Japanese plane - shrouded pusher w/winggrids
Old March 8th 06, 12:18 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Japanese plane - shrouded pusher w/winggrids
http://www.winggrid.ch/do%20and%20do%20not.htm
(Do's and Dont's designing winggrids)
Bottom of page - yellow Japanese design. Shrouded pusher ...with winggrids.
What is it? Has anyone seen this plane in magazines? I'm guessing it flies.
http://www.winggrid.ch/index.htm
It comes from this site - Winggrids.
"WINGGRID -THE SUBSTITUTE FOR SPAN
The ultimate solution for aerodynamic drag reduction and wingtip stall
resistance"
Montblack
Old March 8th 06, 02:43 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Hoo-yeah! I love the smell of snake oil in the morning!
Bob K.
Old March 9th 06, 02:15 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Bob K.
Nothing new here. A Sport Aviation article, in the late 80s if I
recall, breathlessly told the story of a C-150 with identical wing tips,
back during days when Jack Cox's articles were uniformly uncritical puff
pieces (not sure if this particular article was written by Cox, it was
just that SA never reported real criticism of homebuilts back then). I
remember it had a fancy stars and stripes paint job. This C-150 had
those venetian blind thingys on the tips plus VGs and fences and was
supposedly capable of impossibly low stall speeds, which to the extent
that stall was reduced would have been a function of the VGs mainly.
The tip 'blinds" just looked ridiculous and speed limiting.
The problem with fancy wingtips is this: If they do anything to extract
benefit from tip vortices, they only do so when the wing is working
hard, at max L/D. So such a device MAY improve rate of climb or sink
rate. It won't have all that much effect on stall speed. At higher
speeds with low AOA they are just drag makers. Who is willing to give
up 15kts of cruise just to get an extra hundred FPM of climb? Thus such
things never appear in the real world in any great quantity.
Note that the only wingtip devices that actually do anything useful are
winglets, which generate some thrust from tip circulation that is more
than their drag, and this only when the wing is at max LD. As a result,
they are only used on two types of a/c in general; gliders and high
altitude cruisers like airliners and bizjets. Both do their thing at
close to max LD, the glider for obvious reasons and the airliner because
at 36000 ft it is operating at cruise effectively in the same indicated
speed regime and AOA as the glider at max LD. In both cases the
winglets are only there because their benefit is available at the
aircraft's intended cruising speed range.
Same applies to any other wing tip device that proposes to use tip
vortice energy.
JohnK
Old March 9th 06, 04:26 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Take a look at some of the papers on the site -
http://www.winggrid.ch/AIAA-2004-2120.pdf
Since they aren't selling anything, and they are doing both real world
experiments and academic papers with plenty of data collection, I
wouldn't call them snake oil.
The effect is real. It may be too mechanically complex to be economic,
but it's more than vaporware.
Old March 9th 06, 07:26 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
wrote ...
Snake oil is far too nice a term for what they're peddling. Did you read
the paper? In the first sentence they throw out a hundred years of
aerodynamics and replace it with their own. Why? Because the old stuff
doesn't give the answers they want. They don't justified it further than
that. They then go on to claim span efficiency factors of 1.5 with their
system. If you understand anything at all about wing aerodynamics you would
know that's an absurdity.
Sometimes people want to believe things so badly that they can't see that
they're leading themselves astray.
Rich
Old March 9th 06, 08:13 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Earlier, wrote:
Take a look at some of the papers on the site...
I did. I also chatted about them with one of the aero engineers whose
work is cited in them. We agree that it's a bunch of hokum. It looks
almost like it was designed to spawn a bunch of conspiracy theories
like the ones about GM suppressing the 200 mpg carburator.
As regards the topic of winglets raised by another poster, they're
great for span-limited and bending-moment-limited situations, which is
why they're popular on sailplanes and airliners. L/D-wise it's more
effective to just make the wing longer - that is, a 2-foot span
extension usually increases the performance more than a 2-foot tall
winglet. But of course, extra span drives the wing bending moment up
more, so there are many cases where you can have a winglet but not the
equivalent span extension.
That feathered tip is about the exact opposite of Steve Wittman's tiny tip
trapezoid approach.
(for the newbies)
Some early NACA reports indicated that the outer one-chord-length of wing
span was disturbed by the tip vortex. (That vained thing might show some
promise in this respect, but the drag of it - just due to increased surface
area alone - and all ALL speeds???)
Anyway,
If the tip chord were reduced, what would happen to the total wing tip vortex?
The story goes Steve decided to test this eye-dia by modifying one wing tip.
He took off and tip-toed around the pattern holding near full aileron to hold
near level. Landed, rolled it back into the hanger and fixed the OTHER tip.
Steve's tip modification did indeed reduce the sink rate for any given speed.
Ergo...
Richard
May you always have a Tailwind...
Old March 9th 06, 10:21 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
In article et,
Ergo...
Richard
Is there someplace on the web with information on the Witman wing tip
design? I'd love to have a write up with the particulars without having
to buy a set of Tailwind plans. I've looked all over the web and haven't
found it. I have a little wood wing homebuilt that would dearly love to
have those wingtips.
Thanks
Wallace
Old March 9th 06, 11:24 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Richard Isakson" wrote in
wrote ...
read the paper? In the first sentence they throw out a hundred years of
This Doonesbury is appropriate:
http://www.uclick.com/client/wpc/db/.../05/index.html
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html
Sed quis custodiet ipsos Custodes?
Old March 9th 06, 11:46 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
OK.
How are they getting an increase in L/D while decreasing span and
adding drag?
(And before the serious flames begin, neither I nor they are selling
anything.)
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
