I have a piper Arrow and out of the blue...(no pun intended)... the
Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
First, what is the make and model of the autopilot?
For my respsonse, I'll assume you have a Piper autopilot, which is based on the Edo-Aire / Mitchelle designs. In general, a hard bank to one side indicates that that roll servo is being driven that direction by the amplifier. (Obvious, uh?). The question is why. In my Piper Altimatic II, the roll servo is a motor that is driven by an H-Bridge type of amplifier. This input to the final motor driver amplifier is a left / right signal which is derived from the difference in the heading bug and indicated heading, and if in NAV, OMNI, LOC or REV LOC mode also the left / right signal from the nav output. Therefore, your trouble could be in the console amplifier itself or the input(s) to the amplifier. If the alierons are driven to their mechanical limits, I'd suspect a bad transistor in the console amplifier output stage (H-Bridge). If the alierons are driven to their maximum bank position but not the their mechanical limits, (usually about 30 degrees of bank), then I'd suspect a stage before the final amplifier. Since this happens in heading mode, the problem could the the resolver in the DG, or any of the electronics in the autopilot console amplifier or the radio coupler. Ronnie "William Snow" wrote in message ... I have a piper Arrow and out of the blue...(no pun intended)... the Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
Ronnie
It is an Autocontrol II B with HSI. I only tested it in the Hdg mode sine I had a passenger and did not want to alarm him. When the weather clears I will give it a test in the other modes to try and isolate the problems/mode. Thanks for the tips. Bill "Ronnie" wrote in message . com... First, what is the make and model of the autopilot? For my respsonse, I'll assume you have a Piper autopilot, which is based on the Edo-Aire / Mitchelle designs. In general, a hard bank to one side indicates that that roll servo is being driven that direction by the amplifier. (Obvious, uh?). The question is why. In my Piper Altimatic II, the roll servo is a motor that is driven by an H-Bridge type of amplifier. This input to the final motor driver amplifier is a left / right signal which is derived from the difference in the heading bug and indicated heading, and if in NAV, OMNI, LOC or REV LOC mode also the left / right signal from the nav output. Therefore, your trouble could be in the console amplifier itself or the input(s) to the amplifier. If the alierons are driven to their mechanical limits, I'd suspect a bad transistor in the console amplifier output stage (H-Bridge). If the alierons are driven to their maximum bank position but not the their mechanical limits, (usually about 30 degrees of bank), then I'd suspect a stage before the final amplifier. Since this happens in heading mode, the problem could the the resolver in the DG, or any of the electronics in the autopilot console amplifier or the radio coupler. Ronnie "William Snow" wrote in message ... I have a piper Arrow and out of the blue...(no pun intended)... the Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
As you've been told, lots of things in the path between what's
happening and where it may have started. To isolate some of them out: 1. First try it in ROLL mode. If it still fails, then it's almost certainly in the "computer" (the black box with the ROLL knob on it). See if you can get the ROLL knob to have ANY effect in this mode. 2. If it works in ROLL mode, but not in HDG, then try bypassing your NAV coupler. [This just requires unplugging two cables and plugging one back in.] You also likely have an HSI - NAV adapter that could be bad. 3. If the info from your AH is bad, then it will roll no matter what (but you might be able to offset it, or at least slow it down, with the ROLL knob in ROLL mode). Those Tyco (AMP) connectors are not very reliable. Try plugging and unplugging the one between your AH and your "computer" several times (and make sure it is plugged in good and locked). After all that, if even in ROLL mode it insists in rolling oncontrollably, then you've got a bad computer. You might check for broken wires on the rear connector housing, or even removing and re-inserting it a time or to - but most likely it needs to go back in for service. Century no longer services them, but several other places do. It's just some simple analog transistor discrete stuff... nothing high tech. |
William,
