#11
![]() Brad Z wrote: I'll give Richard the benefit of the doubt that the inclusion of the Bryne intersection makes this approach just a bit different from your typical on-airport "No FAF" out-n-back approach. The Bryne intersection only serves as a step-down when using the Pittsburgh altimeter setting. While it serves to aid in situational awareness when flying the approach without GPS, it does not serve as a FAF. The fact that there is no timing information from FAF to MAP is another clue. *Every* on-airport, no-FAF NRB orVOR IAP approved for GPS overlay has a sensor FAF. It is not unique to this location. What is different about this location is that BRYNE is a stepdown fix for optional lower minimums, but nonetheless it becomes the sensor FAF when it's tagged as "FAF" in the database. And, this isn't the only on-airport, no-FAF IAP with an optional stepdown fix. Those have been around for years, long before GPS. |
![]() "Brad Z" wrote in message news:qTUdc.3086$_K3.24982@attbi_s53... Bryne is not required to be identified unless you are using the Pittsburgh altimeter setting and need to use it as a stepdown fix. Besides, I've never seen a "VOR required" note on an approach. Anyone else? The note "VOR required" is not used because all IFR aircraft are assumed to have at least one VOR receiver. |
![]() PaulaJay1 wrote: My refference is Trevor Thom's Instrument Flying. He says: "The FAF is marked on IAP charts with a maltese cross or a lighting bolt symbol. Where no final approach fix is shown, final descent should not be commenced until the airplane is established within +or- 5 deg of the final approach course." His advice is good, but technically would apply only to ICAO PANS-OPs countries where they define on course with plus-or-minus limits. In a strict sense the FAA refuses to legally define on-course as anything other than on-course, the PTS standards notwithstanding. This is confusing to me as it says it is marked and then says what to do when it isn't. If I were flying it, I would assume Bryne (though assumptions on fimal are dangerous). Another interesting point, for flying the NDB, it doesn't say VOR required. No, because the VOR fix is optional. If you can use it, you get lower minimums. And, it is policy to never state "VOR Required" because every IFR airplane is presumed to have at least one VOR receiver. |
![]() Brad Z wrote: "PaulaJay1" wrote in message ... Another interesting point, for flying the NDB, it doesn't say VOR required. Bryne is not required to be identified unless you are using the Pittsburgh altimeter setting and need to use it as a stepdown fix. Besides, I've never seen a "VOR required" note on an approach. Anyone else? The PIT altimeter is a different issue. The 1840 becomes 1920 when using PIT. The same 80-foot addivitve should have been applied to the stepdown minimums; i.e. 1740 would become 1820 with BRYNE and using PIT altimeter. They screwed up the remote altimeter charting. |
Just curious, how would vectors to the NDB final fit in with the
requirements to vector outside the approach gate if no approach gate exists? (There is no FAF) FAAH 7110.65 Section 9. Radar Arrivals 5-9-1. VECTORS TO FINAL APPROACH COURSE Except as provided in para 7-4-2, Vectors for Visual Approach, vector arriving aircraft to intercept the final approach course: a. At least 2 miles outside the approach gate unless one of the following exists: 1. When the reported ceiling is at least 500 feet above the MVA/MIA and the visibility is at least 3 miles (report may be a PIREP if no weather is reported for the airport), aircraft may be vectored to intercept the final approach course closer than 2 miles outside the approach gate but no closer than the approach gate. 2. If specifically requested by the pilot, aircraft may be vectored to intercept the final approach course inside the approach gate but no closer than the final approach fix. EXCEPTION. Conditions 1 and 2 above do not apply to RNAV aircraft being vectored for a GPS or RNAV approach. AIM Pilot/Controller Glossary APPROACH GATE- An imaginary point used within ATC as a basis for vectoring aircraft to the final approach course. The gate will be established along the final approach course 1 mile from the final approach fix on the side away from the airport and will be no closer than 5 miles from the landing threshold. Steven P. McNicoll wrote: "Brad Z" wrote in message news:83Vdc.3108$xn4.16249@attbi_s51... Semi-related question: Can vectors be issued for this type of approach? Yes. In addition to the verbiage of "vectors for the approach" it was mentioned that ATC is required to specify distance from the FAF. Can ATC just provide a vector to intercept the approach course and provide distance to the missed approach point / Airport / navaid? I've only flown one or two of these as full practice approaches, so I'm curious if there was anything different about them. ATC must issue position information relative to a fix on the final approach course. If none is portrayed on the radar display, or if none is prescribed in the procedure, position information is issued relative to the navigational aid which provides final approach course guidance or relative to the airport. |
![]() "J Haggerty" wrote in message news:GwWdc.10755$wb4.9646@okepread02... Just curious, how would vectors to the NDB final fit in with the requirements to vector outside the approach gate if no approach gate exists? (There is no FAF) Interesting. It appears the definition of Approach Gate was altered at some point. As I recall, it did not formerly refer specifically to the FAF, but to the outer marker or the point used in lieu of the outer marker. |
![]() J Haggerty wrote: Just curious, how would vectors to the NDB final fit in with the requirements to vector outside the approach gate if no approach gate exists? (There is no FAF) If there is no FAF what would preclude them from video mapping the approach gate 5 miles from the threshold? |
![]() J Haggerty wrote: wrote: Richard Kaplan wrote: I cannot find a charted final approach fix on the GPS 23 approach to KUCP (New Castle, PA): http://download.aopa.org/iap/2004021...gps_rwy_23.pdf The Garmin 530 and UPSAT GX50 both consider Bryne intersection to be the FAF, but there is no Maltese cross. Any ideas? Can an approach exist without a charted FAF? Is there an alternate nomenclature to replace the Maltese cross? Jeppesen plates show the same situation. Richard, You'are a CFI-I and you don't know the answer to that question? First, it's an overlay IAP, so it's really an NDB approach with GPS overlay authorization added. Second, the primary approach--the NDB--is what is known in TERPs as an "On Airport, NO-FAF NDB instrument approach procedure." Third, because On-Aiport VOR and NDB IAPs, by definition, have no FAF, the industry added a Sensor "FAF" to these on-airport IAPs, so that the GPS avionics would have a psuedo-FAF to trigger the approach mode. Jeppesen issued a briefing bulletin on all this several years ago, and it is mention, albiet briefly, in the AIM. In reality, with a on-airport, No-FAF VOR or NDB IAP, you are in the final segment as soon as you complete the procedure turn. You're partly right, this is a GPS overlay of an existing NDB N0-FAF procedure, but there is no pseudo-FAF on the procedure. Normally the pseudo-FAF would be located 4 miles prior to the NDB. But, since this on-airport, No-FAF NDB has a stepdown fix 3.5 miles from the runway Jeppesen coded the CNF at that point, and called it the "FAF" so for GPS purposes it is the sensor fix. |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Why an NDB approach with a miss to an intersection? | Ben Jackson | Instrument Flight Rules | 10 | March 25th 04 03:53 AM |
Changes to Aircraft Approach Categories?! | skyliner | Instrument Flight Rules | 10 | February 9th 04 08:55 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
