coupler in HDG mode, it was essentially then just a
pass-through. The DG signals basically went through the NAV Coupler as
if it was nothing but an extension cord. [Except, as another poster
mentioned, the NAV Coupler still generated a new version of the
EXCITATION signal.]
With the NAV coupler in tracking mode, it simply took the DG offset,
played the same "in/out of phase" game that the computer normally would
to provide an offset, added in the offset from whatever L-R signal it
was tracking, chopped it back up, and sent the new sine wave back to
the computer. The computer never knew it was tracking anything but the
DG heading bug. [BTW, all the nav coupler tracking modes are just
variations on a theme. The LOC mode (Localizer) just has a different
divider resistor on the L-R so the sensitivity is changed. The OMNI
vs. NAV mode just adds a capacitor to slow up it's ability to respond
to quick changes in the L-R signal. And the LOC Backcourse? Yup...
the switch just switches the L-R input wires so that it responds
backwards.]
[I'd be happy to learn all you're willing to teach me about these
things. If you have any schematics or theory of operations on the
I/II amplifiers and/or on the early radio couplers, I'd really
appreciate getting a copy. ]
A while back I scanned in the schematics for the Autocontrol computers
and the NAV coupler. I don't know if they are still around or not
(really poor quality originals). I'll try to see if I can find them.
Old February 18th 06, 09:58 PM posted to rec.aviation.owning
Looking forward to your findings Bill. Reason being, the Autocontrol
III in our Arrow only works in heading bug mode. I'm interested to know
how much time/money you wind up putting into your repair. It would be
nice to have ours work in all modes but I'm not so sure I'd want to
spend more than a couple tenths of an AMU on it.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old February 18th 06, 10:26 PM posted to rec.aviation.owning
Sheesh - can you even get a tire changed for that much?
.... by the way, it costs me nuthin' to get a tire changed ;-)
On the other hand, the mixture control is bottoming out against the firewall
and the maintenance folks believe this is working correctly ;-\
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 19th 06, 12:51 AM posted to rec.aviation.owning
Dunno...but will find out soon as the nose wheel is due. Stay tuned.
Hehe...ya, and you don't need to wipe bugs off the plane after each
flight either. OTOH, I can be a hangar rat whenever I want. :-)
firewall
Hmmm, I like our maintenance program better, even if we can't get a tire
changed for free :-)
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 19th 06, 01:09 AM posted to rec.aviation.owning
Oh, it's true, it's true ... I have no hangar
firewall
I can't argue with that.
Sacramento, CA
Old February 19th 06, 10:21 PM posted to rec.aviation.owning
Are you saying it doesn't work in ROLL mode, but does work in HDG mode?
Unusual, but if so then it's a pretty simple fix. The HDG switch
essentially disables the ROLL pot, so if it works okay in HDG but not
in ROLL, then either the switch is bad, or the POT is bad, not much
else involved.
Old February 20th 06, 12:04 AM posted to rec.aviation.owning
else involved.
Sorry, I should have clarified. Heading mode works, roll works (sort
of, I'll explain in a sec.). It is the other modes (NAV, OMNI, LOC, LOC
back course) that don't work.
For roll mode, if I turn the round roll knob slightly one direction, the
ailerons keep moving to the stops. If the knob is centered though, the
ailerons stay centered. I've only tried this on the ground. In the
air, heading mode works fine but none of the other modes mentioned above.
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 21st 06, 11:50 PM posted to rec.aviation.owning
I thought that is the way it is supposed to work on the ground. I thought,
and I might be wrong on this, that the roll pot set a desired angle of bank,
not a desired aileron position. Next time I have some time, I will check
this out.
Just another data point for consideration: My auto pilot was not working
right on my arrow when I bought it ( or should I say it always worked
"right"). It would turn to the right in VOR/LOC modes. I had the shop look
at it along with other items on my squawk list. They fixed it with no parts
and about an hour of labor. I don't know what the problem was. Just goes to
show you that autopilots are not always expensive to get fixed. It is
definitely worth having someone look at it.
"Jack Allison" wrote in message
else involved.
Sorry, I should have clarified. Heading mode works, roll works (sort of,
I'll explain in a sec.). It is the other modes (NAV, OMNI, LOC, LOC back
ailerons stay centered. I've only tried this on the ground. In the air,
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
- Leonardo Da Vinci
Old February 22nd 06, 07:19 AM posted to rec.aviation.owning
else involved.
That's OK - the autopilot rolls till the roll feedback
from the horizon gyro matches the request from the pot.
You're ordering a certain amount of roll. If the horizon
does not follow, turn more on the ailerons till the order
is fulfilled.
Tauno Voipio (CPL(A) - avionics engineer)
tauno voipio (at) iki fi
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 04:06 AM
mitchell autopilot dave Owning 1 May 5th 04 06:11 PM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 07:17 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 03:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