The Autocontrol II is equivalent to my Altimatic II, the difference being the altitude control in the later. I'm not sure how the Autocontrol II B differs from the orginal Autocontrol II, so some of this information may not be correct. The roll circuit is picks off bank information from the attitude gyro via a RF pickup coil. This pickup is a small coil which helps to determine the resonant frequency of an RF oscillator in the roll amplifier. There is a "follow-up" capacitor on the roll servo that indicates the position of the alierons. The turn trim or roll knob on the console is another reactive component in this circuit. With the wings level, attitude indicator level, and turn tirm centered, all these reactive compoents are centered up and the circuit is operating at it center frequency. If any one moves, the resonant frequency of the roll circuit changes. There is a frequency discriminator in the console amplifier that produces a DC output when the frequency moves above or below the normal operating frequency. This DC output is amplified and used to drive the roll servo motor left or right. In heading mode, the radio coupler takes information from the resolver (heading bug) in the DG and feeds that into the console amplifer as a DC signal between the discriminator and the output amplifier stage. When in NAV, OMNI, LOC, or REV LOC modes, the radio coupler mixes in a left / right signal from a nav radio source. If the uncommanded roll happens in heading mode, then none of the radio nav modes are going to be any better. They will have the problem too. Therefore, an uncommanded roll could be caused by: 1. Bad pick up in the attitude gyro. 2. Bad resolver in the DG 3. Bad radio coupler (yes, even in HEADING mode). 4. Bad console amplifier 5. Lack of feedback or "follow-up" signal from the roll servo 6. A loose connection between any of these components. As others have suggested, check all the connectors by reseating them a couple of times. If that does not work, you'll need to determine which component has failed. Without a means to substitute a known good unit or test signal for each of these, isolating which component has failed bad may not be easy. When I posted a query about my old autopoilot, the kinds folks on the net had these recommendations for shops: "Contact the folks at http://www.bevanrabell.com Not sure about now, but they used to work on ALL the old stuff... No longer works some of the older stuff, but may be able to point you to a shop that does: Bob Ferguson, Autopilots Central at Sparks Aviation, Tulsa, OK " Good luck and let us know what you find out. Ronnie "William Snow" wrote in message news ![]() Ronnie It is an Autocontrol II B with HSI. I only tested it in the Hdg mode sine I had a passenger and did not want to alarm him. When the weather clears I will give it a test in the other modes to try and isolate the problems/mode. Thanks for the tips. Bill "Ronnie" wrote in message . com... First, what is the make and model of the autopilot? For my respsonse, I'll assume you have a Piper autopilot, which is based on the Edo-Aire / Mitchelle designs. In general, a hard bank to one side indicates that that roll servo is being driven that direction by the amplifier. (Obvious, uh?). The question is why. In my Piper Altimatic II, the roll servo is a motor that is driven by an H-Bridge type of amplifier. This input to the final motor driver amplifier is a left / right signal which is derived from the difference in the heading bug and indicated heading, and if in NAV, OMNI, LOC or REV LOC mode also the left / right signal from the nav output. Therefore, your trouble could be in the console amplifier itself or the input(s) to the amplifier. If the alierons are driven to their mechanical limits, I'd suspect a bad transistor in the console amplifier output stage (H-Bridge). If the alierons are driven to their maximum bank position but not the their mechanical limits, (usually about 30 degrees of bank), then I'd suspect a stage before the final amplifier. Since this happens in heading mode, the problem could the the resolver in the DG, or any of the electronics in the autopilot console amplifier or the radio coupler. Ronnie "William Snow" wrote in message ... I have a piper Arrow and out of the blue...(no pun intended)... the Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
Hmmm... I have to admit, that's quite a bit different than a standard
