This is not a question, just a comment about a recent experience.
I have a fiberglass trailer that needed a repainting. After asking around some trailer manufacturers the general conscensus was to use a two part epoxy paint. I ended up using Benjamin Moore M36/M37 gloss white tintable epoxy paint. It costs about $100 for one gallon of part A and one gallon of part B. Two gallons are said to cover 880 sq ft. It dries to 2mils so it is significant protection. I started with a brush but it is so thick that I had to switch to a roller for the broad flat surfaces. Wear gloves and a hat. I got some in my hair and it may not go away until I get my next hair cut. As it is tintable you can go with something other than plain white for no extra charge. All in all the trailer looks great and I recommend this solution. http://www.benjaminmoore.com/tds/1033/TDSM36M37.pdf - John |
When I painted my trailer I used Easypoxy single part polyurethane. The
paint has held up well for two years now. No need to spray, use a mask, etc. Roll it on then cross brush to even out and get rid of the bubbles. Google for "paint tipping." |
![]() For those of you not addicted to the "Do it yourself" approach, I recently had my 1984 Cobra (aluminum) trailer painted by Miracle Auto Paint. The trailer paint was in terrible condition, flaking and pitted from living under a tree for several years. Miracle did the whole job for $1200 including prep, epoxy undercoat, acrylic auto paint, and detailing. The trailer looks fantastic, and while I would not want to make an andorsement, I had my Volvo painted by them about three years ago, and the paint job has held up very well. Post-paint waxing is important. |
My Cobra fiberglass top needs work too. Sometime in it's past someone
painted it with a poor paint and it is just turning to dust! Anyway, I need to sand this old s... off. Any recommendations regarding type of sander and grade of sand paper? I am not much of a craftsman and do not want to damage, groove, or dent the top. Thanks |
![]() Any recommendations regarding type of sander and grade of sand paper? I I painted my Eberly, Libelle trailer top a few years back. Sanded it with 60 grit on an 18 inch air-board. Cheap air-boards are available for under $100 bucks, but you need a source of high volume air at about 90+ PSI. Then I painted it with synthetic enamel with flatner added so that the gloss wouldn't show all the imperfections in the fiberglass and also my 60 grit sand marks. Looked good and has held up well. JJ |
Trailer hitch inadvertant disconnect | Bill Daniels | Soaring | 5 | July 16th 04 03:17 AM |
Blasting and painting | [email protected] | Home Built | 7 | June 3rd 04 03:14 PM |
Trailer spare - who woulda thunk? | Bill Daniels | Soaring | 7 | May 20th 04 04:47 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
Fiberglass Tip Tanks Question | Jay Honeck | Owning | 7 | September 26th 03 04:23 AM |
