![]() Private wrote: "Jim Macklin" wrote in message news:EZF9g.20244$ZW3.18025@dukeread04... I've heard of owners replacing the standard fasteners with nice shiny stainless steel screws. Trouble is you can get dissimilar metal galvanic reactions and then you have to drill them out. I am aware of galvanic corrosion, which often corrodes aluminum when it is in contact with steel, especially if in the presence of moisture and even more especially moisture with salt. The use of stainless fasteners should AFAIK greatly reduce corrosion of the fasteners but am unaware of any change to the galvanic corrosion rates on the aluminum. Are you suggesting an increase in galvanic action between a stainless fastener and a plain steel nut? Please expand. What I have heard is this. If you use a carbon steel screw in the aluminum structure, the corrosion occurs on the steel screw (rusted screws). To correct the problem, you just replace the screws. If you use stainless screws, this changes the galvanic status of the connection to where the aluminum becomes the metal that corrodes. This means that if you allow corrosion to occur, the aluminum structure around the screw is what corrodes instead of the screw. To correct this situation, you have the aluminum structure around the screw to replace, which is much more involved and expensive than just replacing the screws. I would also appreciate comment on the use of thread lubricants like 'Nevr-Seize' which IMHO allow increased clamping force and also greatly reduce thread seizing from corrosion. Use of a good corrosion preventative like corrosion X or ACF-50 should prevent any corrosion of the structure, if you keep it applied every annual. |
I find never-seize on threads to work magic minimizing corrosion, but
one has to be very careful not to get it on the phillips head or the phillips driver. Even traces of it (or paint) make the drivers cam out. Buy lots of spare screws and drive bits. Use solvent on the drivers and the screw heads. It doesn't help that those damn AN structural screws (can't remember the number) are so soft and the phillips socket so shallow that the heads strip out much easier than those unapproved pan head stainless fasteners. I don't know what they offer except of course a full diameter shank and a lot of ductility. Some of you must live in a very corrosive environment though. |
![]() "Private" wrote in message news:yu2ag.165036$7a.147100@pd7tw1no... "Jim Macklin" wrote in message news:EZF9g.20244$ZW3.18025@dukeread04... I've heard of owners replacing the standard fasteners with nice shiny stainless steel screws. Trouble is you can get dissimilar metal galvanic reactions and then you have to drill them out. I am aware of galvanic corrosion, which often corrodes aluminum when it is in contact with steel, especially if in the presence of moisture and even more especially moisture with salt. The use of stainless fasteners should AFAIK greatly reduce corrosion of the fasteners but am unaware of any change to the galvanic corrosion rates on the aluminum. Are you suggesting an increase in galvanic action between a stainless fastener and a plain steel nut? Please expand. I would also appreciate comment on the use of thread lubricants like 'Nevr-Seize' which IMHO allow increased clamping force and also greatly reduce thread seizing from corrosion. All it takes for corrosion to begin is two dissimilar metals and a bit of dirty moisture (obtainable free from polution and humidity). Even two pieces aluminum of different alloys can cause corrosion. AC43-13, which every owner should have a copy of, has an excellent section on corrosion. |
On 14 May 2006 03:37:06 -0700, "Jay Honeck"
wrote: This seems odd, Robert. Is your plane parked outside? Why would those inspection panel screws be so corroded? Unless...were they never removed recently? (More work undone-but-paid-for?) I strip a fair number of screws every year -- but I've NEVER had to drill any out on either of the planes we've owned. Dude, you really need to take a good look at the underside of a Mooney, especially an older one. You just "think" a PA28 has a lot of screws. Unless things have changed a whole bunch, they are mostly countersunk machine screws, opposed to your universal head PK screws. Really ups the temptation for a tech/owner to use power tools to crank the **** out them when closing up. Makes me shudder just thinking about it.. What I like is when you have everything in neat little tupperware cups underneath the appropriate parts of the plane -- and then the shop moves the plane. Or they pull an extension cord under your plane, and lasso all the parts buckets. Or they get kicked over. THAT is my pet peeve about doing an annual. Mine is wheels off for inspection, somebody steps on the pedals and blows out the wheel cylinder pistons. I would highly recommend this experience to any aircraft owner who is comfortable with a wrench. Agree 100%. I have a voluminous knowledge of the inner workings of my aircraft, solely because of doing the owner-assisted annuals. In my case, the transition from allegedly mucho-experienced tech to private pilot was definitely made a lot easier by having in-depth knowledge of aircraft systems. TC |
You know what? I've been through this one so many times, but it's been
a few years, and I just don't have the energy to fight this fight again. There is NO "torque-limiting" power screwdriver-type tool that has both the ability to prevent over-tightening, and allow sufficient "torque" to be applied to screws installed into aircraft nutplates. A slightly boogered screw or nutplate will NOT be tightened sufficiently, or else other screws will be over-tightened-there is NO middle ground. In most cases, a quality torque-limiting screwdriver set at minimal torque can be used by an experienced operator to run screws and initially secure panels. The final "ginch" needs to be performed by a human that knows what the **** he/she is doing. There is a large portion of the "certified technician" population that isn't smart enuff to use the proper bit for the type of screw to be r/r'd, let alone to use power to drive it. It's not much of a stretch to say that this applies to owner-performed maintenance also. TC |
Yes and bits are cheap, use new Phillips bits regularly.
