![]() "Reed Judd-Dyer" wrote in message oups.com... Kyle Boatright wrote: "Don McIntyre" wrote in message oups.com... Why did they settle on the 3-blade configuration? Wouldn't a 4-bladed system allow for a smaller footprint on the ground (or ship)? Or is there too much thrust loss involved? More blades = less efficiency. Shorter blades = less efficiency in vertical flight. They probably couldn't have absorbed the performance loss from both increasing the number of blades and reducing blade length. KB How does more blades equal less efficiency? If that is true why do all current Helicopters use 4-5 blades instead of two like the legacy systems of the Huey and Cobra? Why do all modern turbo-props have more then two blades? Somthing sounds off here. Guesses are like.... Anyone actually involved in the engineering of the V-22 or at least privy to some of the original evaluation documentation? Reed More blades equals less efficiency for several reasons. One is that the more blades you have, the dirtier the air becomes. Rotor and prop blades like undisturbed air best. Also, you balance the number of blades and their diameter against the HP from the engine. More blades = less blade length = lower aspect ratio = lower efficiency. Early helicopters needed the most efficient blade/power system possible just to get off the ground. That resulted in two bladed rotors with long blade length. As engines came along with significantly more HP, designers could trade-off aerodynamic efficiency for packaging efficiency and create a helicopter with adequate performance and reasonable size for the delivered performance. Aircraft with turboprop powertrains have multiple blades because those designers have to make compromises too. There are clearance issues to deal with (ground clearance, fuselage clearance, prop to prop clearance). There are tip speed issues (you don't really want to take prop tips over .9 mach if you can help it). And there are dynamic issues where a fast turning big prop generates tremendous forces in shear, bending, and precession.. All of those things drive designers towards a smaller diameter prop. So, the designer compromises those packaging needs versus aerodynamic efficiency, and voila... Multi-bladed prop's. If more blades was a better solution, you'd see Cessna 150's with 20 blade prop's, because those little airplanes need all the help they can get... KB |
![]() Kyle Boatright wrote: "Reed Judd-Dyer" wrote in message oups.com... Kyle Boatright wrote: "Don McIntyre" wrote in message oups.com... Why did they settle on the 3-blade configuration? Wouldn't a 4-bladed system allow for a smaller footprint on the ground (or ship)? Or is there too much thrust loss involved? More blades = less efficiency. Shorter blades = less efficiency in vertical flight. They probably couldn't have absorbed the performance loss from both increasing the number of blades and reducing blade length. KB How does more blades equal less efficiency? If that is true why do all current Helicopters use 4-5 blades instead of two like the legacy systems of the Huey and Cobra? Why do all modern turbo-props have more then two blades? Somthing sounds off here. Guesses are like.... Anyone actually involved in the engineering of the V-22 or at least privy to some of the original evaluation documentation? Reed More blades equals less efficiency for several reasons. One is that the more blades you have, the dirtier the air becomes. Rotor and prop blades like undisturbed air best. Also, you balance the number of blades and their diameter against the HP from the engine. More blades = less blade length = lower aspect ratio = lower efficiency. Early helicopters needed the most efficient blade/power system possible just to get off the ground. That resulted in two bladed rotors with long blade length. As engines came along with significantly more HP, designers could trade-off aerodynamic efficiency for packaging efficiency and create a helicopter with adequate performance and reasonable size for the delivered performance. Aircraft with turboprop powertrains have multiple blades because those designers have to make compromises too. There are clearance issues to deal with (ground clearance, fuselage clearance, prop to prop clearance). There are tip speed issues (you don't really want to take prop tips over .9 mach if you can help it). And there are dynamic issues where a fast turning big prop generates tremendous forces in shear, bending, and precession.. All of those things drive designers towards a smaller diameter prop. So, the designer compromises those packaging needs versus aerodynamic efficiency, and voila... Multi-bladed prop's. If more blades was a better solution, you'd see Cessna 150's with 20 blade prop's, because those little airplanes need all the help they can get... KB OK, That jives with research I was doing on ducted fan systems. The advantage of the duct being that it reduced the "disturbed" air effect, making them more effecient untill the drag created by the duct zeroed out the gains. Also helps explain why a two engine tilt-rotor can verticly lift more then a four engine tilt-prop. Thanks for the clear answer. Reed |
Reed Judd-Dyer wrote
How does more blades equal less efficiency? Those of us that flew rubber band powered contest model aircraft way back ('40s-'50s) KNOW that the most efficient propellor has only ONE blade...and a counterweight on the other side. :-) Bob Moore |
![]() Bob Moore wrote: Reed Judd-Dyer wrote How does more blades equal less efficiency? Those of us that flew rubber band powered contest model aircraft way back ('40s-'50s) KNOW that the most efficient propellor has only ONE blade...and a counterweight on the other side. :-) Bob Moore A Helo with one blade would have to be the most uncomfortable ride, until after a minute or so, when it had shook itself to pieces. Jeremy Thomson |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Ivo Prop Blades - question | Dave S | Home Built | 6 | August 26th 05 04:20 AM |
Sport Prop blades needed | Ron | Aviation Marketplace | 0 | February 19th 04 11:12 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