Autocontrol (aka Century) for a normal Piper system - and I would ask if you are sure of your information? The standard "wing level" indication from the AH is indeed off a pickup coil, but it's about 5 KHz, no RF. And there is no frequency shift - the inside of the Century AH/AI just has two coils and a metal plate behind them (looks like an iron butterfly). As the thing shifts from one side to the other you get a shift in amplitude, either in phase or out of phase (180 degrees) with respect to the ROLL EXCITATION signal. [Or the HDG EXCITATION signal, if it goes through the nav coupler.] With the AH centered in roll, the amplitutde is zero. There is no frequency shift regardless. It would be great if there was some sensor back from the ailerons, but there isn't - so it has no way of knowing their position. Having said all the above, your "list of the usual suspects" is the same one I would come up with. #3 is the one that surprises most folks, but if you have a nav coupler then it uses HDG EXCITATION to drive the ROLL coils, so lose of HDG signal affects just operating in the WINGS LEVEL mode. You can move the ROLL cable that goes from the computer to the NAV Coupler to go to the AI instead and restore use of ROLL EXCITATION for a test. |
Hi James,
Thanks for your feedback. I think we are talking about two different generations of Piper / Mitchell autopilots. Mine is an Altimatic II, installed in a 1964 Piper Aztec. It obviously is original equipment, factory installed. All the electronics are composed of germanium transistors, so that also dates it. My info all comes directly from the Piper Service Manual entitled "Autocontrol I & II, Altimatic I & II Service Manual". The Piper part number is 753 798 with a first publish date of June 1961. It contains permanent revisions numbered PR710920 and PR721020, dated September 20, 1971 and October 20, 1972, respectively. There are also pages with various dates between these dates. The 10Mhz frequency information is contained in the theory of operation section and it describes in good detail the construction and operation of the roll vane in the AI. It shows it as being composed of an Iron Ferrite piece on one side and of an Aluminum piece on the other. As the aircraft banks to the Iron side, it says the inductance of the circuit is increased and when it banks to the Aluminum side, the inductance of the circuit decreases. It also details a similar pickup in the AI for pitch and a variable capacitor in the DG, variable capacitors in the each servo's "follow-up" circuit and variable capacitors in the amplifier and control console. It goes step by step on how a change in bank and a change in pitch and altitude changes each reactive component and how all of the these reactive components work together to maintain a given resonant frequency. Maybe the 10MHz figure is just an example - I have not measured the frequency. However, the roll and pitch servos in my 1964 Aztec definitely have the feedback or "follow-up" capacitors. I've seen them with my own eyes and checked their timing marks to see if they are lined up properly. There are RF type variable capacitors in the control console and in the console amplifier to adjust the circuit reactance (level the wings and level the pitch). There is also an RF type variable cap in the altitude bellows assembly to detect a change in pressure altitude. The trim-turn and pitch controls on my control console are also variable caps, along with an altitude / pitch offset adjustment. The amp has two cans which look like IF transformers with paper labels on them that state "Do not adjust discriminator". The whole thing is connected together with coax cables and the service manual is clear about using the proper length and type of cables otherwise the resonant frequency will be shifted. The service manual shows a drawing of these cable as being composed of a hollow tube that contains a curly wire on the inside and a braided shield on the outside. The whole thing is covered with an outer jacket of rubber or plastic material. It reminds me of the radio antenna coax used in automobiles in the 1960s. When I went looking for an instrument shop to overall my AI, I ran into several that stated they would not work on "those old RF type gyros". All of this taken together makes me believe that the system does in fact use an RF signal as the method to detect changes in pitch and bank and to detect the position of the servos. From the limited information I can find, it appears that the later Mitchell / Piper versions switched to the pickup system that you describe. Maybe this was the Autocontrol IIB / Altimatic IIB and later versions? I don't know. I wish I had a schematic of my console amplifier. My service manual is lacking in this area. It treats the amplifier as a black box. It does provide a schematic of the radio coupler, but no theory of operation information, or other useful info like the excitation frequency it supplies to the DG, voltage levels, etc. Any information you'd care to share along those lines would be greatly appreciated. Just FYI, the earliest Autocontrol and Altimatic systems used what the service manual refers to as a "0" heading directional