How different is aviation GPS?
Old June 29th 06, 05:07 AM posted to rec.aviation.piloting
Default How different is aviation GPS?
As part of my work (civil engineer), I routinely use GPS equipment in
surveying. And construction specifications usually calls for this
equipment to be held stationary for as much as three hours where
crucial transition points are to be located, and for up to twenty
minutes at less important locations.
I guess since you folk use GPS to navigate all across the globe and
requires to be both very precise and instantaneous, my equipment is
very much inferior to what's used in aviation.
Has anyone here used the type of equipment I'm mentioning? You should
see the time the thing I use takes to stabilize itself to show the
elevation... you'd comfortably CFIT if you had that in your airplane
Ramapriya
Old June 29th 06, 06:16 AM posted to rec.aviation.piloting
Bob Noel wrote:
[snip]
yeah, but what is the accuracy of your GPS?
I suspect it is much more accurate than needed for aviation.
Not really Bob. Most building, refinery and pipeline surveys accept a
+/- 0.8 centimeter variation, so it isn't pinpoint like in aircraft, I
think.
Btw, just out of interest - does TCAS use GPS data in some ways too?
Ramapriya
Old June 29th 06, 07:56 AM posted to rec.aviation.piloting
Bob Noel wrote:
+/- 50+ meters is plenty accurate enough for aviation use in determining lateral position. +/- 10 meters vertically would be wonderful but not always obtained.
I confess I couldn't have guessed that )
No.
ADS-B does, but not TCAS.
Thanks, but how exactly does the TCAS get the coordinates of the
transponder it talks to, in determining whether or not an evasive
mechanism needs setting in? Anything like a +/- 50 meter accuracy there
would be disastrous.
Ramapriya
Old June 29th 06, 09:19 AM posted to rec.aviation.piloting
TCAS typically uses the transponder output to determine altitude of the
other traffic, and basic radio direction and range-finding processing to
determine direction and distance.
For the purpose of TCAS, +/- 50 meters is perfectly sufficient. Alerts are
provided at distances much greater than that, and an error of 50 meters
would affect the timing of the alert by a second or less. When in a
congested area, where TCAS is most typically important, airplanes are
traveling on the order of 50-100 meters per second.
You seem to be under the impression that flying involves a very high degree
of accuracy with respect to position information. That's simply not true.
Even in a differential GPS precision approach or a Cat III ILS, accuracy is
only to within a meter or so, and for anything else tens, hundreds, or even
thousands of meters is sufficient (depending on the exact situation).
In addition, while you are relying on your GPS receiver for altitude,
airplanes almost never do. They have barometric altimeters that provide a
different reference (not necessarily more accurate...just different) that is
more appropriate for the operation of an airplane (generally speaking). So
the GPS data is used only in two dimensions, in which the instantaneous
accuracy is generally much better, as compared to 3D accuracy including
altitude.
Your demand for accuracy in construction is FAR greater than any need
aviation has. As far as the difference in the GPS receiver goes, it is
likely that the basic operation of the GPS receiver you are using is
identical to that of an aviation handheld.
That said, I'm surprised you are using sample averaging to gain the accuracy
you need. Surveyors do use differential GPS with great success, and it
provides similar accuracy to what you're getting, only in a matter of
seconds rather than hours. (DGPS used for surveys has better accuracy than
that used for aviation because the reference point is so close to the
measured location in the case of surveying, whereas it may be quite a
distance away for aviation).
Pete
Old June 29th 06, 06:15 PM posted to rec.aviation.piloting
In a previous article, Stubby said:
I had my property surveyed and asked what the accuracy was. The
surveyor replied that 0.1 foot is the standard for most applications and
0.01 foot is required for commercial, high-precision applications.
They use GPS (DGPS??) but I don't know how.
You need a better surveyor. When I was doing road construction layout, we
were expected to get the marks within 5-7 millimeters. And when they
actually did the construction, they were allowed to be within 2-3
centimeters. (You've heard the expression: measure with a micrometer,
mark with chalk, cut with an axe.) Legal surveyors were supposed to be
*far* more accurate than us. For instance, we just held the chain (that's
the "measuring tape" to you) or laid it down on the ground. Legal
surveyors had a special device to make sure they were holding exactly the
right amount of tension on the chain because that's what it was calibrated
for.
ALL programs are poems, it's just that not all programmers are poets.
-- Jonathan Guthrie in the scary.devil.monastery
Old June 29th 06, 08:10 PM posted to rec.aviation.piloting
You also attach a thermometer to the tape because there is a
correction for expansion. If the tape was supported by the
ground, a tension of 10 pounds was required if I remember
correctly.
was. The
applications and
applications.
And when they
within 2-3
micrometer,
supposed to be
the chain (that's
ground. Legal
holding exactly the
it was calibrated
| for.
| Paul Tomblin
are poets.
Old June 29th 06, 03:16 PM posted to rec.aviation.piloting
Aircraft systems are designed to rather wide standards,
measured in meters and not the centimeter accuracy of a
surveyor's system. An aviation GPS will lock on to all
visible satellites and begin giving navigation solutions
within just a few minutes. The aviation and
automotive-marine-hiker GPS include a navigation computer
and will to some degree do all the calculations and display
results. Your impression about aircraft accuracy is 100%
backwards.
You can find the specifications for GPS systems on the
Garmin or other makers web sites.
| Bob Noel wrote:
| [snip]
to show the
your airplane
aviation.
surveys accept a
aircraft, I
| think.
ways too?
| Ramapriya
Airmens' Freedoms Threatened by Harsh Congressional Proposals Larry Dighera Piloting 24 July 29th 05 06:15 PM
Aviation Books&CD Roms FS [email protected] Home Built 0 April 10th 05 10:29 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 11:55 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Owning 0 May 11th 04 10:43 PM
