#11
Paul Tomblin wrote:
Years and years ago, I was told how to access some diagnostic modes on my Garmin GPSMAP 195. The diagnostic mode showed the state of all sorts of internal stuff, and from that it was apparent that one major difference between the aviation 195 and the marine 175 is that the 195 had temperature and pressure sensors. I suspect they put that in there so that they could correct the results from the GPS radio for those factors. The other major difference was that the 195 had WAY more flash memory to store all those aviation waypoints. Paul, Do you happen to remember what the keystrokes were to get to the 195's diagnostic mode? I'd be curious to see what mine is saying. --- Jay -- Jay Masino "Home is where the critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Paul Tomblin wrote:
Years and years ago, I was told how to access some diagnostic modes on my Garmin GPSMAP 195. The diagnostic mode showed the state of all sorts of internal stuff, and from that it was apparent that one major difference between the aviation 195 and the marine 175 is that the 195 had temperature and pressure sensors. I've had several handheld, general purpose / outdoor GPS units that gave temperature and possibly (I don't clearly remember) pressure in diagnostic mode. Many newer marine units have external water temperature, depth sensor, and water speed sensor capabilities, as well as the same memory capabilites as aviation units. While airplanes need aviation waypoints and related information, boaters need serious waterway chart storage, so memory is just as important. The better marine units have the waterborne equivalent of our VFR charts stored and displayed by the unit. I really think price differences have more to do with our $70 inner tubes and $50 carriage bolts than technology differences. Here's one link to diagnostic modes, use at your own risk: http://www.gpsinformation.org/dale/secret.htm The rest of the site: http://www.gpsinformation.org is got enough info to spin your head! G We've flown with a Garmin 196 next to an eTrex Vista and a 60CS (with an included magnetic compass and barometric altimeter), the 196 was no more accurate than the $3-400 handheld units. My co-owner has the marine clone of the 296, loaded with "BlueCharts", and the unit is just as accurate, feature laden, and powerful as the aviation model. |
![]() wrote in message oups.com... As part of my work (civil engineer), I routinely use GPS equipment in surveying. And construction specifications usually calls for this equipment to be held stationary for as much as three hours where crucial transition points are to be located, and for up to twenty minutes at less important locations. I guess since you folk use GPS to navigate all across the globe and requires to be both very precise and instantaneous, my equipment is very much inferior to what's used in aviation. Has anyone here used the type of equipment I'm mentioning? You should see the time the thing I use takes to stabilize itself to show the elevation... you'd comfortably CFIT if you had that in your airplane ![]() Aircraft GPS systems are accurate to about 30 feet; how well do you think that would work if your building a bridge, or more importantly, a tunnel? |
Matt Barrow wrote:
Aircraft GPS systems are accurate to about 30 feet; how well do you think that would work if your building a bridge, or more importantly, a tunnel? Some, maybe even many, aviation units can get far better accuracy with differential and WAAS corrections. |
B A R R Y wrote: Many newer marine units have external water temperature, depth sensor, and water speed sensor capabilities, as well as the same memory capabilites as aviation units. While airplanes need aviation waypoints and related information, boaters need serious waterway chart storage, so memory is just as important. The better marine units have the waterborne equivalent of our VFR charts stored and displayed by the unit. I really think price differences have more to do with our $70 inner tubes and $50 carriage bolts than technology differences. Marine units (at least the high-end ones) often have tide charts built into them too. Unlike winds aloft, tide heights and tidal currents are very predictable and can be calculated years in advance. A good GPS unit will have these tables built in, and can superimpose on the displayed chart a field of current vectors, and tidal water depths. Marine units also have a feature which is very handy on a boat, but more or less useless on an airplane (unless you're hauling skydivers). Hit the MOB (Man Over Board) button, and the unit will immediately store your current position as a user waypoint and start navigating to it. They also often have an anchor watch feature, which sounds an alarm if you ever get more than N feet away from your current position. You do then after you've anchored to alert you to the possibility that your anchor is dragging (you set N to however many feet of rode you've put out). Oh, yeah, and marine units tend to be waterproof. I don't know of many aviation units that are designed to 1) float, and 2) survive be submersed in salt water. |
Aircraft systems are designed to rather wide standards,
measured in meters and not the centimeter accuracy of a surveyor's system. An aviation GPS will lock on to all visible satellites and begin giving navigation solutions within just a few minutes. The aviation and automotive-marine-hiker GPS include a navigation computer and will to some degree do all the calculations and display results. Your impression about aircraft accuracy is 100% backwards. You can find the specifications for GPS systems on the Garmin or other makers web sites. wrote in message oups.com... | Bob Noel wrote: | | [snip] | Has anyone here used the type of equipment I'm mentioning? You should | see the time the thing I use takes to stabilize itself to show the | elevation... you'd comfortably CFIT if you had that in your airplane | | yeah, but what is the accuracy of your GPS? | I suspect it is much more accurate than needed for aviation. | | | Not really Bob. Most building, refinery and pipeline surveys accept a | +/- 0.8 centimeter variation, so it isn't pinpoint like in aircraft, I | think. | | Btw, just out of interest - does TCAS use GPS data in some ways too? | | Ramapriya | |
![]() Roy Smith wrote: In article , B A R R Y wrote: ..... Hit the MOB (Man Over Board) button, and the unit will immediately store your current position as a user waypoint and start navigating to it. We use the MOB feature to memorize where we parked the car while Geocaching. Also, MARK saves a point on a route list. We "drop a mark" every time a decision (to turn etc) is made. The route can be reversed to get back to the car. |
![]() "B A R R Y" wrote in message . net... Matt Barrow wrote: Aircraft GPS systems are accurate to about 30 feet; how well do you think that would work if your building a bridge, or more importantly, a tunnel? Some, maybe even many, aviation units can get far better accuracy with differential and WAAS corrections. WAAS will provide about 10 feet, but that only for approaches with WAAS augmentation. See nice graphic at http://www.garmin.com/aboutGPS/waas.html |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Airmens' Freedoms Threatened by Harsh Congressional Proposals | Larry Dighera | Piloting | 24 | July 29th 05 06:15 PM |
Aviation Books&CD Roms FS | [email protected] | Home Built | 0 | April 10th 05 10:29 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
