Painting aluminum glider trailer
Old April 20th 06, 07:42 PM posted to rec.aviation.soaring
Default solar radiation, polished metal and white paint
I have lived in Texas most of my life and can tell you from experience
that my trailers will ALWAYS be white. On bare aluminum, use a solution
of 10/1 water/white vinegar to etch the surface. Rinse thoroughly and
use alodine per lable directions. A good quality, latex gloss
housepaint can be rolled on with a low-stipple mohair roller and the
results look sprayed. This paint, applied properly, will last 15 years.
If you're in a dry climate and have some shade for it... it'll last
much longer than that. No primer, no spray equipment, and a decent
paint job for less than $200.00. Who could ask for anything more?
Jack Womack
Old April 20th 06, 07:48 PM posted to rec.aviation.soaring
Thanks, Fernando. Just two illustrating examples which everybody knows:
In winter, a metal table feels colder than a wooden table of the same
temperature, because metal conducts heat much better then wood.
In summer, you burn your feet by walking through hot sand a the beach,
but not by walking over wood of the same temperature. Same reason.
BTW, this is also the reason why it's no big deal to walk over red-hot
coal, especially if you walked through wet grass before. If you try it
with Charcoal, that is. But please don't try it with mineral coal!
Stefan
Old April 20th 06, 07:33 PM posted to rec.aviation.soaring
A mistake in my previous posting: white paint has a solar reflectivity =
of 70 to 80%. It is the opposite property of solar absorptivity, from a =
table of which I was quoting, that is 20-30%. I hope the argument makes =
more sense now.
Old April 20th 06, 07:37 PM posted to rec.aviation.soaring
If you are looking fo a cheap job (cheap is emphasised,
no flames please) you can paint aluminium with an ordinary
roller and household gloss, eg Dulux enamels, I hope
Dulux is recognisable in the USA.
Yes, I do know that if you're going to paint Alu properly
then you use epoxy etch primer and a decent topcoat,
but the raw materials alone are still going to be about
400ish dollars, trailers have a big surface area.
Compare this with 10 litres of household gloss, no
flames please, this is a cheap suggestion, it works
and has lasted for 5 years so far.
Old April 20th 06, 11:15 PM posted to rec.aviation.soaring
Default Painting aluminum glider trailer
John Murphy wrote:
I have a 20+ year old trailer for my G102. Presently, its bare sheet
aluminum. I want to paint it white to reduce the amount of heat
absorbed by the trailer skin. A local autobody shop quoted me $1600.00
to cover with a polyurethene paint over an epoxy primer. This is far
more than I wanted to spend. Any suggestions on durable paints or
products that can be applied by a novice to sheet aluminum. I can rent
an airless sprayer if need be. Thanks.
I looked into this when I had an aluminum tube-type trailer. I compared
the air temperatures inside the trailer in several places (ceiling,
floor, inside cockpit) with those in a similar trailer painted white. As
I recall, the air temperatures in the top 6" of the trailer were 10 to
15 F hotter, but below that, the air temperatures were only a few
degrees hotter. Because the _glider_ temperatures were hardly different,
I decided the heat protection gained wasn't worth the cost and effort to
paint the trailer.
I believe the hot air convects to the top of the trailer and insulates
the rest of the air from the heat input. I notice the same effect in my
Cobra trailer, where the air near the top is very hot, but below that
the air is only a few degrees above the outside air temperature.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old April 25th 06, 10:44 PM posted to rec.aviation.soaring
I painted my trailer with white two part epoxy paint. It was about
$110 for two gallons (a gallon each of part A and part B). I went
through about 3 gallons total. I mixed the first two gallons together
and when that was gone, 1/2 of each of the other two gallons. Thus I
have some left over. I put it on with a short nap roller. Looks
great.
You can't generally find this at the big box stores and have to go to a
paint only storefront that the trades use. Epoxy paint can be sprayed
but cleaning up the sprayer afterwards could be tricky.
Funny story: the counter guy at the store admonished me to not mix the
two together unless I was ready to paint. No duh. Apparently a guy
came back to the store after buying some epoxy paint holding a bucket
of now quite hard paint with a stiring stick permanently stuck in the
middle of it and wanted his money back. Uh huh, yeah, sure. Read the
label dude.
- John
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Glider and Trailer Transport Paul Soaring 5 March 12th 06 05:58 PM
Painting a Fiberglass Trailer Experiences ContestID67 Soaring 4 April 28th 05 07:40 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Need (glider&) trailer transport - Sante Fe, NM > Santa Cruz, CA, late Aug Eric Soaring 1 August 8th 03 03:21 PM
