Japanese plane - shrouded pusher w/winggrids
Old March 10th 06, 12:08 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Japanese plane - shrouded pusher w/winggrids
Earlier, wrote:
OK.
How are they getting an increase in L/D while decreasing span and
adding drag?
(And before the serious flames begin, neither I nor they are selling
anything.)
The short answer is, they're not. Their verbiage and treatises dance
around it by carefully comparing apples to oranges.
Old March 10th 06, 04:05 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
wrote ...
adding drag?
The only way for this system to do what they claim is they would have to add
energy to the airflow. Perhaps they just forgot to tell us about a small
embedded jet engine.
Rich
Old March 10th 06, 04:48 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
These guys selling snake oil too?
http://www.star-tech-inc.com/papers/aiaa/aiaa.pdf
http://tinyurl.com/g66ln
http://jeb.biologists.org/cgi/reprin...lcode=je xbio
Alsio
SPEDDING, G. R. (1992). The aerodynamics of flight. In Mechanics of
Animal Locomotion (ed. R. McN.
Alexander). Berlin: Springer-Verlag.
SPILLMAN, J. J. (1987). Wing tip sails; progress to date and future
developments. Aeronaut. J. 91,
445-453.
Or did we reach the totality of knowledge on wing tip design with
Whittman's experiment?
Old March 10th 06, 06:42 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Earlier,
Not at all. They make a convincing case that carefully-implemented
multiple element winglets can reduce induced drag so as to improve best
L/D over some range of Cls, especially for wings with low aspect ratio.
What they don't try to do is sell such configurations as a panacea, a
"substitute for span."
As all good sailplane pilots know, the only substitute for span is
talent. The difference between the two is that you can _buy_ span.
Thanks, Bob K.
Old March 10th 06, 07:08 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Bob Kuykendall wrote:
Earlier,
Thanks, Bob K.
While there was some discussion about heavy jet wings, the data in the
paper indicated that the tests were performed at very low Reynolds
Numbers - 161K to 300K.
Our light experimental usually run at least 3,ooo,ooo.
They are studying Eagle wings - not 747's...
Richard
Old March 11th 06, 08:10 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Alsio
445-453.
Wittman's Wonderful Wing Widget
Yep, I think so!
To my knowledge, this is the only light plane wing tip design that makes
a measurable difference in flight.
If you can measure it, it's there!
Best I can do for now is a pic of a (modern) all wood outer panel -
before installing the top skin. It's a work in progress, but gives
an idea of the shape.
http://home.earthlink.net/~tp-1/w10-tip.jpg
The originals were brazed up steel and fabric. (yeah right!)
The Unofficial Tailwind Page is located at:
A lot of info there - including flight reports and old reprints.
http://www.chlassociates.com/Aviation/Tailwind.htm
I had a link to the '05 race winner, (210 mph on 160 hp?) but I can't
find it right now. Pretty thing!
Richard
(X the X to reply)
Old March 11th 06, 11:46 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
("Richard Lamb" wrote)
home.earthlink.net/~tp......... link doesn't work for me.
Lose the capital "T" in Tailwind for your link to work:
http://www.chlassociates.com/Aviation/tailwind.htm
This link works.
Or play around in here
Montblack
Old March 12th 06, 03:32 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
This link works.
Montblack
Try it now?
Old March 13th 06, 02:13 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
This link works.
Montblack
Again. Thanks.
I might finally have it worked out.
http://www.home.earthlink.net/~tp-1/w10-tip.jpg
Wittman W-10 all wood wing tip.
This should give the folder index
or start a web page "index.htm" - if one existed?
Richard
Old March 13th 06, 02:48 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Buttercup"
Steve's "parts hauler"
http://www.chlassociates.com/Aviation/buttercup.htm
The second (of 3) pictures shows Steve examining the unique
Leading Edge flap on Buttercup.
Leading edge flaps are effective when used in conjunction
with a corresponding trailing edge flap.
Buttercup had longer wings - and longer trailing edge flaps.
On a Tailwind style wing, half the TE flaps - the other half ailerons.
So, to spread the effect further out on the wings, droop the ailerons
as the flaps go down?
Richard
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
