![]() As airplane travel is becoming more frequent, air traffic is said to double in the next coming years. Right. http://www.birdseyetourist.com/?cat=14 |
Larry Dighera wrote: Pilots, prepare to lose some sovereignty over your flights: http://www.exn.ca/dailyplanet/view.asp?date=2/13/2006 As airplane travel is becoming more frequent, air traffic is said to double in the next coming years. A new system called 4DT (4 Dimension Trajectory) will soon replace current ones. relax. The concept of required time of arrival has been talked about for years. It's going to be a loooooonnnnnngggggggg time before it's actually implemented. -- Bob Noel Looking for a sig the lawyers will hate |
On Mon, 20 Mar 2006 21:21:43 -0500, Bob Noel
wrote in :: The concept of required time of arrival has been talked about for years. Apparently, among other things, 4DT supports tweaking that time en route so there will be less holding, and stepped approach descents will give way to throttled back glides. It's going to be a loooooonnnnnngggggggg time before it's actually implemented. Perhaps. But IIRC Bowing is providing ATC under contract in the UK. Once the software is written and tested, it would be possible to deploy it as rapidly as personnel could be trained. In this country, of course, there's no need to reduce CO2 emissions and aircraft noise levels. :-( |
Larry Dighera wrote: It's going to be a loooooonnnnnngggggggg time before it's actually implemented. Perhaps. But IIRC Bowing is providing ATC under contract in the UK. Once the software is written and tested, it would be possible to deploy it as rapidly as personnel could be trained. In this country, of course, there's no need to reduce CO2 emissions and aircraft noise levels. :-( Check out the history of when all the new CNS/ATM requirements were going to implemented. They always always always slide to the right, and slide to the right many times. You think this particular old idea is any different? -- Bob Noel Looking for a sig the lawyers will hate |
On Tue, 21 Mar 2006 00:34:17 -0500, Bob Noel
wrote in :: They always always always slide to the right, and slide to the right many times. You think this particular old idea is any different? Was Boeing doing the sliding? http://www.washingtonpost.com/ac2/wp...nguage=printer Boeing officials say that by May they will give the FAA a comprehensive plan for replacing the nation's radar-based air traffic control system -- which is straining to handle the 93,000 aircraft that fly daily in U.S. airspace -- with a satellite-based one that could squeeze perhaps 50 percent more flights into available airspace and improve air safety. |
Larry Dighera wrote: They always always always slide to the right, and slide to the right many times. You think this particular old idea is any different? Was Boeing doing the sliding? Yes. -- Bob Noel Looking for a sig the lawyers will hate |
![]() "Larry Dighera" wrote in message ... On Mon, 20 Mar 2006 21:21:43 -0500, Bob Noel wrote in :: The concept of required time of arrival has been talked about for years. Apparently, among other things, 4DT supports tweaking that time en route so there will be less holding, and stepped approach descents will give way to throttled back glides. It's going to be a loooooonnnnnngggggggg time before it's actually implemented. Perhaps. But IIRC Bowing is providing ATC under contract in the UK. I don't think so. Bowing are not providing ATC under contact in the UK. ATC is provided by NATS http://www.nats.co.uk/about/ownership.html |
On Tue, 21 Mar 2006 15:34:44 -0000, "Chris"
wrote in :: "Larry Dighera" wrote in message .. . On Mon, 20 Mar 2006 21:21:43 -0500, Bob Noel wrote in :: The concept of required time of arrival has been talked about for years. Apparently, among other things, 4DT supports tweaking that time en route so there will be less holding, and stepped approach descents will give way to throttled back glides. It's going to be a loooooonnnnnngggggggg time before it's actually implemented. Perhaps. But IIRC Bowing is providing ATC under contract in the UK. I don't think so. Bowing are not providing ATC under contact in the UK. ATC is provided by NATS http://www.nats.co.uk/about/ownership.html Interesting: NATS is a public private partnership between the Airline Group, a consortium of seven UK airlines, which holds 42%, NATS staff who hold 5%, UK airport operator BAA plc, with 4%, and the government which holds 49% and a golden share. The Airline Group is a consortium of seven UK airlines: British Airways, bmi British Midland, Virgin Atlantic, Britannia, Monarch, easyJet and Airtours. I do recall, that there was discussion several years ago of the UK contracting with Boeing for ATC services, but I can't locate a reference just now. Here's some more interesting information about NATS: http://www.rppi.org/atc15.html#Anchor-42816 August 2003 As reported here previously, NATS accomplished a financial restructuring last spring that brought in BAA as a new investor and led to new cash infusions by both BAA and NATS's 49% owner, the U.K. government. Now NATS is about to launch a billion-dollar bond issue to refinance a large part of its bank debt. That, in turn, will permit the removal of restrictive provisions on the debt that had prevented NATS from moving forward with its $1.6 billion, 10-year modernization program. The bond issue has received AAA ratings by both Standard & Poor's and Moody's. Apparently it was the FAA (not Boeing) who delayed implementation of something similar to 4DT in the US: http://www.reason.org/atcreform15.shtml Jaws dropped last month when the FAA announced that controller-pilot-data-link communications (CPDLC) was being put on indefinite hold, despite a highly successful test program in Miami. Automating routine ATC communications-in effect, switching from voice to email-"is the key architectural enabler of almost any future envisioned air traffic management system," says Kevin Brown, one of Boeing's senior ATC people. "It is hard to imagine a future where the connective tissue between aircraft and ground is someone's voice over a VHF radio." And CPDLC isn't just about automating a few routine voice messages. It could eventually permit a plane's flight management system to automatically update ATC computers with the plane's current trajectory, making possible a "network-centric" approach to ATC. By putting the program on hold, the FAA is ceding leadership in CPDLC to Europe. Eurocontrol's plan will equip 15 en-route centers by 2007, whereas observers now don't expect comparable nationwide CPDLC equipage here until 2012, at the earliest. More information he http://commdocs.house.gov/committees...hsy73841_0.HTM DEVELOPING THE NEXT GENERATION AIR TRAFFIC MANAGEMENT SYSTEM HEARING BEFORE THE SUBCOMMITTEE ON SPACE AND AERONAUTICS COMMITTEE ON SCIENCE HOUSE OF REPRESENTATIVES ONE HUNDRED SEVENTH CONGRESS FIRST SESSION JULY 19, 2001 |
1-26 Dimension Needed | Mark Zivley | Soaring | 3 | February 7th 05 02:16 PM |
Dell Dimension 8300 | Tlewis95 | Simulators | 3 | March 4th 04 07:50 PM |
RV-8 Dimension request | Howard Johnson | Home Built | 3 | December 7th 03 07:15 AM |
