"Going for the Visual"
Old April 9th 04, 08:53 PM
Newps
O. Sami Saydjari wrote:
So, my question becomes, at what point do you abort the attempt to go
visual and transition to an IFR approach.
When you are over the airport and can't see it.
Say, you have a GPS and ATC
cleared you down to 2000 ft AGL and you are 10 miles from the airport.
Do you continue at that altitude to the airport until you are right on
top of it (controller permitting), notice that you are still not out of
the clouds, and then ask for an IFR approach at that point?
Yes.
Just trying
to see how the transition from "going for visual" to "err, no can
do...need an instrument" happens. Does the controller force the
decision at some distance out?
He may if there is other traffic. If you are the only one and therefore
aren't causing delays for anybody I'll drive you right to the airport,
if you call it in sight then you can have the visual, if not you'll do
an instrument approach.
Old April 9th 04, 08:58 PM
Steven P. McNicoll
"Newps" wrote in message
news7Ddc.110245$JO3.77994@attbi_s04...
While the 1000/3 applies because you have to have VFR to get a
visual the ceiling needs to be higher than that because there are no
MVA's that are even as low as 1000 feet. So practically speaking
the ceiling needs to be higher than the MVA for that area.
An aircraft can sight the field through a broken layer and be cleared for a
visual approach.
Old April 9th 04, 09:14 PM
Bob Gardner
I have heard rumors for years that the feds were going to eliminate MSAs
because pilots persist in trying to make them part of IFR procedures. Hasn't
happened yet, and the misunderstanding is still around.
Bob Gardner
"O. Sami Saydjari" wrote in message
A while back, I was with an experienced pilot, IMC, descending to land
at my home airport. The airport is not in an environment where ATC will
give vectors to final. As we approached, ATC asked which approach we
wanted. He said that he was "going for the visual." The ceilings were
right at the Minimum Safe altitude (MSA)--3000. I think ATC said that we
could descend to 3000 and report airport in sight.
Is this request of "going for the visual" usual?
Is it the norm if ceilings are above MSA?
-Sami
N2057M, Piper Turbo Arrow III
Old April 9th 04, 09:57 PM
Ben Jackson
In article 7vDdc.810$nK1.8649@attbi_s54,
I've never really looked at them. I lump them in with information like
"200' unlit tower 2 miles from the airport". When it becomes a factor
I'm in much bigger trouble than a bit of obstruction info is going to
fix!
Ben Jackson
http://www.ben.com/
Old April 9th 04, 10:24 PM
Andrew Sarangan
"Bob Gardner" wrote in
news:7vDdc.810$nK1.8649@attbi_s54:
MSAs because pilots persist in trying to make them part of IFR
procedures. Hasn't happened yet, and the misunderstanding is still
around.
Bob Gardner
I like the MSA because it gives me an idea of what the terrain is like.
We had this discussion before, but no one has given a good reason what
exactly is wrong with the MSA. It gives you 1000' obstacle clearance,
which is exactly what you need for IFR (except in mountainous areas).
Someone pointed out that MSA is not an IFR procedure because the AIM says
it is for emergency use only. Someone else said it was because MSA is not
measured to the same precision as other altitudes. Fine, but if the FAA
is going as far as eliminating it, there must be something more to this
than that. Has there ever been an accident or violation as a result of a
pilot using the MSA?
Old April 9th 04, 10:30 PM
Michael
OK. It just happened, in this case, that ATC was able to let us go down
to what was coincidentally that MSA for the area.
Right. The operational altitude is really MVA, which is not available
to you. It could be a lot lower. Right off, I can think of some
airports where it is 1400 ft lower, because the obstructions that
drive the MSA are over 20 miles from the airport.
That's your decision as PIC.
You could do that. Sometimes it even works. Cloud bases are often
ragged. Or you could tell him that you're still in solid IMC and need
the approach. Your call.
Just trying
That all depends on the MVA boundaries, traffic, etc. For example,
I'm familiar with one field where the MVA is 1700 MSL from one
direction, 2000 from another, and the dividing line seems to be about
a mile from the field. As a result, if you approach from the right
direction, you can get a descent to 1700 - but if you don't get the
airport in sight in a timely manner, you get a climb which essentially
destroys any chance of doing the visual.
In general, the controller will prefer you do the visual if he has a
preference at all - it's less work than vectoring you to final, ties
up less airspace, gets you out of his hair quicker, etc. The only
time a controller doesn't want you to do the visual is if he thinks
you won't get in.
Michael
Old April 9th 04, 10:36 PM
Steven P. McNicoll
"Michael" wrote in message
m...
to you.
Why would the MVA not be available to him?
Old April 10th 04, 12:16 AM
Bob Gardner
No way of knowing. If there had been an accident, a contributing factor
would be "improper IFR" with no details.
Bob Gardner
"Andrew Sarangan" wrote in message
. 158...
around.
Bob Gardner
Old April 10th 04, 12:19 AM
SeeAndAvoid
Alot of how it goes depends on the recent trends, are they getting in,
where are they cancelling, or are they cancelling after landing.
If they arent breaking out until 1,000' below our MIA (Minimum
IFR Altitude, similar to MVA, but not MSA), it's kind of pointless
to bother with a Visual.
If someone wants to try anyway, and if there's not a line of others
behind them, I'll let them try. But if they get right up on the airport
and then decide they want that ILS I suggested after all, it's the back
of the line.
Visuals are great, but make sure you can maintain visual with
the airport.
Chris
-Sami
Old April 10th 04, 04:01 AM
Ron Rosenfeld
On Fri, 09 Apr 2004 11:33:20 -0700, Jim Weir wrote:
I don't know about the rest of ye all, but the real world out here is to be
vectored as low as the controller can give you, get the airport in sight, and
"cancelling IFR". That way the 1000 & 3 does not apply.
Yes, but you have to maintain VMC, whereas on a visual approach under IFR,
that is not a requirement, so long as you maintain the field in sight. In
other words, you don't have to maintain VFR cloud clearance requirements
while enroute from your present position to the field.
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
Night over water Stuart King Instrument Flight Rules 43 March 4th 04 01:13 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Visual Appr. Stuart King Instrument Flight Rules 15 September 17th 03 08:36 PM
