Hi!
I have a 68' Arrow, and wonder if I can remove the back seat to allow some bulky transportation. Or is this seat some sort of stiffening of the airframe? If I can, can I remove only the seatback? If so, how do I do this? Any mod to make it easy to fold down and back up again with no tools? Like a station wagon car's back seats....? My back seat is in one piece, ie not twp seperate seats. Thanks, Frode |
Depends on the plane. In the Mooney the POH says the pilot can remove
the seat. |
bulky transportation. Or is this seat some sort of stiffening of the airframe? Yep, that bench seat comes out -- but it will expose lots of stuff that you probably don't want to drop things in...like your elevator and rudder cable runs. (One reason I REALLY like the "bucket" back seats in our '74 Piper PA28-235 Pathfinder. They literally pop out -- without tools -- in seconds, and leave a nice, flat, 3/4 inch plywood floor.) If I can, can I remove only the seatback? If so, how do I do this? I don't see why you couldn't, although I suspect that the seatback is pretty permanently attached to the seat bottom. Any mod you make is going to have to be approved, which may not be a simple matter. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Rear seats in my 72 Arrow remove in seconds. As I recall, there are
four slots in the floor that accomodate four mating prongs on the seat base. Again, if I recall correctly, push FORWARD on the whole seat while lifting up. The 72 Arrow has two individual rear seats so may not be the same but give it a try. No effect on the structure but might want to consider weight and balance. |
Dave Butler wrote:
In fact, it might be prudent to update the weight and balance section of the POH with seats-in and seats-out weight calculations, unless your POH has some other provision for flying without the seats. Please don't shoot me if this is a stupid question. G Couldn't you simply calculate the weight and station (of the center of the weight) of the seats, do the same with the replacement items, use them in the CG calcs, and be good to go? For example: Remove x pounds @ arm y Add x pounds @ arm y Am I thinking correctly? |
of the POH with seats-in and seats-out weight calculations, unless your POH has some other provision for flying without the seats. Please don't shoot me if this is a stupid question. G Couldn't you simply calculate the weight and station (of the center of the weight) of the seats, do the same with the replacement items, use them in the CG calcs, and be good to go? Yes, exactly. I'm just saying you might want to have that calculation in the aircraft POH rather than on the back of an envelope. Seems to me the aircraft was (probably) certified with seats in, and you are making a modification by removing the seats, and that should be documented on the W&B section of the POH. Maybe I'm just over-cautious, but I'm pretty sure I've heard of doing exactly this. Probably no difference as far as safety of flight, just a documentation difference. Dave |
Dave Butler wrote: In fact, it might be prudent to update the weight and balance section of the POH with seats-in and seats-out weight calculations, unless your POH has some other provision for flying without the seats. Please don't shoot me if this is a stupid question. G Couldn't you simply calculate the weight and station (of the center of the weight) of the seats, do the same with the replacement items, use them in the CG calcs, and be good to go? Yes, exactly. I'm just saying you might want to have that calculation in the aircraft POH rather than on the back of an envelope. Seems to me the aircraft was (probably) certified with seats in, and you are making a modification by removing the seats, and that should be documented on the W&B section of the POH. Maybe I'm just over-cautious, but I'm pretty sure I've heard of doing exactly this. Probably no difference as far as safety of flight, just a documentation difference. The key is to see what the certification standard is for your aircraft. I don't know about Arrows but in the 182 I had and the Bonanza I have now all seats except the pilots seat are standard items, the pilots seat is a required item for certification, it cannot be removed and then legally flown. The equipment list from Cessna showed all items and a column that had either an R, S or O, for required, standard and optional. Only the required stuff has to be in the plane. I carry a weight and balance sheet with three configurations for my Bo. First is the standard one with all seats in, second has one rear seat removed and third has both rear seats removed. I weighed the seats myself and use actual weight, in the case of my Bo each rear seat weighs 22 pounds. In the 182 I also had three configurations on the W+B. All seats in, rear seat out and rear and copilot seat removed. To be legal a logbook entry has to be made but I never bothered with that. |
four slots in the floor that accomodate four mating prongs on the seat base. Again, if I recall correctly, push FORWARD on the whole seat while lifting up. The 72 Arrow has two individual rear seats so may not be the same but give it a try. Nope, totally different. Frode's bench seat doesn't come out the same way as our bucket seats. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Thread Tools | |
| Display Modes | |
| Airtex Interior Refurbish - Day 43 | Mike Spera | Owning | 0 | May 15th 05 03:15 PM |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| Airliner Seats ... | smjmitchell | General Aviation | 6 | September 26th 04 11:00 PM |
| Pitts Seat Mod | Martin Morgan | Aerobatics | 0 | November 21st 03 04:56 AM |
| Seat cushion | Ernest Christley | Home Built | 14 | August 5th 03 08:16 PM |