Once the screwdriver is damaged it will destroy all the screw slots afterward. If the screws have paint in the slot, clean it out before you try to unscrew the fastener. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. wrote in message oups.com... | You know what? I've been through this one so many times, but it's been | a few years, and I just don't have the energy to fight this fight | again. | | There is NO "torque-limiting" power screwdriver-type tool that has both | the ability to prevent over-tightening, and allow sufficient "torque" | to be applied to screws installed into aircraft nutplates. | | A slightly boogered screw or nutplate will NOT be tightened | sufficiently, or else other screws will be over-tightened-there is NO | middle ground. | | In most cases, a quality torque-limiting screwdriver set at minimal | torque can be used by an experienced operator to run screws and | initially secure panels. The final "ginch" needs to be performed by a | human that knows what the **** he/she is doing. | | There is a large portion of the "certified technician" population that | isn't smart enuff to use the proper bit for the type of screw to be | r/r'd, let alone to use power to drive it. It's not much of a stretch | to say that this applies to owner-performed maintenance also. | | TC | |
![]() wrote in message oups.com... You know what? I've been through this one so many times, but it's been a few years, and I just don't have the energy to fight this fight again. There is NO "torque-limiting" power screwdriver-type tool that has both the ability to prevent over-tightening, and allow sufficient "torque" to be applied to screws installed into aircraft nutplates. But... a power screwdriver set below the specified torque for a screw and then torqued by hand with a calibrated torque wrench set to the proper setting will work just fine, or am I wrong? I believe that I am restating your paragraph below, but in a way that my son or mother could read it. A slightly boogered screw or nutplate will NOT be tightened sufficiently, or else other screws will be over-tightened-there is NO middle ground. We were taught in A&P school not to reuse fasteners. I doubt very seriously that this actually happens in the real world, but in the schools perfect world, this should eleminate *most* of the "boogered" fastener problems. In most cases, a quality torque-limiting screwdriver set at minimal torque can be used by an experienced operator to run screws and initially secure panels. The final "ginch" needs to be performed by a human that knows what the **** he/she is doing. There is a large portion of the "certified technician" population that isn't smart enuff to use the proper bit for the type of screw to be r/r'd, let alone to use power to drive it. It's not much of a stretch to say that this applies to owner-performed maintenance also. TC --- avast! Antivirus: Outbound message clean. Virus Database (VPS): 0619-3, 05/12/2006 Tested on: 5/14/2006 9:55:47 PM avast! - copyright (c) 1988-2006 ALWIL Software. http://www.avast.com |
You know what? I've been through this one so many times, but it's been a few years, and I just don't have the energy to fight this fight again. There is NO "torque-limiting" power screwdriver-type tool that has both the ability to prevent over-tightening, and allow sufficient "torque" to be applied to screws installed into aircraft nutplates. I guess I should have been more clear. I didn't intend to use the screwdriver to set the screws to the proper torque, I never trust those kind of tools for that, just to get it in with out getting them too tight. On any thing that is important, I always go back over it with a hand driver to finish the job and get them tight. Also why would anyone reuse a screw with messed up threads? Just get a new one already. The nut plate is another story though, those are a bit of work to replace so I guess it would depend on just how bad the threads were. -- Chris W KE5GIX Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
I used a torque limiting powered screwdriver once on the PK screws into
tinnermans to put my Cessna back together. I learned a lessons after a flight when several were missing. I use the power screwdriver to run the screws in and the torque by hand. No problems since. Ross wrote: You know what? I've been through this one so many times, but it's been a few years, and I just don't have the energy to fight this fight again. There is NO "torque-limiting" power screwdriver-type tool that has both the ability to prevent over-tightening, and allow sufficient "torque" to be applied to screws installed into aircraft nutplates. A slightly boogered screw or nutplate will NOT be tightened sufficiently, or else other screws will be over-tightened-there is NO middle ground. In most cases, a quality torque-limiting screwdriver set at minimal torque can be used by an experienced operator to run screws and initially secure panels. The final "ginch" needs to be performed by a human that knows what the **** he/she is doing. There is a large portion of the "certified technician" population that isn't smart enuff to use the proper bit for the type of screw to be r/r'd, let alone to use power to drive it. It's not much of a stretch to say that this applies to owner-performed maintenance also. TC |
Learning from an owner annual | Robert M. Gary | Piloting | 88 | July 5th 06 07:07 AM |
2006 Annual -- My 8th Owner Assisted -- Update | Jay Honeck | Owning | 14 | March 27th 06 07:11 PM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
