"Going for the Visual"
Old April 9th 04, 08:31 PM
O. Sami Saydjari
Default "Going for the Visual"
A while back, I was with an experienced pilot, IMC, descending to land
at my home airport. The airport is not in an environment where ATC will
give vectors to final. As we approached, ATC asked which approach we
wanted. He said that he was "going for the visual." The ceilings were
right at the Minimum Safe altitude (MSA)--3000. I think ATC said that we
could descend to 3000 and report airport in sight.
Is this request of "going for the visual" usual?
Is it the norm if ceilings are above MSA?
-Sami
N2057M, Piper Turbo Arrow III
Old April 9th 04, 08:33 PM
Jim Weir
I don't know about the rest of ye all, but the real world out here is to be
vectored as low as the controller can give you, get the airport in sight, and
"cancelling IFR". That way the 1000 & 3 does not apply.
Roy Smith
-The MSA has little to do with it. The MSA is an emergency altitude with
-no regulatory meaning (at least in the US). What's important is that
-you've got the weather minimums for a visual approach (1000 & 3) and
-that ATC can issue you a clearance to descend low enough that you can
-see the airport (or the aircraft you're following).
http://www.rst-engr.com
Old April 9th 04, 08:44 PM
Roy Smith
It's pretty common to request a visual approach. It's usually the
simpliest and quickest way to get to the airport, if the weather
conditions allow it.
Old April 9th 04, 08:47 PM
Ron Rosenfeld
On Fri, 09 Apr 2004 13:31:23 -0500, "O. Sami Saydjari"
-Sami
It has nothing to do with MSA. Basically, weather needs to be at least
1000/3, and the pilot needs to have the airport or an a/c to follow in
sight.
AIM 5-4-20. Visual Approach
a. A visual approach is conducted on an IFR flight plan and authorizes
a pilot to proceed visually and clear of clouds to the airport. The pilot
must have either the airport or the preceding identified aircraft in sight.
This approach must be authorized and controlled by the appropriate air
traffic control facility. Reported weather at the airport must have a
ceiling at or above 1,000 feet and visibility 3 miles or greater. ATC may
authorize this type approach when it will be operationally beneficial.
Visual approaches are an IFR procedure conducted under IFR in visual
meteorological conditions. Cloud clearance requirements of 14 CFR Section
91.155 are not applicable, unless required by operation specifications.
b. Operating to an Airport Without Weather Reporting Service. ATC will
advise the pilot when weather is not available at the destination airport.
ATC may initiate a visual approach provided there is a reasonable assurance
that weather at the airport is a ceiling at or above 1,000 feet and
visibility 3 miles or greater (e.g. area weather reports, PIREPs, etc.).
Old April 9th 04, 08:58 PM
O. Sami Saydjari
OK. It just happened, in this case, that ATC was able to let us go down
to what was coincidentally that MSA for the area.
So, my question becomes, at what point do you abort the attempt to go
visual and transition to an IFR approach. Say, you have a GPS and ATC
cleared you down to 2000 ft AGL and you are 10 miles from the airport.
Do you continue at that altitude to the airport until you are right on
top of it (controller permitting), notice that you are still not out of
the clouds, and then ask for an IFR approach at that point? Just trying
to see how the transition from "going for visual" to "err, no can
do...need an instrument" happens. Does the controller force the
decision at some distance out?
-Sami
Old April 9th 04, 09:14 PM
Roy Smith
If you get as low as the controller can get you and you still can't see
the airport. Just say something like, "negative contact, request ILS"
and the controller will give you a new clearance for the instrument
approach.
That sounds like one reasonable way of doing it. Of course, it pays to
get whatever weather info is available. If there's an AWOS/ASOS that's
reporting 1500 overcast and the controller says he can only get you down
to 2000, there's not much point.
Just trying
It's not the job of the controller to tell you what to do. You make
requests and as long as he's able to, he'll issue you clearances.
If you're north of the airport and instrument approach is the ILS-36,
you've got to go over the top of the airport to get to the appoach.
Assuming no conflicting traffic, you could ask the controller to vector
you onto downwind for 36 at the MIA to see if you can see the runway.
If you do, you can request the visual (or contact) right then and there.
If you don't see anything, you just keep going out to the IAF and fly
the approach normally.
On the other hand, if you're already pretty much lined up for an
instrument approach, you really don't gain anything by asking for a
visual.
Old April 9th 04, 09:28 PM
Steven P. McNicoll
"Jim Weir" wrote in message
be
and
It does if your destination is in a surface area.
Old April 9th 04, 09:34 PM
David Brooks
"Ron Rosenfeld" wrote in message
sight.
sight.
This tells you when you can commence and continue the visual approach. I
think the question was more on the lines of the appropriate communications
with ATC when you think there's a visual in your future, but you can't be
certain yet.
-- David Brooks
Old April 9th 04, 09:47 PM
Newps
MSA plays no role whatsoever in any altitude assigned by ATC. We don't
know or care what the MSA is. If you have to go by the airport to get
to where you would start an approach ask ATC to bring you down to the
MVA at the airport as you go by. If you see the airport you can get the
visual, if you're still in the clouds you're headed for the approach
anyways.
Old April 9th 04, 09:49 PM
Newps
sight.
While the 1000/3 applies because you have to have VFR to get a visual
the ceiling needs to be higher than that because there are no MVA's that
are even as low as 1000 feet. So practically speaking the ceiling needs
to be higher than the MVA for that area.
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 03:34 PM
Night over water Stuart King Instrument Flight Rules 43 March 4th 04 02:13 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 06:20 AM
Visual Appr. Stuart King Instrument Flight Rules 15 September 17th 03 09:36 PM
