#11
Gotta wonder why the AWC icing page in ADDS offers the user to choose
between a graphic display of "all icing" and of "SLD icing" if Supercooled Liquid Droplets are not a hazard. The Roselawn accident (ATR-72, if I recall correctly), was attributed, in part, to SLD icing. Bob Gardner "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message nk.net... You still have it partly backwards on droplet size. Let me provide you with a more probabilistic view of the data you are relying on, being "observed". Now in fact FAA funded a study of icing from large droplets, as that was the "observed phenomena". Consider an experiment where 50 pilots encounter large droplet icing and 50 pilots encounter small droplet icing. At the end of the experiment, the group with "observed" large droplet reports 49 incidents, while the small droplet "observed" group has only 5 advocates. |
O. Sami Saydjari wrote:
This question is a question on physcial phenomena, NOT on regulation (so I am starting a new thread). As I understand it, icing happens between +2C and -10C. Assuming this is correct, I have three questions. (a) Does that mean one is relatively safe if the surface temperature is below -10C (and there is no temperature inversion, meaning that the temperature is known to decrease as one goes up in altitude)? 1. How the cloud got formed is as important as the current temperature of the cloud. As many have pointed out, cumuloform clouds often retain supercooled water well below -10. But not only that, the original air that formed the cumuluus cloud may have come from low, warm, humid levels. If the air in the cloud started out at, say, 20 degreec C with a 15 C dewpoint, it will have condensed out about 11 grams of liquid water per cubic meter by the time it cooled to -10. (This is also why the worst icing in cumuloform clouds is often near the top.) If the air started with a dewpoint of -5, it will have condensed about 1 gram per cubic meter... only about a tenth of the above scenario. If the air in the cloud STARTED with a dewpoint of -10 or less, the cloud will have condensed less than 2 grams of liquid water per cubic meter NO MATTER HOW COLD IT GOT. 2. As Roy mentioned, water condenses only onto a nucleus of some type. In nature these nuclei are MOSTLY the wrong shape for ice crystals to form, so it is natural for the condensation to stay liquid as long as possible, and -10 or so appears to be "common". (By the way, Roy, the latent heat release when it DOES freeze just goes to warm up the air a tiny bit). Typically, once a few drops DO freeze, or when snowflakes are fall into the liquid layer from above, then the liquid will migrate to the ice fairly quickly... Below -10, it is common that at least SOME ice crystals will form, and this usually erodes the water content quickly. However, in vertically developing cloud (Cumulus, etc.) the updrafts may prevent the introduction of ice crystals for some substantial period of time. |
![]() "Mike Rapoport" wrote in message ink.net... I have no idea of what you are trying to say. OK. Aircraft performance in icing is measured in both wind tunnels and in flight. It doesn't matter what a bunch of pilots think, There you go. the data is quantified Yes. and it shows that the performance degradation is highest with large droplets which form ice in ridges aft of the leading edges. But icing events that lead to catastrophic failure are more likely to occur in small droplets forming rapid acretion on the tail surface. (rudder reversal) |
![]() "Bob Gardner" wrote in message news:xkRAb.329519$9E1.1623342@attbi_s52... Gotta wonder why the AWC icing page in ADDS offers the user to choose between a graphic display of "all icing" and of "SLD icing" if Supercooled Liquid Droplets are not a hazard. The Roselawn accident (ATR-72, if I recall correctly), was attributed, in part, to SLD icing. Management of acretion may have been a factor in the ATR-72 AP problems, but we know now that f the operator disables the autopilot in such conditions that the airplane remains in controlled flight. There is a second issue with certain German Litton gyros and their switcher power supplies passing through 0 C, but that is something clearly referenced on the equipment's boiler plate. |
"Matthew S. Whiting" wrote in message
... However, keep in mind that most thermometers have some error in them. So, even though ice doesn't form above 0C, it may form above 0C as indicated on your airplane thermometer. Absolutely true, but remember that your thermometer is one of the easiest instruments in the aircraft to calibrate. The ATIS gives the temperature on the ground before flight -- it's well worth a check. Julian Scarfe |
"O. Sami Saydjari" wrote in message ...