gyro. This device did not allow a specific heading to be selected, but rather just indicated a change in heading which was used to keep the wings level. Also, these early models had amplifier modules attached to the back of the AI and to the back of the DG. There was no central "console" amplifier. When I first got the service manual and saw this, I knew these didn't exist in my airplane and thought there were missing components. However, as I dug in more, I finally figured out that these were consolidated in a later version and that the DG was changed to a resolver type wired to the radio coupler rather than the older RF type wired to the autopilot amplifier. What is the excitation frequency of the radio coupler to the DG in the later Mitchell / Piper autopilots? Maybe it is the same in mine. FYI, my coupler has a 4-pin Amphelnol connector for the radio input and a 9-pin Amphenol connector for connection to the DG and autopilot amplifier. In my case, the coupler could not be eliminated from the system by simply moving connectors around. I'd be happy to learn all you're willing to teach me about these things. If you have any schematics or theory of operations on the early Autocontrol / Altimatic I/II amplifiers and/or on the early radio couplers, I'd really appreciate getting a copy. Ronnie "jmk" wrote in message ups.com... Hmmm... I have to admit, that's quite a bit different than a standard Autocontrol (aka Century) for a normal Piper system - and I would ask if you are sure of your information? The standard "wing level" indication from the AH is indeed off a pickup coil, but it's about 5 KHz, no RF. And there is no frequency shift - the inside of the Century AH/AI just has two coils and a metal plate behind them (looks like an iron butterfly). As the thing shifts from one side to the other you get a shift in amplitude, either in phase or out of phase (180 degrees) with respect to the ROLL EXCITATION signal. [Or the HDG EXCITATION signal, if it goes through the nav coupler.] With the AH centered in roll, the amplitutde is zero. There is no frequency shift regardless. It would be great if there was some sensor back from the ailerons, but there isn't - so it has no way of knowing their position. Having said all the above, your "list of the usual suspects" is the same one I would come up with. #3 is the one that surprises most folks, but if you have a nav coupler then it uses HDG EXCITATION to drive the ROLL coils, so lose of HDG signal affects just operating in the WINGS LEVEL mode. You can move the ROLL cable that goes from the computer to the NAV Coupler to go to the AI instead and restore use of ROLL EXCITATION for a test. |
Sorry if this is too obvious, but you are sure it is not actually in
wing-leveler mode with the wing trim turned off to the left? -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "William Snow" wrote in message ... I have a piper Arrow and out of the blue...(no pun intended)... the Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. Does it keep the wings level when NOT in heading mode? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I had a failure like this. It wasn't the computer but one of two
transistors in the location of the servo. The avionics guy told me they each process (?) turning signals and sort of balance each other out for level flight. If one goes, the other is free to bank the plane without a signal from the broken one to bring it back. Now his explaination wasn't the best and this was many years ago.....but that was my experience. In my situation, it would bank and never level out, I imagine I punched it off about 30 degrees or so, but it would have kept going. On the ground you can demonstrate the failure with the heading bug. But I have a seneca with a king autopilot and the parts were under the seats, computer in the tailcone. In case it helps.. John William Snow wrote: I have a piper Arrow and out of the blue...(no pun intended)... the Autopilot banked hard left (30 deg.) for no apparent reason. It was on Hdg Mode and the bug was centered. Each time it was shut off and re-engaged it continued to bank hard left. I have a long trip to FL planned over the school break and sure would like to have the Autopilot working. Does anyone know why this would happen? Thank You All. Bill Snow |
KAP140 autopilot and a KLN94 GPS question | STICKMONKE | Instrument Flight Rules | 5 | November 12th 05 04:06 AM |
mitchell autopilot | dave | Owning | 1 | May 5th 04 06:11 PM |
IMC without an autopilot | Jon Kraus | Instrument Flight Rules | 101 | April 18th 04 07:17 PM |
Chelton AP-3C autopilot | Kyler Laird | Owning | 0 | April 2nd 04 03:08 PM |
KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 02:01 AM |
