Why don't wings have dimples?
Old June 12th 06, 05:05 PM posted to rec.aviation.homebuilt
Default Why don't wings have dimples?
Ron Wanttaja wrote:
On 12 Jun 2006 06:07:26 -0700, wrote:
if golf balls have
dimples, to help them sail further, why don't wings
Philippe Vessaire wrote:
because birds hav'nt....
Dang.
That's a lot of feathers for the fellow to have to glue to his wings.
"Fortunately, I keep my feathers numbered for just such an emergency."
- Daffy Duck
Foghorn Leghorn.
Old June 12th 06, 05:14 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe wrote:
Dimples work on round things under a relativly narrow range of reynolds
numbers (a function of speed, size and properties of air) by helping keep
the boundry layer attached. Golf balls happen to fit into that range and
have the right shape. Gliders sometimes use "turbulator" tape to trip a
laminar boundry layer and make it turbulant so it will stay attached
longer - but the placement is critical (and only works if you have a very
laminar wing to begin with).
So, if you are having boundry layer seperation problems due to the shape of
your fairing aft of the maximum "thickness", then dimples or other boundry
layer devices may or may not help but most likely they will not.
So maybe you could use dimples on fairings, fuselage or struts,
especially
if the struts are circular tubing, eh?
FF
Lots of aviation stuff for sale cheap:
http://groups.google.com/group/rec.a...e=source&hl=en
Old June 12th 06, 08:29 PM posted to rec.aviation.homebuilt
Dancing Fingers wrote:
Hi all,
I always wanted to build my own airplane but the time and money has
eluded me. So I've decided to design and build my own recumbent trike,
with farings. This brings me to my question, if golf balls have
dimples, to help them sail further, why don't wings -- especially for
STOL aircraft? Would putting dimples in my faring reduce my wind
resistance?
Just curious.
Chris
I read a story about NASA research of wings with thousands of tiny
holes that suck air into them on the top of the wing. Apparently they
aid in laminar flow, but there were concerns with the holes clogging
too easily with dirt.
Dean
Old June 12th 06, 09:49 PM posted to rec.aviation.homebuilt
especially
FF
Could be. Somewhere or another I saw some wind tunnel data on golf balls
that nicely showed how the flow remained attached further around the back
side (no spin was involved - just a reduction in the wake). But you would
have to find out what the range of Reynolds number this works for...
Geoff
Old June 12th 06, 11:34 PM posted to rec.aviation.homebuilt
Thanks everyone for the great answers vto my silly question.
especially
FF
Geoff
Old June 13th 06, 06:11 PM posted to rec.aviation.homebuilt
Does anyone know of a good simulation program where you could play with
dimples on a large hot dog shape, just to see what happens.
Just more curious.
Chris
especially
FF
Geoff
Old June 13th 06, 06:51 PM posted to rec.aviation.homebuilt
("Alan Baker" wrote)
First of all, golf balls have dimples because in order to create lift they
need to influence the air passing by them with the golf ball's spin. The
dimples help to make the air slow down beneath the ball and speed up above
it; creating downward flow.
Wings produce that downward flow with their shape.
How about a dimpled spinner?
Your choice - slice or draw.
Montblack
Old June 14th 06, 01:46 AM posted to rec.aviation.homebuilt
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
especially
FF
Geoff
I've seen a video of that, but don't recall where. However, I believe that
you have it backward--the flow detaches earlier (from the non-spinning golf
ball) and reduces the drag.
I am not quite sure how that might relate to wings and propellers; but I
suspect that they (wings and props) are two radically different, and
possibly opposite, phenomena.
Peter
Old June 14th 06, 01:55 AM posted to rec.aviation.homebuilt
"Alan Baker" wrote in message
In article . com,
"Dancing Fingers" wrote:
Hi all,
resistance?
Just curious.
Chris
they need to influence the air passing by them with the golf ball's
spin. The dimples help to make the air slow down beneath the ball and
speed up above it; creating downward flow.
I believe that you have the effect exactly backward. The spin, which should
only be significant using the more steeply pitched irons; slows the relative
speed over the "top" of the ball and causes it to remain attached longer,
while the air flowing under the bottom breaks away more quickly, which would
result in a slight net lift. It also explains why a "slice" curves as it
does--which is why a smooth ball would have improved my game. :-(
Exactly.
Peter
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
Charging for Wings safety seminar? Marty Shapiro Piloting 19 June 23rd 04 05:28 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Stolen "Champ" wings located...from 23,000 feet!! Tom Pappano Piloting 17 December 15th 03 01:24 PM
Wings from "Champ" stolen in Oklahoma after emergency landing Tom Pappano Piloting 1 December 7th 03 05:02 AM