This question is a question on physcial phenomena, NOT on regulation (so I am starting a new thread). As I understand it, icing happens between +2C and -10C. Assuming this is correct, I have three questions. (a) Does that mean one is relatively safe if the surface temperature is below -10C (and there is no temperature inversion, meaning that the temperature is known to decrease as one goes up in altitude)? Sami, I believe you are in Wisconsin - in the Midwest this is generally the case, but as you know, with icing there are no guarantees. -Nathan |
This question is a question on physcial phenomena, NOT on regulation (so I am starting a new thread). As I understand it, icing happens between +2C and -10C. Assuming this is correct, I have three questions. (a) Does that mean one is relatively safe if the surface temperature is below -10C (and there is no temperature inversion, meaning that the temperature is known to decrease as one goes up in altitude)? If there is any chance you will pick up ice at some altitude, you'll want to be sure there is some altitude you can get to where you can shed the ice before landing, unless you can land with an iced-up windscreen. For me, that means somewhere within range where the temperatures are above freezing at the surface. This is probably not possible in Wisconsin for a big part of the year. I've never had the experience of accumulating ice and then not being able to descend to above-freezing temperatures, but I'd think it would be a pretty serious situation without a heated windscreen. When I've had an iced-over windscreen, the defroster wouldn't touch it. It was only descent into warmer air that allowed me to see again. Maybe someone who has landed with ice when the surface temps are below freezing can commment on the windscreen issue. Dave Remove SHIRT to reply directly. |
It is not just a calibration problem (accuracy of themometer), nor is
it just the problem of getting an accurate static temperature (due to moving air). There are low pressure areas on the wing surfaces, and lower pressure causes the air temperature to go down, in these places. So these are all reasons why we don't use zero degrees (which IS required to freeze water), but use some temperature a little higher. I use the airmets as my guide. If there is an airmet for icing, I don't go. Even then, it is possible to pick up ice. I have also broken this rule when I talked to an incoming pilot who flew the other way through the clouds, and he informed me that not only did he not pick up ice, he didn't think there was any ice in those clouds. It was a bit risky, but he was right, no ice. It was the tail end of the front (I have found less ice in the tail end of the fronts than the leading part), and the icing airmet hadn't gone away, yet, but the clouds were "dry". None of the PIREPS indicated icing either. It think I was legal as I had more complete information than the airmet (debatable). I agree with MU-2 Mike in that we do get ice below -10 degrees Celcius. It is also possible to get ice when there is no airmet, so always have an out. One big reason the airliners can deal with ice is they have the climb ability to outclimb the ice. A turbine or at least a turbo charged aircraft (with either oxygen or pressurization), has protection at least as good as having deice system. Also keep in mind, that if you go fast enough (300 knots or so), you wont get ice due to friction warming of the wings (specific info needed on the type from the mfg for this, no general rule). One final piece of information. The smaller diameter of the surface area, the more ice will accumulate. This is why antennaes and struts get more ice. This is due to the physics of the air in front of the surface. Large diameter surfaces deflect the air coming toward the surface more thand smaller diameter surfaces. "Julian Scarfe" wrote in message ... "Matthew S. Whiting" wrote in message ... However, keep in mind that most thermometers have some error in them. So, even though ice doesn't form above 0C, it may form above 0C as indicated on your airplane thermometer. Absolutely true, but remember that your thermometer is one of the easiest instruments in the aircraft to calibrate. The ATIS gives the temperature on the ground before flight -- it's well worth a check. Julian Scarfe |
Doug ) wrote:
snip I agree with MU-2 Mike in that we do get ice below -10 degrees Celcius. It is also possible to get ice when there is no airmet, so always have an out. During this season (my first full winter winter since receiving my IFR rating last March), I have picked up ice at +2 C, -12c, and in areas that were outside of icing Airmets by hundreds of miles. In my limited experience, one fact seems apparent to me: There are no reliable rules pertaining to ice except, perhaps, plan for possible icing from October to March (at least downwind of the US Great Lakes). -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
Mike Rapoport wrote:
[...] Ice is less likely to be a problem than if it was 0C at the surface but, again, icing can occur at temperatures much lower than -10C particularly in clouds with vertical movement (cumulus). I've been wondering why the vertical movement makes a difference. This assumes that the water is still. It the water is turbulent then the temperature will go even lower before crystalization starts. Is that the answer? The vertical movement counts as "turbulence" in this context? Why does the "activity" of the water alter the temperature at which freezing starts? The kinetic energy of such movement? The friction which results from such movement? But wouldn't the friction merely raise (or slow the decrease) of the temperature? - Andrew |
Removing water repelent from fiberglass lay-up? | Roger | Home Built | 2 | December 2nd 04 11:15 PM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
water bombers | Stew Hicks | Home Built | 2 | September 8th 03 11:55 PM |
water bombers | Stew Hicks | Home Built | 0 | September 7th 03 04:27 PM |
Need help with Fluid Mechanics equation | Doug | Home Built | 4 | August 16th 03 03:13 AM |
