1-26 Dimension Needed
Old February 7th 05, 04:11 AM
Mark Zivley
Default 1-26 Dimension Needed
The trailer configuration for our club's 1-26 uses a steel tube that is
passed through the aft wing attach recepticals. This tube keeps the
fuse stable on the trailer. Anyone know off hand what the largest "off
the shelf" diameter tubing will go through that aft wing pass through?
No, I wasn't the one who lost it.. :-) But we do need to buy another
piece to replace it.
Mark
reply to (as the "reply to" is bogus
Old February 7th 05, 05:42 AM
jphoenix
Mark,
3/4 inch pipe galvanized fits loosely - wrap 1/8" thick by 1 or 2" wide
sticky back foam seal around the pipe - cover *tightly* with duct tape,
drill holes for your tie-downs or whatever and you're back in business.
for more 1-26 maintenance info, point your browser to
www.jimphoenix.com or the 1-26 Association web site. Just google it.
is
"off
through?
another
Mark
Old February 7th 05, 01:32 PM
is
"off
through?
another
Mark
Diameter is 1 inch for drag spar.
UH
Old February 7th 05, 02:16 PM
Mark Zivley
Thank you both!
Mark
Dell Dimension 8300 Tlewis95 Simulators 3 March 4th 04 07:50 PM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 04:28 AM
Glider needed Jeff Landfield Soaring 0 July 21st 03 04:39 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
